Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 desktop will not boot into windows xp home. I disconnected everything except hdd, keyboard and mouse. Same problem...will not boot into windows xp home. Did the recovery console thing.....copy ntldr, ntdetect.com, fixboot, fixmbr and chkdsk /r.....no joy! Computer was working according to the customer when he dropped it off, but I have no way of checking this. UBCD4Win will access the hdd and shows it has files on it.
  • blessings_co Aug 25, 2010
    Boot configuration is correct......as hdd (1, cdrom (2
  • 39 Answers
Im sure the boot sector is a mess. If the cd wont fix the boot sector you may have to copy all his personal files from dos and restore the computer to factory settings.
Posted on Aug 25, 2010
I have a dell dimension 5150. I was attempting to upgrade drivers, and appear to have lost use of keyboard and mouse usb ports. As I cannot do anything on computer without one or other, its impossible to...
Are your devices wired or wirelss ? Have you tried another usb keyboard ? You could try booting up the machine, then switching the devices to another usb port and hope windows will reconize them. Last resort would be getting a real PS/2 keyboard at thrift store or if your really stuck, boot with a live-CD then you should have mouse and keyboard to try to copy drivers manually over to the windows folder.
Sep 29, 2013 | Dell Dimension XPS 400 PC Desktop
Dell Dimension 5150. After bost my computer, I can the accounts icons on the screen, but I cannot slect the icon by mouse because all USB port did not work.
You can try this. On the log-on screen where you see your Account Icons try pressing ctrl alt delete. Some windows XP are configured that if ctrl+alt+delete are pressed on the lon-on screen the classic log-on screen window will appear, where you can type your username and password thus eliminating the use of the mouse.
Jun 20, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I need the usb controller driver for the dell dimension 2350 know where i can find it? thanks
The USB controller driver for Windows XP is a Native XP driver. If you have a problem with it, boot to the safe mode, go to device manager, remove the controller from list, make sure all USB devices are disconnected (Keyboard and Mouse excepted) reboot and let the controller re-detect.
If that doesn't work, then try a repair install of XP
Oct 21, 2009 | Dell Dimension 2350 PC Desktop
Dell dimension 5150 blinking amber lights
I have similar problem these days. After normal shutting down the PC, it can not be powered up again, the amber light blinks. A temp solution for my case is by doing these steps:
1. leave all monitor, network, keyboard and mouse etc. connected
2. disconnect the power, wait until green light and amber light dim.
3. pop up the CMOS battery, then put back in (better to check its remaining voltage, if not good, change a new one)
4. power amber light flash shorter and lighter
5. disconnect any USB connections like keyboard and mouse,
6. immediately connect keyboard and mouse back into USB ports
7. my pc powers up at this point, all green lights shining. Except it displays CMOS setup warnings, give me options to click either F1 or F2
8. I click F1, it goes into normal login XP
The only problem is I could not shutdown PC again, if I do, then I have to repeat 1-8. I have to use "Standby" instead, which I usually do.
Aug 31, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My Dell Dimension 4600 needs to be reformatted. The Dell reinstallation OS disk boots up and gets as far as "Windows Setup....press Enter to continue". Then it freezes. I have tried using both the original...
Before you go ahead and try reformatting the system , Please disconnect everything from the system (Except Mouse, Keyboard and screen)
and then try to use the disc to reformat the system. and if it still hangs up or freezes up that clearly seems to be a hard drive failure.
Hope this help.
Cheers!!!!
Jul 16, 2009 | Dell Dimension 4600 PC Desktop
Before I start my dell dimension 2400 computer up, I have to disconnect my usb mouse and usb keyboard because if I don't I will get these 2 errors, Primary drive 1 not found and Secondary drive 1 not...
The resolution for this is to go into the BIOS with the help of F2. Then look for the option USB Legacy devices. If it is enabled disable it or vice-a-versa. Also look for Boot from USB devices. Please disable that option. And select the first boot device to be the HDD (Internal hard drive)
Jul 11, 2009 | Dell Dimension 2400 PC Desktop
When I plug in ANY usb device, the computer freezes
Disconnect all external devices except the keyboard, monitor, mouse and network.
download a bios update from the dell support site. Update the bios, allow it to reboot. After you reboot, go back to the dell support site and download the latest chipset drivers for your system.
After you reboot one last time, that should do the trick.
Feb 25, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Can someone olease help me?
it sounds like your os in corrupt. re installing windows should help you out.
Oct 19, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Restore my dell dimension 5150
disable all integrated devices, change boot sequence to cd drive & then try to reinstall....
Jul 03, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell usb problems
the only thing i can think of is your usb support in the bios settings which can be accessed by pressing del button while the comp is starting that option should be enabled if that doesnt work i think your keyboard and mouse might need replacing i can't see all usb ports being faulty it's very unlikely jim regards
Aug 18, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
190 people viewed this question
Alun Cox
