I have a Magnavox Model 42 MF130A Plasa Tv and have it hooked to a Dish Network Model 625 DVR. I would like to have the Model 6.0 IR/UHF Echo Star remote that came with the DVR control the TV for on and off volume etc. The same as the one that came with the TV. I have tryed scaning until my fingers are numb. Can anyone tell me how to find the correct code to control this Magnavox TV with a Echo Star model 6.0 remote??????
  • 1 more comment
  • parkerguns May 31, 2008
    Well this help is referancing an All in One 7800 and how to program it ?????? I actually asked for help programing a Echo Star remote 6.0 remote so these instructions have NOTHING to do with this remote and probably work great if you have a AIO 7800 ????? So I can only assume you never actually read my request for help and this is just a computer generated response to any cry for help on remotes..................????
    I do appreacite you trying to help but unless you actually read the request we could never comunicate......................... I asked for help with a model 6.0 REMOTE and you are asking me if I actually looked at hifi -remote site under URC-7800 ?????
    Since a Echo Star remote doesnt even have a "setup" button on it like the URC7800 how could this possibily be relevate????
    I have also tryed punching the button HUNDREDS of times to see if the code was in the remote before I ever contacted you as I was hoping you had a referance that I dont as to the actual code that Magnavox used on this TV or that you would look up the way to transfer the info end to end like you suggested for the 7800..............................
  • parkerguns Jun 02, 2008
    I have tryed all of those David and some of them will do interesting things like bring on the mute or even the source instead of turning on or off the TV like it should ????? Very strange deal ................. Magnavox has NOTHING on this code setup and basically BLEW ME OFF when I contacted them.
    I contacted Echo Star and they told me that my TV is probably weird as far as codes go?????
    I dont think any of them want to know about this problem???
  • 2,712 Answers
You can find the remote control codes for different brands of devices from
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
Posted on May 05, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
  • Swilin Sampson
    Have you actually tried the other link I provided?
  • Swilin Sampson
    Try 566, 506, 520, 525, 536, 564, 565, 567, 568, 569, 573, 575, 588, 610, 652, 654, 656, 659, 660, 664, 665, 666, 669, 671, 673, 674, 677, 710, 712, 723, 724, 729, 762
    are the remote codes for your Magnavox TV from your remote. However, I do not have the exact setup steps.
Can't get my 21 1 ir/uhf pro remote to work with dish network dvr 625
If you are attempting to program it to tv-2 on a 625 receiver it has to be set to a odd number for example number 7 instead of 2 or 6.
The reason for this is that the 625 receiver only supports band A frequencies for UHF and on a 21.x remote odd numbers are A band and even numbers are B band.
Sep 25, 2013 | DISH Network DVR-625 DTV Receiver /...
Recent IR20.0 remote problem developed after 2 years without any issues. The remote no longer communicates to my 722k dvr reciever while my LG Tv is turned on. I have Hdmi run directly from reciever to my...
Hi Robert, my name is Cheri Torres and I work on the Social Media Team at DISH. It sounds like your remote is experiencing IR(Infrared) interference from your LG TV. You can resolve this issue by converting your TV1 remote to UHF(Ultra High Frequency) instead of IR. In order to do this you will need a UHF remote, the 20.0 remote is only an IR remote. Please email me directly at with your account number or phone number on the account so that I can look into getting a UHF remote sent out. Thank you.
Cheri Torres
Social Media Representative
Apr 08, 2012 | DISH Network IR Remote Control
I get the dish network screen on # 2 tv and have lost the remote I can't get # 1 tv remote to change the channel. Is there any way to program the remote for tv 1 to change the channel on tv 2.
It is possible to get your TV1 remote to work TV2, but it would have to be a model 6.0/6.3/6.4. If it is not one of those models you would need to have a remote ordered and sent out; then it would work. If your remote is one of the above models; I have included the steps to get that done.
Changing Remote from UHF-to-IR and IR-to-UHF:
1.) Verify correct model of remote and it is IR/UHF compatible. Remove tab from bottom of remote. For TV1: Green Tab with Green 1 in it. For TV2: Blue tab with 2 and black UHF in it.
2.) Push correct tab into remote, and go to your main TV.
3.) Access System Information either with a remote, Sys Info button on front of receiver, or powering it off and pressing the up arrow.
4.) Press and hold the gray SAT button until all buttons on top light up. Release and while the light is blinking enter a number between 1-15 and press Pound(#)
5.) Press Record 3 times and check to see if the address changed to the number you chose. Verify remote works.
If you have any other questions you can let me know here; or at and I would be happy to see what else can be done!
Tommy Faust
DISH Network
Sep 05, 2011 | DISH Network DVR-625 DTV Receiver /...
Need remote tv code for 42 inch Vizio tv?
Hey there, Cheri Torres with DISH network Customer Service here. I came across your post recently and wanted to help. We have a few different codes for each of our different models of remotes. The model number of the remote will be located on the back of the remote on the top usually a 2 to 3 digit number with a decimal point. I will list here for you the more popular models of remotes as well as the instructions for addressing your remote to your TV. I hope you find this information useful and if you have any further question or concerns feel free to reach me at
Remote codes for Vizio TVs.
3.0, 3.1, 3.2, 3.4 IR remotes - 505, 671, 627, 520 and 766
5.0, 5.2, 5.3, 5.4 IR remotes - 627, 505, 506, 457, 111, 520 and 766
4.0 and 4.4 IR/UHF remotes - 505, 627, 555 and 766
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - 627, 505, 678, 825 and 520
20.0 IR and 21.0 IR/UHF remotes - 505, 598, 502 and 627
Instructions for address the remote to the TV.
  1. Turn the Television On.
  2. Press and hold the TV Mode button until all the mode buttons light up red.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button.
    Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
May 10, 2011 | DISH Network 625 Duo DVR Receiver...
Not all remote are compatible with all our receivers. Depending on the receiver and remote model numbers, if they are compatible you can readdress the remote to the receiver. I have provided a link for readdressing the remote to the receiver. I hope this helps.
Instructions on how to readdress the remote to the receiver:
Remotes and receivers models:
222 -
21.0 IR / UHF Pro
222k - 21.0 IR / UHF Pro
301 -
3.4 IR
311 -
3.4 IR
322 -
4.4 IR / UHF Pro
381 -
6.4 IR / UHF Pro
411 -
20.0 IR
501 -
6.4 IR / UHF Pro
508 -
6.4 IR / UHF Pro
510 -
6.4 IR / UHF Pro
512 -
6.4 IR / UHF Pro
522 -
6.4 IR / UHF Pro
612 -
21.0 IR / UHF Pro
622 -
21.0 IR / UHF Pro
625 -
6.4 IR / UHF Pro
722 -
21.0 IR / UHF Pro
722k - 21.0 IR / UHF Pro
Ray Calo
DISH Network
Nov 06, 2010 | DISH Network IR Remote Control
I have a DISH Network ViP722 DTV Receiver / 350-Hours Video.... Whenever I have my brightness setting below 40 on my LG TV, my Dish DVR will no longer respond to its Dish issued remote control. If I turn...
Hello! Daniel Busa with Dish Network. That would be a case of remote interference. You'll need a model 6.3 or 6.4 remote. You can set it to a uhf frequency instead of an ir that will correct the issue.
Aug 26, 2010 | DISH Network ViP722 DTV Receiver /...
Switch Toshiba projection tv to receive input from video-1?
If your DISH remote is programmed to your Toshiba TV, you can press the TV button at the top left of the remote and then release. This will put the remote in TV mode. Press and release the TV/Video button just below the clear TV button. This will cycle through the inputs on your TV. Continue to press and release until you have Video-1 displayed on your TV screen. I hope this helps.
Ray Calo
DISH Network
Jun 14, 2009 | DISH Network DVR-625 DTV Receiver /...
Dish network UHF remote works intermittently.
If you extend the small antenna that is on the back of the receiver by using a short cable and a barrel connector to get the antenna out of the entertainment center or out from the TV this will help alot
May 30, 2009 | Universal Remote Control DISH Network...
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
2nd remote has trouble changing channel
hook up a 6 foot peice of coax cable to the remote antenna port and then attach a barrel connector and then use a larger antenna "bunny ears" basically to extend distance of uhf signal for remote
Nov 27, 2008 | DISH Network DVR-625 DTV Receiver /...
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
