Question about Garmin Edge 305 GPS Receiver
My garmin 305 (for running) will not shut off..soft reset just turns it back on ..the other buttons are frozen
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
Try hard reset, if not working, your device probably needs to go to support
Hard reset : device must be off (short press on mode plus lap/reset)
then hold mode and start buttons for 10 seconds, then pulse on lap/reset button
You'll loose all data, and go back to factory settings.
Before trying such solution you may try reinstalling last software from PC and USB cable
Posted on Sep 10, 2010
It does not turn or or charge. Connected to laptop but got same results. Tried to install latest software but it would not the unit (forerunner 305). Message was that there was no unit connected...
Here's a few options: Soft Rest
- Hold down MODE + RESET for few seconds
- Press the Power button to turn on the device
Hard Reset
(This will erase all of your data inside the device)
- Hold down MODE + RESET + POWER for few seconds
Firmware Downgrade/Upgrade (2.9 > 2.8 > 2.9)
(This will erase all your data inside the device)
Software Downgrade/Upgrade
- Connect your Garmin Forerunner 305 to the computer
- Press the UP arrow button and hold while doing all the other steps below
- Press MODE + RESET for a moment (the computer will recognize the device)
- Dowload the Firmware from Garmin's website.
- Downgrade Firmware from 2.90 to 2.80. (You are still holding on that UP arrow button!)
- When the update is finished the Forerunner 305 should power on running the Firmware 2.80.
- Let go of the UP arrow button, disconnect the device from USB, connect it again and the computer should recognize it normally
- Update the Firmware to the current version.
Nov 04, 2012 | Garmin Forerunner 305 GPS Receiver
Used my garmin edge 305 today on the ride, it worked fine, powered off after the ride. Got home turned on to review my stats and then powered off and went to upload and wouldn't upload, so tried to turn it...
Edge 205 or 305 often crash, then impossible to power on again.
Here is the way to reset the Garmin edge :
Soft reset : hold mode and lap/reset buttons for 10 seconds
Hard reset : device should be powered down, hold start and mode buttons for 3 seconds then pulse press the lap/reset button.
After soft reset, you need to hold start button for up to 10 secs before it starts.
After hard reset, you will loose all your data, including profiles.
Jan 30, 2011 | Garmin Edge 305 GPS Receiver
The edge 305 unit does not answer to hard and soft reset command
Just to be sure ...
Now if this does not work, you should check battery. Does the device charge when plugged on PC ?
If it does not, either battery is out of order or the contacts inside the device re broken. This may happen if device is used in continuous vibrating environment like mountain bike.
Changing battery or fixing contacts issue is explained there :
http://blog.mtbguru.com/2008/11/06/surgery-on-the-garmin-edge-305/
Jan 04, 2011 | Garmin Edge 305 GPS Receiver
My Edge 305s GPS is not working. Everything else runs perfectly fine, it just will not acquire any satellites. I tried a soft reset. It won't let me hard reset though.
Hard reset is not very easy, so follow carefully instructions above.
Now simple advice, did you check in your parameters that the GPS transceiver is turned on ?
There is a mode with GPS off, don't ask why ...
Refer to your manual to find the menu.
Nov 22, 2010 | Garmin Edge 305 GPS Receiver
Garmin edge 705 will not turn on
Nov 08, 2010 | Garmin Edge 705 Handheld GPS Receiver
My garmin 305 edge won't turn on. I had it for about 2 years.
Try soft reset first then hard reset if not solving.
Soft reset : hold lap/reset and mode key for some seconds
hard reset : hold on/off and mode, then pulse on lap/reset.
after soft reset, hold start button for 10 secs before device starts again.
May 15, 2010 | Garmin Edge 305 GPS Receiver
Turns on when I push the butten then shuts off
Try soft reset :
hold lap/reset and mode buttons for ten seconds, then release and wait 10sec, then hold start button for 10 seconds, device should start
Jan 11, 2010 | Garmin Edge 305 GPS Receiver
Garmin 305 is off and wont come back on.
You have to soft reset it first, and if not solving, then try hard reset.
Soft reset : hold lap/reset with mode key for some seconds
Hard reset : hols start and mode, then pulse on lap/reset.
after soft reset hold on/off for up to ten seconds before it starts.
after hard reset all data are lost
Mar 15, 2009 | Garmin Edge 305 GPS Receiver
My Garmin 305 has died
Did you try a soft reset:
With the unit in hand press and hold the mode reset and power buttons all at the same time. Hold these for 3 seconds and then release.
Nov 08, 2007 | Garmin Forerunner 305 GPS Receiver
Garmin Edge 305 GPS Receiver Logo
88 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
