Question about Garden
How to remove the impeller from a Masport Onga HJ200 pump to access and replace the seal between the pump and the motor.
  • 22 Answers
The impeller is screwed on to the motor shaft; to remove it you need to hold the motor shaft at the fan end so that you can unscrew the impeller - normal right hand thread. Holding the shaft can sometimes be quite difficult so a good suggestion would be to remove the fan cowl along with the fan, this will enable you to secure the shaft with a small pipe wrench or similar. Once you have the impeller removed it will be possible to ascertain what steps need to be taken next - you may need a new shaft sleeve as well as a new mechanical seal assembly.
Good luck,
Mike G
Posted on Aug 25, 2010
Pool motor leak
If you are asking how to replace shaft seal?
open & dismantle pump from motor. Some will have thru bolt motors all the way thru the motor, heads of bolts are (4 each) visible & accessible at back of motor. Loosen these & your wet end will be detached from the motor once the impeller is removed. To do this, block and prevent the shaft from spinning - normally there is access to the shaft which is located at center behind a cap at the back of the motor. Then unscrew the impeller from motors shaft.
Aug 17, 2012 | Hayward 1.5hp Pool Pump Motor Motor A O...
How is the pump seperated from the motor. I am replacing the motor only.
From this question I assume you already have a motor. Anyway, most motors separate from the pumps by first taking apart the pump and removing the impeller. Some impellers have a screw in the middle that have left handed threads. Once this screw is removed the impeller can be unscrewed by holding the motor shaft with a wrench and turning the impeller counter clockwise. To gain access to the motor shaft to hold it there usually is a cover at the end of the motor that comes off. When the impeller is off there are usually bolts that hold the pump to the motor. When reassembling the motor it is important to replace the ceramic seal and gaskets. I hope this helps.
Aug 06, 2011 | Pool & Spa
I cannot start pumping. the pump runs but no water is circulating
I think you have spun the center out of your impeller. Disassemble your pump and replace the impeller if necessary. Also replace all seals while you are at it.
May 04, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Onga ltp400 pump , unable to dismantle to change beariings
It's a matter of removing the main casing, impeller, diffuser, seal assembly, baffle, shaft sleeve, fan cowl, fan, motor end shield and rotor in that order - which part of this procedure are you having trouble with?
Jan 09, 2011 | Pool & Spa
Pump seal is leaking water. I removed the screws holding the pump together. How do I remove the impellor to get at the seal?
This is from one of my previous posts, may be some extra steps, but should cover what you need... Turn off the electric first. Now split the pump in two by removing the large clamp or 4-6 bolts holding the two halves together. (not the 4 bolts holding the motor to seal plate, but the the bolts holding the seal plate to the seal plate housing). Once you remove the clamp or bolts, the motor with seal plate, diffuser, and Impeller can all be pulled back away from the pump. Then disconnect the electrical from the motor and you can pull the motor with the seal plate, and impeller all the way out and work on it. To get to the impeller, you need to remove the diffuser (plastic housing that goes around the impeller) usually by a series of 3 to 6 small screws. To remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tail piece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under the thermal overload switch, or removing the capacitor for even easier access. Once you've locked the shaft, you can just unscrew impeller. If the impeller has a bolt or screw in the middle remove that first. this screw will be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. Make sure to replace the shaft seal, and use a tiny bit of pool lube on the rubber parts when installing, but keep the white ceramic, and black graphite surfaces 100% free of any dirt, grease, etc while working with them. Installation is pretty much just the reverse. Install half the seal into the seal plate. Install the seal plate onto motor and bolt into place. Install other half of seal onto shaft. Screw impeller onto shaft and install screw (if one was there to start with) in center of impeller (reverse thread). install diffuser over impeller make sure it is centered and doesn't rub the impeller hub. Install new diffuser and valute o-rings. Hookup wiring before re-attaching to rest of pump. Clamp or bolt back together. Pour plenty of water into pot to prime and flip the motor on for a sec or two. Pour some more water. Install pot lid. You should be good to go. Keep in mind there are many different pumps and some variations to the above instructions, but the above should cover most situations. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 03, 2010 | Dynamo ABOVEGROUND POOL PUMP - 1.5HP -
How do I remove existing motor and replace it with a new one ? Hayward 2.0 hp # SP2615X20 Thank you
Oct 02, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
How do you remove the impeller and mechanical seal off the pump shaft? I am wanting to change the main bearing that sits inside the motor housing of a Onga pool pump PPP750 model.
The impeller is screwed on to the shaft, you need to pull the cover off the end of the motor opposite the pump so you can hold the shaft to keep it from turning. The impeller should unscrew with just hand pressure, most are a standare SAE thread and turn counterclockwise to remove. Hope this helps.
Jimmy
Mar 12, 2010 | Hardware & Accessories
Plastic impellor sticks inside on onga pool pump and i can't get free .When i try with phillips head screwdriver it is jamming and i can't loosen to get impellor off and the pump only makes noise and can't...
Your Onga Pool pump was running dry causing the
impeller to melt down and stick to the pump case.
You have to remove the impeller, and the only way
to take it off by using the heat gun to melt the stucked plastic impeller. Or by forcing it off slowly, cutting the impeller using hacksaw, taking care of the mechanical seal and the motor shaft not to bend it. Afterwhich you can replace the impeller, and assemble the Onga pump/motor. Then, you can
install the Onga pump back to its location. Just
send you e-mail for further assistance. God bless
you.
Oct 20, 2009 | Plumbing
Onga jsp 130 leaks
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase
off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
Sep 07, 2009 | Plumbing
Water leaking
some times you need two people one to hold the shaft the other to turn impeller on you need to put in a vice wraped in a towel and not to tight or break it off and replace it to
Jan 24, 2009 | Pool & Spa
Garden Logo
871 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
