How install xp in usb pen drive - Computers & Internet
    Problem Solver:
  • 4 Answers
Download the following files from Internet and follow the instructions bellow.
1. USB Formatter.exe
2. WinSetupFromUSB_0-2-3.exe
Instruction.
!!!!Set Up Intallation!!!
Note:
*If Required To format with HP Formatter use USB formatter and Donot Bypass the Instruction.
Note: When Formatting Choose NTFS ( this is the Most Important!
1.Install WinSetupFromUSB_0-2-3
2.Follow the Instruction
3.Browse the Source XP cd
4.Click GO. ( note: when making bootable USB! dONT Press or check anything just GO only )
5.Wait until System Process Finished.
*******Before Installation******
!!!!After Finished!!!!
1. Exit the USB.
2. Safety ReMoved!
******Final Installation for Setup*****
!!!Installation to your Netbook/Laptop/Desktop!!!
1. Insert to your Laptop or NetBook USB HUB!
2. In the BOOT SCREEN! bott from CD/DVD?USB. drive
3. Press Enter
***** the Screen will boot Dont Press anything let the program Run for Installation!!!
4. You will see that the System Prompt installing The PART - 1
Let System Continue and Donot Press Any KEY. until its. Finished!!
Enjoy.....
This is new Version for XP to make XP USB Bootable for your Netbook or any other computer..
Posted on Aug 25, 2010
My hpv165w 4 gb pendrive shows empety
Format the usb key with HP USB Disk Format Tool.
Then download Universal USB Installer (Pendrive Linux) which has support for booting/installing Windows Vista, 7, and 8
Mar 29, 2013 | PNY HP P-FD4GBHP165-EF BLUE HPV165W USB...
Tip
How to Install Windows 7 from USB Flash Drive
what if you don’t have DVD-ROM and you are running Windows XP, you might have guessed in this case we can’t install windows 7. Since Windows 7 ISO size is around 2.24 GB so its obvious that you will need to burn windows 7 iso on DVD and another issue is you can’t start windows 7 installation by mounting ISO file on windows XP as Windows XP upgrade to windows 7 is not allowed. In such situation installing windows 7 from USB pen drive is feasible solution.
Here is small guide on how to install windows 7 from USB flash drive or USB pen Drive for Windows XP users.
How to Install Windows 7 from USB Flash Drive Requirement:
USB Pen Drive (Min 4 GB)
Windows 7 ISO (32 bit or 64 bit)
MBRwiz Download and Extract it on your hard drive (Diskpart utility for Windows XP doesn’t detect USB drive as Disk hence we need to use this free utility to make bootable USB drive).
1. Connect your USB Flash Drive to your computer Format USB drive
2. To Format USB Flash Drive Go to My Computer -> Right click on USB drive and select Format from context menu.
3. Now go to Start Menu->run->cmd (Open Command Prompt) and Type following command
convert i: /fs:ntfs (Where “I” is your USB drive latter)
4. Mount Windows 7 iso as drive (You can use Freeware MagicDisc download from here).
5. Type Start->run->cmd
Now dir to directory where you have extracted MBRWiz and run following commands
mbrwiz /list (note down disk number of your USB Pen drive)
mbrwiz /disk=X /active=X (X is Disk Number of your USB Drive)
exit
6. Now open another command window and type following command
J: (Drive letter of Windows 7 iso mounted with demon tool)
CD boot
bootsect /nt60 Y: (Y is drive latter of your USB drive )
7. Now copy all files from drive where you have mount Windows 7 iso
8. Now reboot your computer and press F9 to get your BIOS screen and select USB drive as your boot drive.
9. If every thing goes fine, Your Windows 7 Installation should start from your USB drive.
on Jan 10, 2010 | Computers & Internet
I want to make my pendrive bootable to install window xp on my computer
download this file unetbootin-windows-471.exe, then you must have an ISO file of your windows xp, you can install ultraiso or any iso maker available on the web, insert your xp cd then make an iso image out of your xp cd... after having iso file for win xp, insert your pen drive (at least you have 1gig free space on your pen drive) then open unetbootin-windows-471.exe, under the disk image, locate your win xp iso file using the select disk image file button,. then just chose Usb Drive , and also on the drive chose the drive of the usb (check it on my computer and check the drive letter of your pen drive) then click ok... once successful transfer of image to the pen drive, restart pc then make your pen drive to be the 1st boot device
Dec 02, 2010 | Computers & Internet
How can i install windows xp to pen drive
Prerequisites
  1. A USB pen drive with 2GB+ storage.
  2. Windows XP (preferably a SP3, but not necessarily) ISO or CD.
  3. Batch files to write the boot record and copy XP files Download Here.
Perceptions:
From here on I will assume that you have downloaded the batch files and unzipped them and put the WinXP2USB folder directly in C drive so the path to that folder is C:\WinXP2USB and i will also assume that your USB drive letter is H. If these value differ in your system please change accordingly.
For steps to install xp using a pen drive please refer the link below:
http://dotnetwizard.net/tutorials/guide-to-install-windows-xp-using-usb-stick/
Please reply back if anything was not succesfull...
Regadrs,
Yateesh Varma.
Jul 31, 2010 | Microsoft Windows XP Professional
BIOS settings to boot from pen drive
HELLO BROTHER ITS VERY EASY TO INSTALL XP THREW PEN DRIVE PLZ CONTINUE THESE STEPS TO INSTALL XP THREW PEN DRIVE
STEPS:-
1.http://files.extremeoverclocking.com/file.php?f=197/</code>
CLICK ON PRIMARY DOWNLOAD SITE & DOWNLOAD USB DRIVE BOOTABLE TOOL
2. AFTER THAT ON THE ABOVE OF THIS PAGE CLICK ON http://files.extremeoverclocking.com/file.php?f=196/</code>
3. COPY XP FILES ON PEN DRIVE WITH FOLDER NAME(WINXP)
4. BOOT FROM USB
5. AFTER COMPLETE BOOTING U WILL SEE THE PROMP C:/>
6. C:/>SMARTDRV
7. CD WINXP
8. C:/WINXP>CD I386
9. C:/WINXP/I386>WINNT
10 NOW UR COMP START SOME FILES AFTER COMPLETING THIS UR COMP WILL RESTART
11. DOESN,T REMOVE UR PEN DRIVE BUT SELECT OPTION BOOT FROM HARD DISK
12. DONT FORMAT THE C: AND CONTINUE UR INSTALLATION AS A BOOTABLE CD
Apr 03, 2010 | Computers & Internet
Eee pc asus 904hd xp, corrupt registry
you can install windows XP from a Pen Drive/Flash Drive provided that your motherboard supports booting from USB drives.
Further detailed instruction can be found here.
http://www.troublefixers.com/solved-install-windows-7-from-usb-pen-drive-with-iso-image-without-cd-dvd-drive/
Oct 08, 2009 | ASUS Eee 4G Notebook
Hi i wanna install win xp via pen drive to my pc
Go to BIOS setup the do
first boot from USB Drive then Restart you system. then automatically boot windows xp from your pen drive. Do and enjoy with windows xp. For this you need to get a Bootable Pen Drive http://files.extremeoverclocking.com/file.php?f=196
Here is the Tutorial to Installing Microsoft Windows XP from USB
http://compupodia.blogspot.com/2009/08/installing-microsoft-windows-xp-from.html
Sep 20, 2009 | HP Pavilion dv6000z Notebook
Usb pen drive not recognized on my computer
My computer have USB port and windows XP but my pen drive is not getting recognized do i need an additional software in order to use pen drive
Jul 22, 2008 | Microsoft Windows 98 for PC
Computers & Internet Logo
169 people viewed this question
David Payne
David Payne
