Question about Kingston 4GB Secure Digital High Capacity Memory Card
How to remove write protection from pen drive
  • 776 Answers
Posted on Aug 25, 2010
Hello ,i have problem with my 4 GB kingston pen drive. whenever i try to copy or delete something it gives me an error that 'The disk is write protected.remove the write protection or use another...
If you have just been taking the pen drive out without going through the "safely remove hardware" option then you have probably corrupted it. you could try the below technique, however, my feeling is that you will have to replace it and try to be more careful how you remove the pen in future.
http://techsalsa.com/solution-to-remove-write-protection-from-usb-pen-drive/
Jan 30, 2011 | Fuji (MAP3367NP) 36.7 GB Hard Drive
Tip
Removing Write Protection
Trouble:
In the past we had received so many problems from the readers who have a problem in copying files on their USB portable devices like pen drives, memory card and iPod etc.
According to the mails we had received about this problem, people have seen the following errors when their thumbs drives, memory card etc becomes write protected.
  • Cannot copy files and folders, drive is write protected
  • Cannot format the drive, drive is write protected
  • The disk is write protected
  • Remove write protection or use another disk
  • Media is write protected
Some times people say that suddenly their drive become write protected and they are not able to delete any files and folder on the drive and also not able to copy new files and folder to USB portable drive.
Let’s see how can you remove write protection on your portable devices like pen drives, memory cards, iPod and other USB mass storage devices.
Fix:
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button disablewriteprotection_thumb.png
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
In case you still find an issue, please leave a comment below.
Updated on 28th May 2009
After a lot of user comments telling that the above method does not work for them, we tell you another method which you can follow to solve the “Pen Drive is Write Protected” problem.
If the above method does not work for you, follow the below steps:
1. Copy all the important data from this drive to your computer because this method will format the drive and erase all the data on the pen drive.
2. Now download the Apacer Formatting Utility, Unzip this utility to a folder on your hard disk, preferably on a folder on desktop screen for easy access (Do Not Try To Save it on pen drive). Keep your pen drive plugged in, and double click on the Start.bat file in the folder where you unzipped the above utility. This will start formatting your pen drive, wait till the formatting completes and the LED on your pen drive stops blinking. Remove your pen drive after than and plug it in again.
The above two steps will solve the problem. If you still face the problem, follow the below steps:
1. Goto Start > Run, type cmd and press enter, this will open command prompt.
2. Type the following command on the command prompt replacing X with the drive letter of your pen drive.
CHKDSK X: /F
The above two methods will help you fix the problem.
Note: For all those who are out of luck in fixing the problem with their portable drives, I would suggest you to get your drives checked or replaced by the manufacturer to fix it for you
on Jun 19, 2010 | Computers & Internet
I have iball pen drive which has been write protect how to remove write protect
Sir I'm sorry for directing you to another site but you will rather undersand it better at this link i'm pasting http://www.troublefixers.com/remove-write-protection-on-usb-pen-drive-or-memory-card-or-ipod/ your problem will for sure will be resolved
Jun 19, 2010 | Electronics - Others
I have kingston pen drive 32 gb which is write protected .what i
The write protected message appears due to many reasons detailed steps to fix the issue can be found from the following link
May 28, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
WRITE PROTECT ERRORS IN PEN/FLASH DRIVE
Please open the link below and follow the instructions there to resolve the issue if the problem persist after following the instructions then pen drive is defective.
Feb 08, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Write Protected Problem
Hi Sir myself piyush gajera sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection. sir my email id is piyush_gajera147@yahoo.com kindly mail me as soon as possible. my Pen Drive is transced d33193. and it has no any stick to remove write protected. Thanks in advance. i have the same error while deleting or formating my pen drive My transcend 4GB pen drive when deliting data it ask to remove the write protection while formating the disk it shows write protected. when copying data it ask to remove the write protect
Jul 09, 2009 | PNY 2GB microSD Memory Card
How to remove write protection from my pen drive
Dear,
Just do one thing
Copy the data of Pen drive to PC and format the drive. Now paste the data back to the pen drive.
It may work fine onward.
Please try it.
Regards,
Rakesh Kumar
Apr 07, 2009 | Kingston 4GB Secure Digital High Capacity...
Remove Write Protection
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
Nov 06, 2008 | Transcend (589307) Media
Removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
Oct 31, 2008 | iLO (2 GB) MP3 Player
How to remove write protect from pen drive
I OWN A TRANSCEND pen drive of 8gb when i try to copy or format the command it shows is "cannot create,remove the write protected"what shall i do .the pen drive is very new
Jan 12, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Kingston 4GB Secure Digital High Capacity Memory Card Logo
95 people viewed this question
Top Kingston Electronics - Others Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
jairo sanchez
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
