Question about Vizio P50HDTV10A 50 in. Plasma HDTV
My vizio P50hdtv10a has major issues. I turn it on and i see lines, then it shuts it self off and i notice that the stadby /poer light flashes green/yellow. I replaced the y-sus board and the lines went away but tv still shuts off? help
  • jeremyparypa Aug 25, 2010
    i checked the capaciters and all look good. can i test the board somehow
    Can the power supply be tested?
  • Vizio Master
  • 11,800 Answers
The tv shuts off because the power source detects an overcharge on one of its exits and shuts itself down for protection. You need to measure the voltages at the exits of the power source to find out which is the faulty one. Once you will know that you should check the components from the power source that generate that power line - rectifier, filtering capacitors, coils and the stabilizer transistors (if present). Once you are sure they are in working order you must investigate the parts that line is powering.
Posted on Aug 25, 2010
  • 3 more comments
  • Azrael SRL Aug 25, 2010
    Yes, just use a voltmeter to measure the output lines and an ohmmeter to check for shorts.
  • jeremyparypa Aug 26, 2010
    It seems i have 5 volts going to the Y-sus board on a couple of lines and about three volts on the rest of them.
    Will the tv shut its self off if there is no inputs connected?
  • Azrael SRL Aug 26, 2010
    The high tension ~120volts is missing, find out why - but most like the ysus board has died.
    No, the tv will just display an blank image.
    The y sus , i allready replaced. So i sould have a 120v lead to the Y-sus board. Could the main control board be the problem/
    Yes, if there's a short in it that is triggering the protection - check the voltages there. If they are ok then the power source is faulty - check its components.
  • 4,889 Answers
Tv shutting off is due to a overload on one of the (5V, 9V, 7.5V) lines on the power board. A variety of component failures can cause this. If you want to go the easy way then a replacement power supply board should resolve your problem.
Sai.
  • 1 more comment
  • eagle338
    eagle338 Aug 25, 2010
    Yes it can be. But you are gonna need a service manual that has a proper schematic diagram. However I do not appreciate you voting me down as it affects my rating in a negative way.
    Sorry, i wasnt aware that i " voted you down" no harm meant. Can i fix that anyway?
  • eagle338
    Yes but Vizio service manuals with schematic are hard to find. I did find one that does not have the schematic, but it should tell you the location of the problem and possible components involved.
    http://www.servicemanuals.net/ServiceMan...
    I have also found a replacement power supply for 90 bucks(If you are interested) but I suggest you verify the part number if you wanna go for it.
    http://www.shopjimmy.com/vizio-3501q0015...
    Otherwise component level repair is fine with me.
Fix my vizio
I have fixed a few tv's that were flat screens and the problem is almost always a capasitor. They use the cheepest from china, look for a bulge on one on the power side although they are not always noticable.
Jul 31, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vertical lines on my vizio p50hdtv10a
If its one large line an inch or two you have a problem with the x boards. If its several thin lines multiple its going to be in your digital/main board.
Nov 21, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDTV10A 50 in. HDTV Plasma Television The picture started flashing in and out and then the picture went black. The power light is on, has sound no picture. only 2 yrs old
I repair a tv just like yours with same problem. I replace the x and y sustains boards. If you do replace them, please make sure it is disconnected from power outlet.
Aug 26, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
50" Plasma Vizio P50HDTV10A - no video - just flashing B & W
Don't replace anything, Vizio has issued a lifetime warranty for this set because of this problem. No joke, call the customer service line and tell them you got the pop of death. They'll send someone out to 'repair' the set free of charge. If they can't fix it they'll give you a new one. Even if your mfg purchase warranty has expired. Call them and post the results. I've been fixing TV's longer than I care to admit and this is the first time I've actually seen a company stand behind their products like this. I bought a broken tv with the intent of fixing it and after replacing almost every board I could only manage to get the vertical racing stripe line, except mine was purple. I put it all back together and called to find out if there was a recall on this set and within 5 minutes the (Actual English speaking) gentleman told me to sit tight and he'd have a repairman come and do his thing. He did, and long story short, he couldn't fix it. Last week they delivered a new TV to replace this one. I was shocked. I think Vizio will have all my future business.
Good luck.
Mar 17, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Line on screen
is the panel problem it cant be repair.
Aug 27, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
155 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
