Question about Maytag Dryers
My old Maytag DE490 electric dryer won't tumble. How do I get inside to look at the drum belt?\r\n Does anyone know where I can get a repair manual for this model? Thanks
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other connections.
Remove the lint filter screws and filter.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Posted on Aug 25, 2010
Why does my Neptune moder number mce8000ayw dryer not tumble?
If the motor runs, but the drum doesn't rotate, check the belt, part # 341241. It's probably broken and off of the drum.
May 14, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Won't tumble. Drum won't roll. How do we open it
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 11, 2011 | Kenmore 62702 Electric Dryer
I HAVE A TUMBLE DRYER BECKO DRVS62W THE BELT HAS SNAPPED HOW DO I REPLACE IT. THE DRUM DOES NOT ROTATE MANUALLY IS THIS ANOTHER PROBLEM OR WILL THE DRUM ROTATE ONCE THE BELT HAS BEEN REPLACED.
If this is an electric tumble dryer,
the way to replace the belt is from the rear of the machine,
remove all the screws on the rear silver panel, which gives you access to the internals of the dryer.
And yes the drum wont turn properly if the belt is broken.
I hope this helps you.
If so please leave a vote or comment.
Have a great day
MobileJB
Jul 18, 2011 | Dryers
Where is the belt located?? This maytag legacy elec dryer is 4 yrs old. over the last few mths it has made louder sqeaky noises but now all of a sudden it stopped tumbling!! It still heats up like it's...
it is inside the dryer, you will need to disassemble the dryer here is a website that may help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
diagram of belt routing:
http://www.applianceaid.com/images/belt-config.JPG
Good Luck Tim
Feb 09, 2011 | Maytag MDE308DAYW Electric Dryer
L have a older maytag lde 410 the drum is hard to turn after the belt came off can you help us please
here is a descent website, Hope it helps Tim:
Oct 19, 2010 | Maytag MDE8757AY Electric Dryer
My COSTCO Whirlpool dryer SEDS 800 JQ0 heats but won't tumble.
There is usually a friction drive belt inside the unit that turns the drum. Check for a broaken belt or a defective drive motor. Usually it is just the belt.
Jun 20, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
Just moved, dryer won't tumble with a load. Error code PF
Did it get tipped in the move? I don't know about the specific model of Maytag, but on my old Kenmore the belt that ran the drum also had a wheel and kind of like a pulley that it had to seated on in order for the belt to stay centered on the drum and turn properly.I don't know how you get the shell off the front to get at the drum, the Kenmore had screws that you had to take out and lift the control panel off and then back to get at the inside. Sorry
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Stopped tumbling
First make sure your belt is broken.
Take a putty knife or a old CD and insert it between the top and the front panel about 2 inches in from the sides where the top and front come together.
Push the clips towards the back of the machine while pulling up on the top.
Once it is open you can tell if the belt is broken or not.
It you see no belt around the drum it is broken.
If you see a belt around the drum pull on it carefully.
If it does not come loose it is not broken.
After you do this, let me know the result.
We will then move on to step #2.
Mar 15, 2009 | Maytag PYE2200 Dryer
Dryers Logo
138 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
