Question about Casio Parts Cash Register PC Desktop
Im using TE2400 but i do know how to set table number into the mechine
  • Casio Master
  • 1,780 Answers
Hi. You type the table number, then press the NEW/OLD button, or sometimes it may have a NEW CHECK button. The machine must be set up for table tracking before you can use these functions. Your dealer should have set the MAC code for table tracking files, then memory allocation for enough tables, then the keyboard buttons required for tracking.
If anyone needs a TE-2200 or TE-2400 Casio manual, try here
http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Posted on Aug 25, 2010
Casio TE2400 program tables/checks.Tried to reset values back to 000's but now it is hung up and will not allow any entries keeps asking us to sign in but will not accept any clk no.
You can never set point of sale machines to zero, because it would encourage *****. I worked at a place where a manager thought he could just keep doing Z Readings until it came back to 71, and then it went to 171, and then to 1071. He was there all night trying to make his till reading balance with 70 from the day before.. He blamed the machine, auditors checked with company, he lost his job.
Sometimes you will find a reset button under the keyboard, but if not, you will need to contact the maker direct, or a service centre who service that make locally.
Nov 19, 2016 | Retail Supplies
How do i get a plu report te2400
Have you read the manual? If you do not have one, you can download it here:
http://totalpos.co.nz/wp-content/uploads/2012/10/Casio-TE2400-Operator.pdf
May 07, 2014 | Casio Parts Cash Register PC Desktop
Titan advantage sprayer stops pumping
Yes im sure you see you need to clean the mechine and all filters after each use if you ever want to work again
Apr 11, 2014 | Titan Advantage 100 Airless Paint Sprayer
I need to know how to get to Table Set on the TI-85 because I need to find the x intercepts on the graph, but I can't find it. How do I get to it?
try this one:
(first). Set up a function in the TI85. how?
Step 1. Press the [Y=] key to open the function editor.
Step 2. Type in the function you want in the Y1= line.
Step 3. Press [2nd] [QUIT].
(second). Create a table of numbers using the Y1 function.
Step 1. Press [2nd] [TBLSET] to open the table setup menu. On the line "Indpnt", highlight "Ask" and press enter. On the line "Depend", highlight "Auto" and press enter.
Step 2. Now press [2nd] [TABLE] , type in a value for "X", and press [ENTER].
Step 3. Continue typing more values for X to fill up the table.
(third). How can I see more decimal places for the numbers in a table?
Answer:
Step 1. Use the arrow keys to move the highlight over the number you are interested in seeing to more decimal places.
Step 2. Read the number at the bottom of the screen. You should be able to see anywhere from 9 to 14 significant figures for your number.
(fourth). Delete the numbers in a table by:
(The following procedure will work when the table setup has been set to ask for the values of the independent variable.)
Step 1. In the table screen, check the bottom of the screen to make sure that the cursor is not blinking at the bottom of the screen. If the cursor is blinking, press the [ENTER] key to stop the cursor from blinking.
Step 2. Use the arrow keys to move the highlight to the first number in the first column of the table (the "X" column).
Step 3. Press and hold the [DEL] key to delete the numbers in the first column of the table. The entire table should become clear with this procedure.
Thanks! I wish it can help you..
Feb 16, 2011 | Texas Instruments TI-85 Calculator
The blade it is not square with the fence?
I would go to managemyhome.com and download a manual for this tool. I used a table saw number and they have detailed instructions on how to align the blade. I used saw number 11329884. Let me know if you need more assistance.
Aug 29, 2010 | Craftsman 10" Table Saw
Im trying to repair my crafstman table saw model #137.248830. Replacing the armature but cannot get the gears to line up correctly am i missing something?
I would recheck the part number for the armature to ensure they have the same number and diameter of teeth. once you install the bearings this part should easily slide into the diaphragm and there is no alignment of the gears necessary. Let me know if I can be of more assistance.
Aug 06, 2010 | Craftsman 10" Table Saw
I need the wiring diagram for my 10 table saw, I disconnected the motor and the power supp. without marking it first and now i don't know which wire goes where, please help!!
Im guessing ... the motor is 110 volt AC (AC dont care if it is coming or going) ... find the two terminals in the motor and hook the wires back up. If it HAPPENS to be incorrect, the saw will run poorly or the overload will trip.
I wouldnt be afraid to use this method on my craftsman table saw.
Nov 02, 2009 | Craftsman 10" Table Saw
HOW TO SCAN THE DOCUMENTS IR4570 TO P.C ????
On the device you want to chose the SCAN option and set it to ONLINE.
You then need an application that does TWAIN scanning and aquire image data. Set your scanner device yo "Canon Color Network Scangear".
A freeware product you can use to test is irfanview
You would otherwise need to do an aquire / TWAIN scan from MS Word or Adobe Acrobat (full/pro) or another software that does TWAIN scanning.
May 06, 2009 | Canon imageRunner C3100 Copier
Need to change Baude rate of HP 4215 all-in-one mechine
1. Press the setup button (upper right corner of the fax machine)
2. Keep pressing the setup button until you get to the fourth option which says "Advanced Fax Setup"
3. Press OK to select the "Advanced Fax Setup" menu
4. Then using the left or right scroll arrows (below the OK button) scroll till you get to the sixth option which says "Fax Speed"
5. Press OK to select this menu item
6. Press the right scroll arrow till you get "slow" for the fax speed.
7. Press OK to accept this selection.
Then initiate a fax as you normally would.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 12, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Ti-85
It cant make a table. Sorry!
Feb 02, 2008 | Texas Instruments TI-85 Calculator
Casio Parts Cash Register PC Desktop Logo
115 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
