Question about Raymarine St 4000 Wheel Drive E12093
Same problem as Beouffe17. ST4000 used to work fine, then for no apparent reason, all I get now is NO DATA. I don't understand what happened. Any suggested fixes? CnC@C
  • chris_for716 Aug 26, 2010
    tbreeze47 has offered a suggestion - possibly a defective cord. However, I'd like to know if there are other ideas out there to fix this "no data" problem. Thanks!
  • chris_for716 Sep 01, 2010
    Thanks Ginko! Sounds like a reasonable way ahead, so I'll give it a whirl!
    - CnC@C
  • 2,973 Answers
It could either be the connecting cable or the driver for this device. Uninstall and reinstall the driver with a reboot inbetween.
Posted on Sep 09, 2010
  • 19,396 Answers
Hi.
A defective data cable can cause the problem, however before replacing the data cable, cut power and remove battery if present to reset the whole system (the concept is draining per completely).
If that does not help, you can test the data cable using a multimeter on Ohms on the correspondent pin contacts in the two connectors on the cable. Id the connection is good there must be continuity (zero or low Ohms) between correspondent pins.
Posted on Aug 27, 2010
  • 3,083 Answers
No data would have to indicate a problem with the GPS input, I would think, although I've never had one of these. Check the cord, it could be defective. Couldn't find much technical info on these units on the net, but some parts aren't available anymore, so that's bad news. Anyway, hope this helps.
Posted on Aug 25, 2010
How to clear memory from dell 2400
i don't understand when u say it works fine but you need to remove old memory.... inside the PC, you will find the a green rectangle stuff near the processor fan. that is the pc memory. But if your referring the memory as a data, then the data is stored inside the hard drive. if you want to wipe all the data, u just simply format the hard drive. all the data will be gone. hope this will help you.
Jun 14, 2012 | Dell Dimension 2400 PC Desktop
02 AVALANCHE 606.000 RUNS EXCELLENT FOR 5 MILES THEN SPITS SPUTTERS STALLS RESTART FINE THEN RUNS SMOOTH PORRS LIKE A KITTEN
Do you have any OBD Check Lights on your dash?
Any stored codes?
Don't see the intake question,same,
worse,still has to be fixed
I would suggest you drive around with a mechanic
& have that person bring along a professional grade
scan tool or software & see what data shows up.
If that isn't done, there is a good chance you will be told
they couldn't find anything,that happens way too often
You don't get what you go to a repair shop for & they don't
seen to understand why your there.
May 07, 2012 | 2002 Chevrolet Avalanche
I just bought a Sharp Compet CS-2187 at a garage sale, but I don't understand all the switches at the top (e.g., DU CF/P.D, etc. I also am not sure how to set it so the decimal is always in place for...
Pam: I also have that calc. I also need instn manual for same reason(s). Works fine for 30 yrs old.
Did U get the User Manua?
Don deBruyn
daphrogue@bellsouth.net
May 31, 2011 | Sharp Office Equipment & Supplies
Loss of connection to internet for no apparent reason
Can you check if this happens without the router ? if you connect your modem directly does it still drop at times ? If not , see if you can update the firmware of your router. that could help
Thanks Ranjit
Oct 07, 2009 | Computers & Internet
The backup utility does not seem to work properly. I have a 40Gig drive and the backup function works as normal, but when I go to restore it says no backup data. I checked on my PC and there are five files...
In my case the problem was that the USB device did not re-mount after the PS3 restarted.
Try starting the backup restore process, removing the USB device sometime after the PS3 starts formatting, then re-attaching it once the PS3 finishes restarting. Wait for a while to allow the device to mount before you press the PS button.
Jan 21, 2009 | Sony Playstation 3 (PS3) Console
Kitchenaid mixer races when turned on
Hi. Get in touch with Kitchenaid Parts and order a new Control Board. If your mixer is still covered by warranty it's free. ricardok45
Dec 23, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Touchpad Not Working
If you has been installed the right drivers, it is hardware problem.
Try to use the factory touchpad program for your sony touchpad and see what happen (not only the driver, also the program touchpad software)
Oct 06, 2008 | Computers & Internet
Keypad problems
it's all about between key pad papper scrape i hope you will understand
Dec 17, 2007 | Nokia 6600
Raymarine St 4000 Wheel Drive E12093 Logo
109 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
