Question about Masterbuilt 20050106 Propane Smoker
Cannot get my smoker to go above 210 degrees
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Sep 05, 2010
Whats the normal operating temp on a 2000 Suburban 5.3 Vortex Eng? It's 90 above degrees temp wise in the city. Temp gauge in the truck shows between 200-210.
That temp is normal especially considering the ambient temp. A 50/50 antifreeze/water mix not only prevents freezing but raises the boil temp. The pressure in the system also does that. So, in reality, your boil temp is above 230 degrees.
Jul 16, 2011 | 2000 Chevrolet Suburban
Tip
Thermostat trick
This tip is for 210's 1.4 and 1.5. The original lowest degree temperature thermostat that manual calls for is 180 degree, but living in the southwest with a small 210 4 cyl calls for more cooling techniques. In the summer time I take out the thermostat and run it without it. In the winter time I install a regular GM 350 enginge 160 degree thermostat in my 210. It fits! And you can still run your 210 cool with 160 degrees.
on Aug 05, 2008 | 2006 Datsun 210
My cooling fan will not come on by its self ,but it does if u turn on the a/c
The radiator cooling fan runs constantly is A/C mode in order to disperse the extra heat from the condenser. With the A/C off the coolant fan should come on only when the engine temperature reaches about 210 degrees, and then only cool the system to about 190-200 degrees and shut off.
If the fans does not come on and allows the temperature to go much above 210 degrees you may have a bad temperature sensor.
Jul 02, 2011 | 2000 Chevrolet Cavalier
I am getting the EAAF code. What does it mean?
The manual said to unplug the smoker and wait 10 secs and then plug it back in. I tried that and it did not solve the problem. However, I did leave it plugged in with that error code while I was searching the web for an answer. Over the next 5 min or so, the error code went away and my smoker started heating up as if it had no issues.
The solution may be to just let it sit for a few min and then it will begin on its own. The only variable I can think of is that I am smoking in cold conditions for the first time. It may be the case that since the smoker was outside in single digit temperatures, that may have triggered the error code. Who knows, in any case, I am back to smoking for Thanksgiving. Crisis averted.
Nov 25, 2010 | Masterbuilt 20070106 Electric Smoker
Getting eaaf error code
Internal Temp is below 40 degrees. To remedy this, take a hair dryer, and heat up the heat sensor until it is above 40 dgrees. The unit should start to heat up. Keep it on the sensor until the unit is heating for a minute or two, it should stay on after that.
All of the sudden my grill will only heat up to around 350 degrees. It is about a year old and has worked flawlessly up till now. It lights and the flames seem to be coming out of all burners but just...
heatman101
Sep 03, 2010 | Weber SPIRIT E-210 (NG)
The temperature does not get above 200-250 degrees
Please provide the make and model number of the unit.
When you smoke meat, you generally never smoke at more than 220 degrees F.
Dec 17, 2009 | Weber Grilling
Heats only to about 350 degrees
how old is it may neet to clean and blow out burners
May 25, 2009 | Char-Broil Performance 463463006
Masterbuilt 20050106 Propane Smoker Logo
235 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
