Question about Sony KP-51HW40 51" Rear Projection Television
The words are double and color running together
    Top Expert:
  • Sony Master
  • 14,553 Answers
Model indicated uses two of the STK-392-560 convergence chips--see attached photos.
Both need to be replaced and set adjusted with remote--fairly easy if you are handy. Total parts cost will on EBAY be under 25 dollars.
If this information told you something you did not know, rate this solution as very helpful as I do this here for free.
If you need help, I am here.
SD TECH
the words are double and color running together - 846cd5e.jpgCHIPS are located on other side of metal fins on heat sinks and should be STK-392-560--NUMBER WILL BE ON FRONT OF THEM.
Posted on Aug 25, 2010
  • 1 more comment
  • vjgun7 Aug 25, 2010
    I took the back off and decided not to attempt messing with convergence...put back on,turned on TV and it turned off in few seconds..What now?
  • SD Tech
    SD Tech Aug 25, 2010
    Hard to say unless you disturbed a plug or moved a wire---may be time for a new set?
    SD TECH
    Thanks for ur help..
2 Suggested Answers
hardrocko
  • 1476 Answers
SOURCE: colors are bleeding together and words appear
Your convergence ICs are about ready to quit working. Time to replace them. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to correct it and where to get any parts or tools you need. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Posted on Apr 03, 2010
Colors are bleeding together and words appear double struck. The picutre itself sometimes is double. This is an intermitent problelm, comes and goes.
hardrocko
Apr 02, 2010 | Toshiba 55A60 55" Rear Projection...
Double picture colors run together
Convergence problem. You need the 2 convergence ICs replaced by a qualified tech.
N Sabre
Nov 08, 2009 | Hitachi Televison & Video
Double image
In all probability you need to have the convergence amplifiers replaced. A very common problem with all projection sets.
Jun 02, 2009 | JVC AV-48WP74 48" Rear Projection...
The image of the tv not clear words are double
I just had that problem, need to replace the icg chip. but first get the remote the tv came with hit
menu go to the convergeance screen. try to put the lines together with that first. if the color
lines will not line up u need to replace chip. they r cheap
Mar 27, 2009 | Sony Televison & Video
Double vision on color only
I like the Tech Most likely did a Color Configuration , Go into the Menu and Use the Arrow keys to scroll and look for " Color Calibration " run the test make sure you don't have " Bleeding" this is a term used by Color Tech's like myself to describe that Color are mixing together which is causing your current problem.
Do calibration First.
Mar 09, 2009 | HP Color LaserJet 2600n Printer
Double picture & color problem
see if the mirror in side is broke or cracked
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
Double Letters-One in Green other Red in bottom corner
yes goto menue and goto convergence
line up all red blue and green cross hairs so thay are wite.
thanks.
daniel
Jan 13, 2009 | Akai PT4799HD Rear Projection Television
Double image
change color toner with original Hp tonars
Mar 16, 2008 | HP Color LaserJet 2600n Printer
Colors and Images
sounds like loose connections on the convergance amps ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 25, 2007 | Toshiba 65HX81 65" Rear Projection...
Double Picture
Goto menu and look for convergence control and realign colors.
Sep 22, 2007 | Hitachi 57G500 57" TV
Sony KP-51HW40 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
