Question about Kitchen Ranges
Frigidaire electric range fef326ab bought in oct 2005 heating element sparked while baking and now there is a hole in element, what could have caused this and could it be fixed, or will i have to buy new range?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=573215
Generic problem for all Kitchen Ranges
Posted by keepcooking on May 05, 2008
Frigidaire electric range fef326ab bought in Oct 2005
I would advise you to ALWAYS to FIRST UNPLUG YOUR APPLIANCE before beginning any service procedure.
To the best of my knowledge you can replace the heating element with a genuine part from Frigidaire, this happened to me on my water heater and the element just got old and too hot and it just popped and left one to three holes in the element and I just replaced it. I would have it done by an appliance specialist or your local appliance repair person. When ordering the part remember to give the Brand name, Model # and they might ask for the Serial #. So if you need further assistance, please feel free to contact your local appliance dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.frigidaire.com/products/products.asp
Contact Us
Customer Contact Center - USA
1-(800) 374-4432 Monday thru Friday 9:00 am to 5:30 pm EST
Canada 1-(800) 265-8352 Monday thru Friday 9:00 am to 5:30 pm EST
Extended Service Agreements 1-(866) 386-5286 Monday thru Friday
8:00 am to 6:00 pm EST
Order Genuine Frigidaire Parts 1-(800) 599-7569
8:30 am to 5:30 pm EST
Mailing address:
Electrolux Home products
P.O. Box 212378
Martinez, GA 309
Thanks, Don – The Appliance Man
Go Ahead. Use Us.
Posted on May 05, 2008
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
316418305 broiler element and bake element will not heat
Good Afternoon Friend,
I see that you are having trouble with your Frigidaire range, model# FEF336BC, broiler and bake element not heating. I would give your range a hard reset. You can do this by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Turn your oven on and if the elements are still not heating, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 23, 2012 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire Electric Range Model FEF355ESB
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 07, 2010 | Frigidaire FEF355 Electric Kitchen Range
Baking element replaced but still won't heat
you may have triped half your 220v breaker. (you should have shut it off when reparieng wire or it would have been live and zaped you) Or something in line with the wire that shorted blew out like a fuse in the range.
Nov 21, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Frigidaire Gallery stove, oven won't heat up (electric)
With the oven OFF, check the resistance of the bake element with a ohmmeter on the lowest scale. Rx1. If your reading is infinate, replace the element as most elements will open circuit when they burn out. They don't short out.
Jul 27, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Heat element from range
turn of power 2 screws hold in element on back wat, unplg and replug new element. assuming model correct FEF336BC bake element part number 316075103..TURN OFF POWER ALWAYS LIVE!!!!!!!
Oct 30, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire oven not working in bake setting
Hi Thanks For The Question. I Would Check The Bake Element. Replace The Bake Element .Thanks The Appliance Doc
Oct 06, 2008 | Frigidaire FEF366 Electric Kitchen Range
Kitchen Ranges Logo
274 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
