Question about Pride Health & Beauty
? Re: "Pride" brand Scooter -"Legend" model wigwag fault code is flashing. Has new batteries and lights, etc. all work. However, scooter will not move, and the fault code flashes. Any idea what the problem could be and the estimated cost of repairs.? Thanks so much.
  • 175 Answers
SOURCE: my pride IV scooter will not start I get a click
An 8-flash code indicates that the controller has shot craps. The controller is located under the shroud beneath the seat by the batteries and it controls all of the power and automatic functions of the scooter. They are damaged most often by water infiltration like running through deep puddles, etc. or by over-amping the scooter by driving it through unstable terrain like sand, mud, wet grass. There's no fix for it but a replacement and it's pricey...several hundred dollars.
Posted on Aug 28, 2009
gewiz
  • 1271 Answers
SOURCE: Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
Posted on Oct 01, 2009
gewiz
  • 1271 Answers
SOURCE: My Pride Legend 3 wheel scooter will not go
Hi, sounds like the speed pot that is attachment to the throttle lever is worn and needs replacing, this is normally a 5K pot,
Regards
GeWiz.
Posted on Feb 19, 2010
  • 228 Answers
SOURCE: I wanted to get a copy of a manual for the Pride
you can download from this site http://www.pridemobility.com/international/UK/ukownersmanuals.asp
plz rate me
Posted on Mar 09, 2010
Testimonial: "Brilliant and so fast. I am very pleased thank you so much. D."
wcdoc1953
  • 280 Answers
SOURCE: My wife's Pride Legend scooter
There a several solutions to this problem and all involve removing the seat and rear cover of the drivetrain. The brake and lever arm of the brake is located on the end of the black motor. Moving the brake lever up and down places the motor in freewheel or locks the motor/brake. There is a connecting rod from the brake lever to a ball that can be pulled up or down where it exits the back cover.
The connecting rod and brake lever may be bent making it difficult to work. Gently bend it back into alignment if you can. Be careful not to damage the brake and brake lever. The rod is easily reshaped. There is also a chance that the mechanism is binding and rusted or loose. You should be able to work the rod easily. See if you can move the lever right at the brake.
The more likely culprit is an overheated seized brake with the only solution replacing the brake. I have also seen the hexagon shaped nut which is secured by 2 set screws onto the motor shaft inside the brake housing come off. The set screws get loose and the nut gets lodged in the brake. Both of these solutions requires removing the brake with some allen wrenches after noting its position on the motor shaft. Hope this helps.
Posted on Nov 04, 2010
Pride colt plus mobility scooter light flashes 7 times battery fully charged frewheel lever in correct position and there is an audible continueous horn type noise but the scooter will not move
hi , 7 flashes mean the there is a issue with wigwag also known as the throttle lever now can you confirm the year of the colt please ?
Regards
Rob
Feb 08, 2016 | Pride Health & Beauty
Why won't my pride legend start?
The legend has a Curtis controller. The flash codes you provided points the problem to a faulty throttle pot. If a new throttle does not fix the issue, then your problem is the controller itself.
Sep 03, 2014 | Pride New Mobility Legend 4 Wheel Scooter
Sundancer scooter flashing wigwag code
The wig-wag can be tested with an ohm or multimeter. The wigwag plug must be disconnected in the tiller console or at the split-frame connector. Speed dial must be turned up all the way. Measure the wigwag with the ohm meter from the outer most tabs. It should read 5,000 ohms +/- 5%. Then measure center tab to either outer tab. When in "neutral" position it should read 2,500 ohms +/- 10%. If the wigwag is in tolerance I would have the batteries and battery harnesses checked next. Each battery should be charged and tested by a battery shop. These should be 12volt 18-35amp hour batteries.
If the batteries test fine then you have a wiring issue where a loose or corroded wire is dropping voltage under load. Sometimes these types of "bad" connections will cause the wire/connector to become warm or even discolor the connector/wire.
Best regards.
Mar 05, 2014 | Pride Sundancer 3 Wheel Electric Scooter
Wigwag fault code flashing on scooter..waht cause this problem and is it easily fixed?
The throttle potentiometer error code is caused by a damaged or worn potentiometer. The fix for this problem is to replace the throttle potentiometer. The part is available from Pride based on the model and serial number. Hope this helps.
Mar 18, 2011 | Pride Health & Beauty
I have a legend pride four wheel electric scooter. It does not run anymore. We checked the batteries and they are good and we charged them. We also went through all of the wiring and made sure the...
Hi. Is the machine display any fault codes, ( flashing battery light)? Is the free-wheel lever in the correct place, Move it in and back again and try it. It is possible that you have a stuck brush in the motor. Get a multi meter and check the resistance through the motor. Check that the brake unit is releasing properly.
If one of the battery lights is flashing, count the flashes and let us know what the pattern is, and we can tell you what it means. Good luck. Neil.
May 09, 2010 | Pride Mobility Products Pride Legend XL -...
Regards
GeWiz
Sep 23, 2009 | Pride New Mobility Legend 4 Wheel Scooter
The scooter will just stop and then start right back up. It has new batteries.
Most likely some intermittant fault condition is happening and the controller is cutting out. This could be overheating of the controller, a loose or corroded connection to battery, controller, control panel or motor, over-current in the motor or battery under-voltage. It may need someone to go over the wiring and connectors and checking everything is sound.
Aug 31, 2009 | Pride New Mobility Legend 4 Wheel Scooter
I have mislaid my Legend Classic XL8 manual & wish to know all the flash error codes
This page has a link to the users manual near the bottom:
http://www.cheapest-scooters.co.uk/8mph/pride-legend-classic-xl8-mobility-scooter.html
Aug 21, 2009 | Pride New Mobility Legend 4 Wheel Scooter
My pride IV scooter will not start I get a click
Aug 10, 2009 | Pride Mobility Products Casual CL20KD Lift...
Health & Beauty Logo
47 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
