Question about Cisco 7940 IP Phone
I need to replace a Cisco 7060 handset that has gone faulty, I can only get 7961 models, would this model work properly? or can the firmware of 7960 be able to support 7961 or 7962 ?
    Champion:
  • 331 Answers
The handset piece is interchangable. The firmware is NOT. The handset is simply the piece with the speaker and mic in it that you hold in your hand.
Posted on Aug 27, 2010
Cisco 7960 turns it self off
Do you have a power block for the phone or are you getting power from a POE switch via cat5 cable?
How do you know you purchased a working phone? When was the last time the phone worked properly?
Any other information you can supply about your VoIp setup would help us troubleshoot the power issue with your phone.
Jul 17, 2012 | Cisco 7960 IP Phone
Can i make calls with a Hide ID? cisco ip phone 7960 series
You will need to configure this through whatever SIP gateway you are using, it is not configured through the handset.
May 23, 2011 | Cisco 7940 IP Phone
Hello, I recently brought in a few Cisco 7961 VOIP phones into our office. The phones register when I first plug them in but when I pick up the handset to dial there's no dial tone. I tried swapping the...
You need to verify that the Cisco phones are obtaining the proper IP address from your DHCP server. You need to make sure that you create a DHCP Pool of addresses for the VoIP phones that you have and configure the DNS settings in the scope to point to your DNS servers and configure the router settings in the scope to point at the IP of the router. You may need to also configure the TFTP settings in the DHCP scope. Check the IP address settings on the phones that aren't connecting, if they are receiving a 169.x.x.x address then it is having problems reaching the DHCP server to get and IP address. Hope that helps to point you in the right direction.
Cheers!
J the Guru
Oct 15, 2017 | Cisco 7961G IP Phone
How can I clear / reset a Cisco IP Phone 7910
How to set a Cisco IP phone to factory default Reset configuration of Cisco IP Phone (7910, 1911, 7940, 7941, 7960, 7961)
To set the Cisco IP phone to factory default completes the following steps: should be completed:
For 7940, 7941, 7960, 7961 phones:
1. Power up the phone (unplug power cable and plug in again and hold the # key.
2. Release # when lights start flashing.
3. Press 123456789*0#.
4. Press 1 to keep network configuration or 2 to lose the network configuration.
For 7906G and 7911G phones:
2. Release # when MWI starts flashing.
3. Press 3491672850*#.
Oct 28, 2010 | Cisco 7910 IP Phone
How can I upgrade my frimware on the Cisco 7960, it is a 3 and needs to be 7?
Best and easiest way is to plug it into a newer callmanager. The firmware will be upgraded regardless of wether or not it is able to register.
Sep 02, 2010 | Cisco 7960 IP Phone
I have Cisco 7060 phone and using corded Plantronics headset plugged in to the headset port. I experience problem that speakerphone has priority over the headset. When I enter the phone number on keypad...
There is, but these settings are setup in Call Manager, or Call Manager Express. I would see your systems admin to set the default priorities.
Aug 27, 2010 | Cisco 7960 IP Phone
Detecting calls onm Cisco 7961
If the CS70 has a lifter attached to the cisco phone then it should be able to detect an incoming call by beeping in your ear.  If there is no lifter, it won't beep in your ear, but you will still be able to answer.
Apr 26, 2009 | Lands Phones
Is there an easy solution to repair noisy handsets on cisco 7900 series ip phones ie: a rattle in the handset itself. Do they come apart for tightening ????
The Cisco handsets will not come apart easily, and chances are you will snap the plastic on the first few you try. Replacement handsets are however reasonably priced, and then you've got a brand new one. We have these available for purchase at Idacom.
1-800-903-9190
Apr 25, 2009 | Cisco 7960 IP Phone
7906G Home VOIP installation Problem
Then you need power adapter for Cisco 7960 IP phone ( -40V DC).
Cisco phones work best with Cisco, and sometimes ONLY Cisco switches.
One question which voice gateway you will use for your 7960 VoIP phone calls to go through ?
(AT&T probably supports only their IP Phones with special and usually hidden settings from end user)
Jan 17, 2009 | Cisco 7906G IP Phone
Best Buy: Plantronics Problem
James, plug the phone cord that comes out of the back of the CS55 base into the handset port of the Cisco phone, not the headset port.  Then plug the coily cord from the cisco receiver into the front of the CS55.  Don't use the "Headset" button on your Cisco phone, just lift the receiver off.
Mar 21, 2008 | Plantronics PL-CS55 Wireless Headset
Open Questions:
See all Cisco 7940 IP Phone Questions
Cisco 7940 IP Phone Logo
88 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
