Question about Canon FAXPHONE L170 Plain Paper Laser
Fax question When I send a fax on a Canon170, should it provide a sheet once completed that shows it was transmitted with the date/time stamp? If so, and it isn't doing that, how do I fix it?
  • studybuddy May 06, 2008
    Thank you so very much!
  • 2,098 Answers
You want a TX (transmit) Report. You can have the report printed after each fax is transmitted, including the first page of the fax sent if desired. Follow these steps to turn on the report.
1. Press Menu button
2. Use (left or right) arrows to FAX SETTINGS, press Set button
3. Use arrows to REPORT SETTINGS, press Set button
4. Use arrows to TX REPORT (may be there already), press Set button
5. Use arrows to OUTPUT YES, press Set button
6. If screen says REPORT WITH TX IMAGE, press Set button
7. Use arrows to ON or OFF, as desired, press Set button
8. Press Stop/Reset to exit the menu
Posted on May 05, 2008
Does the Canon 3235i have a time stamp function for sending faxes?
Press> Additional functions > Communication Settings>TX fax settings
Feb 17, 2012 | Canon ImageRUNNER 3235i Black and White...
NEED 2 PROGRAM COVER PAGE
Cover Sheet
You can have the fax machine generate a cover sheet and send it as the last page of your fax transmission. The cover sheet includes the date and time, the receiver's name and number if a Rapid Key or Speed Dial number is used, the sender's name and number, and the total number of pages.
? Your name and number must be programmed in order for them to appear
on the cover sheet (see page 49).
? To have the recipient's name appear, you must dial using a Rapid Key or
Speed Dial number with the name programmed.
1 Load the document(s).
• SEND READY will appear in the display.
• Press RESOLUTION and/or CONTRAST to set the resolution and contrast if needed.
Press Cover Sheet. (Flip up the Rapid Key overlay if it is down.)
• The display will briefly show COVER SHEET MODE ENTERED and then
revert to SEND READY.
• To cancel the cover sheet selection, press STOP.
3 Dial the receiving party and transmit the fax.
If desired, you can set your fax to automatically send a cover sheet with every
transmission (you do not have to press COVER SHEET each time). This is
accomplished by setting Option Setting 10 (Auto Cover Sheet) to YES as
explained on page 125.
Jan 17, 2011 | Sharp FO 5800 Fax
Hi, Power surge knocked out power briefly, but now we are getting no printed confirmation sheets that fax was transmitted. How to reset??
Press
Function
74
set
12
set
set
stop
To reset date and time press'
function
71
set
enter date and military time
set
stop
Oct 22, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Is there a way for me to leave a date/time stamp when sending a fax on my intellifax 1940CN?
if you enable send report you can get an a4 page with time and date confirming that the fax has been sent, but when set up it will print for every fax. the other option is to have it print on error only and you can manually print report of sent recieved items( all date and time stamped) with the number sent to as a list.
Aug 10, 2009 | Brother IntelliFAX 5750e Laser Fax
Time date stamp on fax machine
The time it was sent, if they have the time set correctly on the sending fax machine
Mar 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Probllem receiving a Fax
No, the solution you provided I had already done. Problem is not solved as it was guarranteed, but I was charge for it and you still want me to purchaed the premium solution.? Get real!. my charge should be refunded..Very dissatisfied.
Mar 30, 2008 | Lexmark X4270 All-In-One InkJet Printer
Receiving a fax
It will be a problem with the other ends fax when it sends its stretches out the fax too much and it transmits accross two pages. The other fax is telling your machine to print out accross two pages in the transmission. Older faxes are the worst for it.
Feb 18, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Grabs two sheets when sending a fax
Sounds like it just needs to be cleaned. If you can give me the make and model of the fax, I'm sure that I can find the manuals for you.
Mar 26, 2007 | HP OfficeJet 7410 All-In-One InkJet...
Canon FAXPHONE L170 Plain Paper Laser Logo
209 people viewed this question
old marine
old marine
