Question about Philips HTS-3555 System
Unlock HTS 3555
Please,I need help for unlock my home theater Philips HTS 3555,because it´s set for region 1.
Thanks
Works very well for my PHILIPS home theater HTS3545 as well - semi
Posted on Aug 04, 2008
Press "Door Open"
- after the door opens perform the following sequence with the remote control:
Press STOP-7-3-4-4-6-6
a Region settings page will be displayed showing the current region on the TV (usually the default is region 1), using the remote control select the region number by pressing the number on the remote (select region 0 for region free) and press OK.
Posted on May 05, 2008
Unlock region on Philips HTS 3541/F7?
Unlock code for Philips HTS3541
1. Press Home
2. Press on R/C 8 6 8 9 3 1 0 (the 0 being multi-region)
Sep 13, 2012 | Philips HTS3541/F7 - 5.1-Channel Blu-ray...
I have a Philips HTS 3371 DVD home theatre and can not play many DVD's as it give wrong region error. Can you please provide the unlock code and how/where to enter it to get it fixed?
Hi -
Please follow the instructions below for unlocking your Philips HTS 3371
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
1. Switch the DVD player ON
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Regards,
BElectric
Mar 26, 2011 | Philips HTS3371D Theater System
Need a replacement remote control for the Phillips HTS-3555 system, where can i get a replacement remote control
You can buy required remote control for HTS-3555 from Remotes.com
Click above link to see required remote price info.
Thanks.
Sep 06, 2010 | Philips HTS-3555 System
How do i connect a xbox 360 to a philips hts 3555 and hd tv?
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
May 25, 2010 | Philips HTS-3555 System
The region is 4 and would like to watch all regions dvds Do you have the code to unlock my Philips HTS 3578w
Try this:
Switch player on
Press eject on the remote to open tray
On the remote, press 9,9,9,9 then 0
Region:0 should appear on the screen
Switch player off, then on again
Should now be multi-region
Credit goes to rimcius from www.videohelp.com
Jan 28, 2010 | Philips HTS 6600/12 Home Theatre...
I'm looking for the region cod, the Philips HTS 3544
TURN ON THE PLAYER
PRESS OPEN/CLOSE
USING REMOTE PRESS STOP-7-3-4-4-6-6
YOUR REGION AREA WILL APPEAR. PRESS "0" TO UNLOCK ALL.
Feb 09, 2009 | Philips HTS3544/37 Theater System
Unlock dvd player to play all dvd regions
I bought today a Philips HTS 8140 region 4 and i use this solution
1. Abrir a bandeja do aparelho / Open the tray
2. Aperte a tecla DISC / Press DISC buton
3. Digite o código 99990 / Insert 99990 code
4. Feche a bandeja / Close the tray
Jan 12, 2009 | Audio Players & Recorders
Region Unlock code for Philips HTS 3152
Thanks dude,
Not sure which trick worked, but i did ur classic 7,3,4,4,6,6,0 trick, got no message from the player. So i did pressed 0000 after that. Still no message appeared. But when i pressed start....it worked!!!!!!
Thanks a ton!!!!!!!!!!!!!!!!!!!!!!!!!!!!! God Bless...
Sep 23, 2008 | Philips HTS3450 System
Region code
I have a region Code For A Philips HTS-3544 which is 1 model Down. You can try it, it may work or it May Not.
Heres How:- power on the TV/DVD without any disk in the player.Press open/close eject.
Press Stop 7.3.4.4.6.6 ( on the Remote )
The menu code appears On The Screen.
Press 0 for region Free, or the region Code Required.
Power Off and then on Again, if the codes have worked, your dvd player is now region free.
If this works please rate as Fixya.
many thanks mike @ Compurepair.
Aug 28, 2008 | Philips HTS-3555 System
Unlock Philips HTS-3565
Hi
TURN ON THE PLAYER
PRESS OPEN/CLOSE TO OPEN THE TRAY
WITH THE TRAY OPEN, PRESS STOP-7-3-4-4-6-6
YOUR REGION AREA WILL BE DISPLAYED.
PRESS "OK"
Aug 20, 2008 | Philips HTS-3565 Theater System
Philips HTS-3555 System Logo
1,010 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
