Question about Dishwashers
Blinking clean light on my Kenmore 665.17052400 7 times Did the "reboot" normal wash,heated dry sequence which made the machine work for a while. then it would go less times in between needing to be "rebooted", now it will not go through a cycle w/o the clean light blinking even following a reboot. what is my next step? I have heard that this means the microprocessor will need to be replaced. is it even worth it?
  • 128 Answers
No its about a buck forty but im sure you could do it your self
Posted on Aug 25, 2010
Tip
Thanks for the advice, it worked! For a few days I tried to cancel the blinking...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Sep 15, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
Clean light is blinking, when you shut door and push start cycle nothing happens
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Mar 21, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
The green light for "clean" is blinking green and
Kevin
Mar 07, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Clean light is blinking. Services manual says:
No all you do is press
Normal-Wash, Heat Dry, Normal-Wash, Heat Dry,Normal Wash, Heat Dry, Normal Wash, Heat Dry
Then all the bottons light up
Don't press anything wait a few minutes and it will work again
I know because today we just had this problem and did this from looking it up online,
Nov 22, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 66516032400 Dishwasher
On another website, we found a reset code that works for our Kenmore, which I think is the same as yours. Hit Heated Dry, Normal Wash, Heated Dry, Normal Wash (one at a time, within six seconds).
Dec 05, 2006 | Kenmore 24 in. 16032 Built-in Dishwasher
"Heater Circuit Malfunction" Kenmore 16033
Lynn, on the newer boards the key dance is heated dry-normal-heated dry-normal. On the older boards it was high temp-air dry-high temp-air dry. Don't know if yours has been changed or not..Catriver...post back.
Aug 28, 2006 | Kenmore 24 in. 16033 Built-in Dishwasher
Dishwashers Logo
48 people viewed this question
Top Dishwashers Experts
