The fuse inside my phillips DVD home theater system keeps blowing fuses. I recently had a power surge and noticed that the fuse was blown. I replaced it with the same kind and now eveytime I connect the power cord to an outlet it blows the fuse again.
There is a short circuit in the power supply. either change the whole circuit board or it is probably just the heat sink moumted transistor on the board that has to be replaced.
Posted on Jun 21, 2013
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 61 Answers
Short circuit occur after the fuse,main power supply is the problem.please check the AC voltage before plugging.
Posted on Aug 25, 2010
Where are fuses located and how to tell if one is blown
Fuses are usually inside on the circuit board. A blown fuse is usually burnt, so it will be visible. If you are not sure, you can remove it at hold it up to a light. You should see a small wire inside the fuse. If it is blown, you will see a break in the wire. Keep in mind, a blown fuse indicates something is wrong. If it blows again, have it tested by a electronic technician.
Feb 04, 2016 | RCA RTD317W, DVD Home Theater System with...
Model No. PWR2006-37. Where can I buy a power supply?
Before rushing off to buy a replacement power supply, open your sub and check for a blown fuse.
Sep 01, 2015 | Philips Hts3450 5.1 Channel Home Theater...
Philips home theatre system hts35650 stoped working After switched off the power. How to fix it
Perhaps the surge strip has blown a fuse. Try plugging directly into a wall socket, bypassing the surge strip. If it lights up, then you know you have to get a new surge strip. In any event, it is most likely a fuse that's either in the surge strip itself or in the rear of your Philips receiver, near where the AC plugs into the chassis. All electrical appliances and devices have a fuse. Find it and take a look and see if you can ascertain if the nicad wire is broken inside.
Jan 08, 2015 | Philips Audio Players & Recorders
RCA DVD Home Theater System popping noise now wont turn on
if no any power indicator the first place to be check is the power supply where in the fuse get blow. if the fuse blown with darkened color that was mean has shortened line, might the amplifier circuit get damaged that cause of popping before it totally down.check for bad amplifier ic and shorted diodes.
Jul 26, 2012 | RCA Rtd315w Dvd Home Theater System...
POWER SURGE LAST NIGHT. SYSTEM NOW DEAD. IS A RESET POSSIBLE/
Hi:
You may have to at this point open the main unit and check your line fuse for blown condition. If found blown replace fuse with same voltage rating and ampereage rating.
Jan 27, 2011 | Panasonic SC-BT100 Theater System
There is no sound coming from the speakers on the SC-HT900 dvd home theater sound system. It used to make a loud pop sound but then would still work. Now it does not make any sounds. The dvd will play...
May be a fuse inside blown , if it makes a loud pop that can take out a fuse, If you find one blown , replace with same type and try machine .Dont replace with higher rated fuse though , if it keeps blowing. Try using headphones and if you get sound , may be speakers.
pete
Nov 29, 2010 | Panasonic SC-HT900 System
My sony receiver tuner wont turn on. It was working fine yesterday now it wont power up. The fuse near the plug wire inside is good. Any suggestions
Fuses almost never go bad something causes them to blow. Even when a blown fuse is found in electronics just t replacing it can cause more damage if something caused it to blow, a repair person looks for bad parts before replacing a fuse. Only microwaves are known to blow fuses and replacing the fuse fixes it. About the only thing that people can do is unplug a short time and try it again. And need i say is the power outlet ok.
Nov 03, 2009 | Audio Players & Recorders
No power to Insignia dvd player.
Pop the top of the DVD player and check the fuse. It's located right next to the AC power plug on the inside. If the fuse is OK, replace the DVD player. Repairs cost more than a new unit. Sony has DVD players from $ 40. Any repair on any device would cost more than that. If your lucky, the unit just took a surge and blew the fuse. Hope this helps
Oct 14, 2009 | Audio Players & Recorders
The unit won't power on at all.
You can try replacing it with any 10 amp fuse just to see what happens. If a new fuse keeps blowing out then you have a shorted power amplifier inside(they consist of transistor or a single chip). These device look normal most of the time short out with any visual indication. If you desolder the power amp chips(they are mounted against an aluminum heat sink to dissipate heat) and the fuse quit blowing then it is the problem.
Aug 11, 2009 | Samsung HT-TX72 Theater System
Unit won't allow me to change modes
If you're NOT still under warrantee you should at least open the reciever and look for a blown fuse near where the power cable enters the set. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the receiver to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your reciever serviced.
Jan 17, 2006 | RCA RT2380 Home Theater System System
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Electro Med Services...
