Question about Samsung PCL545R 54" Rear Projection Television
Rear Projection Samsung w/ convergence out
My convergence is off on my TV and I need to know if anyone knows the Technician access code to the remote control in order to get into and fix the convergence. I have used the main convergence fix from the "menu" screen, but I know there is a special code you can push into the remote in order to fix the convergence at a much more specific level. Any help will be appreciated.
Thanks.
  • tcolonfam May 08, 2008
    Thank you, that code worked, and it fixed my problem.
I believe it is mute-1-8-3 to enter the service mode, HOWEVER, I have also read that until the convergence problem is repaired, i.e. - depending on the configuration, either 2 individual IC's located on the lower board with 'playing card' size heat sinks or a simple replacmenet convergence board, adjusting the convergence through the service mode is comparable to "ripping the transmission out of your car to fix a flat tire". I myself have not gone into the service mode since I am still waiting for the replacement IC's - I get to do a component level repair.
Posted on May 06, 2008
Tmtmail.co.ukmy samsung projection tv has double vision and i dont know how to amend the lens can yu please help thank you
double vision in a rear projection tv has several reasons. one is convergence magnets are out of tune. u need to tune them which is back side of picture tubes. u please observe that which color is producing the double vision. the lens are firmly fixed & therefore need not to adjust. other option is to adjust the convergence of tv by going to service mode by remote.
Sep 13, 2011 | Samsung Televison & Video
Convergence
It depends on what kind of convergence problem you got & what kind of universal remote you are using. If you mean aligning the crossline some
universal remote can be used to align the colors & on most TV you don't have to save it. Otherwise it will tell you what to do. If you are talking about aligning the convergence by accessing the service menu, you need the original remote control. Of coures this procedure is ONLY for the experience
technician. Good luck. AstroTech
Jun 02, 2009 | Hitachi 60DX10B 60" Rear Projection...
Technition secret code
To get to the convergence menu pressmute - 1 - 8 - 3 - power
Apr 09, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
Service code needed to complete convergence adjustments
I have the service convergence code: mute-1-8-3 (make sure your tv is on and set to antenna. if it doesn't work press S. Mode and make sure is says standard then re-enter code.
So, I have the code but I need the convergence chips. Where did you get the convergence chips?
Jan 26, 2009 | Samsung HCM653W 65" Rear Projection...
Where can i buy remote control for phillips 55pp9401?
get a full universal at your local walmart for less then 20 with full menu and program functions, get a phillips brand and no programming required.
Mar 16, 2008 | Philips 55PP9401 55" Rear Projection...
Digital Convergence Mode
Jou must hold in the menu button wille putting set on and press the code wile hulding in the menu button on tv.
Feb 23, 2008 | Philips Magnavox 9P6034C 60" Rear...
AUSTRALIAN PARTS
the convergence board has nothing to do with tuning of tv, the convergence board put three colour gun (red, green, blue) to work with each other, else you get three image, of red , green,  blue or mixture of all as seperate image, the convergence board for american tv and Australian tv is possibly the same what you check to see the board  part number is the same you possibly need to see if the convergence board has got the memory i.c. if that is the case, you need to tune you t.v reset the channel etc good luck.
need more help let me know.
Oct 09, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Need akai pt4799hd setup code
Do NOT attempt to enter the service mode to align convergence if you cannot align the convergence with the user's menu. If the convergence cannot be corrected with the user's menu, it means that one of your convergence IC's has burned out and possibly burned out the fuse next to it. If you change any settings without first replacing the bad parts, you will only make things much worse. I believe that set is actually a Samsung, and has the 2 convergence IC's on their own board mounted above the small signal board. If you do not know how to identify and replace shorted convergence IC's, allow a qualified tech to handle it for you.
Sep 03, 2007 | Akai PT4799HD Rear Projection Television
Samsung Projection TV
to adjust the convergence it mute 1-8-3 remember to hold the enter key when you go to write then pess the focus key the set will go into a auto focus and stop when its done
Aug 15, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung SP42W4HPX
The convergence wouldn't cause it to go all green. Green outlines yes but, not all green. Get a technician to look at it.
Mar 06, 2007 | Toshiba 53H71 53 in. Rear Projection...
Samsung PCL545R 54" Rear Projection Television Logo
172 people viewed this question
Henry  Thomas
Henry Thomas
