Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
The refrigrater dosnt get cold its looklike the termostat not stop working
  • GE Master
  • 43,501 Answers
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><br />Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling<br /><br />Refrigerator not Cooling or Fridge not Cooling<br /><a rel='nofollow' href="http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not" target="_blank">http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not</a><br /><br />How to Defrost Refrigerator Defrost Timer Problem <br /><a rel='nofollow' href="http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer" target="_blank">http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer</a><br /><br /><br />Water Running in efrigerator from Freezer<br /><a rel='nofollow' href="http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from" target="_blank">http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from</a><br /><br />heatman101</span><br />
Posted on Aug 25, 2010
2003 chrysler 300 blowing cold air and no heat
Could be open termostat ,clog heating core.
Jan 29, 2013 | 2005 Chrysler 300
On A1996 Chrysler Sebring, How Can You Tell If The Thermostat Is Not Working?
Most of time the termostat will stick open
& in the cold weather you have little heat
when it gets to around 35 degrees
For a small number of unfornutate souls it
may stay closed & overheat & even ruin the
engine because they won't stop using the car
Other than putting it in a pot of water on the stove
to test it
Just install a new one every 6 or 8 years
Aug 03, 2012 | 1996 Chrysler Sebring
The refrigrater is not cooling off
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 14, 2010 | Kenmore 51562 / 51564 / 51569
My refrigrater is not working
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Nov 15, 2010 | Samsung Refrigerators
Heater doesn,t warm up forever the every time you stop it gets cold again
It's normal when you shout off your engine and leave it off for a while, check your heater cor, double check for antifreezer in the radiator, check termostat climate temperature.
Oct 28, 2009 | 2005 Dodge Grand Caravan
Blower motor not working any speed
Check for the busted fuse at the fusebox labelled
Fan. Hope this help.
Sep 23, 2009 | 2001 BMW 325
Compressor not comming on somtimes / freezer staying cool not cold / fridge cold
Turn the termostat to high, check the following morning. If unit is not cooling you need to replace the compressor. However, before replacing compressor make sure all the fans are working.
Sep 10, 2009 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Unit not coming on. air isn't getting cold
First check the breakers for the condensing unit (outside unit) and the disconect outside by the unit (could be a breaker ,a pull off/on switch or fuses)If its ok , you should have 220 ,240 volts to the unit contactor (you'll see it after removing the cover on the condensing unit).When the termostat is in the cold position and the temperature its set is lower than the one inside the house the contactor should be pulled in and give power to the compresor and the fan.But if the termostat is in the cooldest set and the blower inside the house works and the contactor in the condensing unit is not pull in the problem is in the termostat or in the low voltage wire.
Apr 24, 2009 | Heating & Cooling
Cold water freeze
you have to lower the termostat because is freezing the the cold water duct that happens when is cold or winter
Jan 01, 2008 | Soleus MW-55
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
