Question about Garden
I have an Ariens GT18 mower with a single cylinder Kohler engine. The unit starts fine and runs well until it gets hot at which point it starts to miss and wants to stall. It also backfires when it is shut off after it is hot. Any suggestions are welcome. Thanks.
  • 3 Answers
Carbon build up in the engine, run some carb cleaner through it like seafoam and you might wish to consider changing the sparkplugs
Posted on Oct 28, 2010
I have a kohler 23 hp command vertical brother hit something stopped deck and engine but started back up and ran good next day motor started fine half way through lawn lost power and will start but no
valve seats have come out do to hitting something motor starts and runs fine the slowly loses power from super heating and finally stops wont restart until cools down right valve jobs per cylinder 150.00 each
Sep 15, 2014 | Garden
Kohler engine troubleshooting
Do you hear the fuel pump running? Is there gas coming out of the pump? Could be a bad wire connection to the fuel pump or bad ground connection.
Aug 03, 2014 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
I have a 214 kohler engine john deere lawn tractor, what point wires go to hot and the ground
if that is the Kohler 14 hp motor it may have the spark control untit on the motor cover. I recently ran into one like that and switched the coil out from a blown 20 hp kohler engine. I just taped up the excess wires and made sure they were not near any moving parts. The mower ran fine after that. Kohler wants about $160.00 for a spark control unit. There have been no repercussions since making the switch.
Apr 21, 2014 | John Deere Garden
Runs good for an hour then engine begins to sputter
Once it starts sputtering carefully pull a spark plug wire off (it can shock you) and see what happens. It sounds to me like you have an ignition module issue that once it gets hot it is grounding out and then when it is sputtering it is because you are running on one cylinder
Jan 02, 2013 | Garden
Will Turn-Over but won't start
Bad fuel,spark to plug would be first starting point. have you done anything under flywheel?
Mar 06, 2010 | Garden
I have a craftman lawn tractor with a 15hp kohler engine. Engines starts and runs fine After mowing for a while and then shutting it off the engine will not restart until it cool off completly. Any...
See if there as any difference in compression when the engine is cold verses hot. Also check ignition spark when it is hot. Unit could be vapor locking because of heat. Carb float could be suspect.
Sep 14, 2009 | Craftsman Garden
Garden Logo
267 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
