Question about Sport & Outdoor - Others
My swimming pool. I have just had my fifth IC 40 Intellichlor chlorine generator installed in 4 years at a cost of over $900 today. Each one has worked for no more than 8 months. The first three were replaces under three year warranty, the fourth by a factory rep and I bought the fifth today. The first three all failed with Flow Chk PCB error message. The fourth just stopped working on Sunday, no power or lights. A local Pentair warranty person, whom I paid a Service Call, unplugged the unit, opened the small power center cover, showed me the green light indicating that there was power, plugged in a new IC 40 which worked immediately (as did the other four). I asked if I should replace the power center and he said that it's basically just a transformer and is working fine. We do get occasional power blips that make the clocks on microwaves, etc blink, but I thought that the power center essentially isolates the cell from these. I do have a Florida Power and Light surge protector on the electrical box that brings power into the house. I have now talked to the pool builder, two Pentair warranty repairmen and one factory rep. I am at a loss. They all tell me they have no idea why these units fail after less than a year. This last IC 40 was installed 3/24/2010, version 2.0 and now failed in less than 5 months. Should I replace the power center that the IC 40 plugs into. Any other suggestions. I have been told that this is the best chlorinator. I don't want to keep replacing units. By the way, each unit had been spotless inside. I keep the water chemicals and salt levels at ideal levels. The units have never worked long enough to get dirty inside. The power center is connected to an Intellitouch control system outside with an indoor control panel. Last time I called Pentair North Carolina and got some smart alec tech person that had no suggestions. Please Help if you can.
I've had the same experiance. On my fifth one as well. Fail every year. No idea why.
Posted on Dec 23, 2012
muttandjeff
  • 359 Answers
SOURCE: York high effenciency furnace not firing all the time
has anyone worked on this furnace because the error would indicate that the positive 120 volt and the neg 120 volt is swapped , these units will also do this when the ground wire to the furnace or gas valve or furnace or @ the panel is lose , corroded , or missing , the gnd must be present to open valve , I am aware that ac is is not usually polarity sensitive but in this case it most certainly is ...have seen many time and know it to be true
Posted on Jan 01, 2009
thehumble1
  • 137 Answers
SOURCE: 1985 40 hp Johnson outboard wouldnt open up and
sounds like your mix is off and it's fowling the plugs. probably too rich. make sure the level in your carb bowls isn't too high. Really sounds like you should clean and bench set your carbs. Especially if a plug change helps but doesn't last, then it's got to be your fuel mix, or maybe timing.
Posted on Jul 24, 2009
  • 302 Answers
SOURCE: my dads new last year 7400 remington 30.06 simi-auto
I would recommend that you send it back to Remington through a local gun shop. They are excellent about fixing their new guns.
Posted on Oct 07, 2009
ruffintool
SOURCE: Gemmy light show lollipops not working right
The gemmy light shows are amazing when working correctly. BUT that may be for one season only. I bought the white trio set of Christmas trees after one season the trees turned brown, tried to get in touch gemmy. Two days later my reply was I improperly stored my trees. All the other set of trees I've seen turn brown after one season. As far as I know gemmy quit making the white trees. Long story short they did't warranty my trees, as for the lollipops 4 or 5 light systems aren't interchangeable, I tried to replace the led in my 5 light system with a led from a 4 light system the led worked but wouldn't sync. When trying to make repairs you must use parts from alike sets of the same year models, alike models from different years don't work. Also when changing led circuit boards solder the wires the way you take them off or you'll short the board out. If you have bad sets of lights you can make repairs if they are alike.
Posted on Dec 04, 2009
  • 905 Answers
SOURCE: Hello, I have a Minn Kota 440 4 Bank Charger. I
Hello Brad / Colee
The voltage converter in the charger has gone out (violently). Do not use this charger in your craft anymore. There is no longer any kind of guarantee of isolation, and galvanic corrosion may be accelerated if the boat is sitting in the water and you try to charge batteries.
Replace the charger. Your craft and your lives aren't worth the risk. You can try contacting Minn Kota to see if there might be some kind of warranty assistance.
Posted on Aug 31, 2010
How much of a cup is 20 grams of granule chlorine
check the links, but best by far is an electronic kitchen scale as grams is a measure of mass (weight) and a cup is a measure of volume.
chlorine dosage calculations and measurements pool volume
www.swimmingpool.com.au/ChemicalBalanceChart.html
  1. Cached
  2. Similar
40 x 20 x 5, 12.0 x 6.0 x 1.5, 110,000 ... CHLORINE DOSAGE CHART (This chart is a guide only)DOSE PER 10,000 LITRES ... Granular Chlorine, 80 Grams ... Tables I-1 and I-2 provide volumes in drops (dp), milliliters (mL), teaspoons (tsp), ... The values moving down a single column represent how many of the units at the ...
Chlorine to prevent swimming pool water problems - POOL WIZARD
www.havuz.org/pool_pool/pool_maintenance/water_testing/chlorine.htm
  1. Cached
  2. Similar
When planning to buy a test kit to measure the chlorine levels in your pool, it is ... Take the water sample from at least 20-30 cm below the surface and at least ... As a rough guide, a pool needs about 600 grams of granular chlorine (2-3 cups) ...
How many grams of granular chlorine does a cup hold - Answers.com
www.answers.com > ... > Categories > Science > Units of Measure > Metric System
  1. Cached
  2. Similar
280 +/- 5% ... many grams in a tablespoon chlorine? Approx 20 grams ... How many cups of granular pool chlorine in one pound? 2 cups. 48 people found this ...
How to measure chemicals??? - Trouble Free Pool
www.troublefreepool.com > Forum > Swimming Pool Care > Just Getting Started
  1. Cached
  2. Similar
May 26, 2013 - 7 posts - ‎3 authors I've been using a measuring cup but I assume when hth says 8 oz....they mean 1/2 pound. ... Ha, found the answer on this video, guess they do mean fluid ounces. ... Using CYA granules for example - if my measuring cup said 32oz, that is 2 lbs, correct? ... 8638 gallon 20'x52" Intex ultra frame round AG.
How to measure Chlorine Granules? - What's The Best Hot Tub
www.whatsthebest-hottub.com > Hot Tub Forum > General > Hot Tub Forum
  1. Cached
  2. Similar
Aug 9, 2006 - 15 posts - ‎8 authors My question is, since I only have a 100 gallon spa, and the Chlorine Granules say to add 1/2 oz per 500 gallons of water, how do I know and ...
how to convert 10 grams into understandable unit? ' Yahoo Answers
https://ca.answers.yahoo.com/question/index?qid=20100527135338AAbL0Np
  1. Cached
  2. Similar
May 27, 2010 - I have to put 10 grams of powdered chlorine in my kids swimming pool ... But you can't use a measuring cup or tablespoon to measure mass ...
Nov 15, 2016 | Computers & Internet
Tip
Solving Salt Water Pool Problems with The Chlorine Genie Chlorinator
Salt Water Pool Systems often are a consumer disappointment when users find out the problems, costs, and maintenance problems of this popular pool technology. Today's video covers some of the common drawbacks, dangers, and problems and offers resources for a solution.
on Nov 08, 2016 | Zodiac Lm3-40 Salt Water Chlorinator...
How can I reset my circu-pool salt generator? it is giving me a high salt light and a check cell light
I have a Circu-pool SJ45, no issues . Have you cleaned the cell. How old is unit. Have you checked pool salt level. Have not seen reset button, will look .
May 15, 2016 | CircuPool Swimming Pool Salt Water...
Is a saltwater swimming pool bad for you?
only if you live in it full time without showering in fresh water after .then you will get crusty.
Feb 13, 2016 | CircuPool Salt Water Pool System
Power and generator light are not lite
Main board is out and you'll need to call a professional or if your a DIY guy it's easy to fix
Jul 22, 2014 | American SPS Nexa Pure Natural Chlorine...
Salt water swimming pool
what is the actual size of the pool, and do you have a chlorine generator to use the salt? if so consult the generator mfgrs site for correct saturation of salt.
May 17, 2013 | Pool & Spa
Why is my swimming pool water cloudy?
Could be first signs of algae growth.
Check the chlorine levels.
Check the pH levels.
Jul 23, 2012 | Pool & Spa
Is a Hayward cl-100 ef chlorinator the right model to use for a 27 foot round above-ground swimming pool. I am having trouble keeping the chlorine level at an adequate level (dips too low) even with the...
The cl100 should do the job. The first thing I would do is check the chemicals. Make sure you have enough stabilizer (cyanuric acid).If it's low your chlorine will not last long at all. Check the ph and alkalinity also. Make sure you are running the pump long enough. the cl100 only adds chlorine when it's running.
Jun 05, 2010 | Hayward Pool Products 25 Sq Ft Micro Clear...
Sport & Outdoor - Others Logo
222 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
