Question about Hitachi 55HDS69 55 in. Plasma Television
There appears to be a problem with the connection for the cable on my Hitachi 55hsd69 tv. The picture flickers and jumps around schizophrenically. This only happens for the cable input - I can play DVDs with no problem at all, so the screen itself is fine. I've tried swapping the HDMI cable used for the DVD and the cable - still no problem with the DVD, and still the same problem with the cable. I've also tried hooking up the cable box to another tv, and there is no problem, so it's not the cable input. Any suggestions? Thanks!
There is a firmware update for your tv..... this is the update unzip this link to your desktop and follow the instructions on the second link
http://www.hitachiserviceusa.com/Service/webtrain-software-Model.asp?sUserModel=55HDS69
here are the instructions
http://www.hitachiserviceusa.com/Service/Seminars/Plasma-Web/DW2-Web/Fixes/Software/frame-DW2-HDS-version-upgrade-software.htm
Posted on Aug 03, 2011
How can i fix my hitachi ultravision it has green and double vision on top of screen
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 23, 2014 | Hitachi UltraVision CineForm 55VG825 55"...
Picture on my Bose Lifestyle 35 is jumping around
Hi
Replied you on premium post as well.
Please change TV color system to AUTO to see jumping free picture.
If Bose is either on PAL or NTSC color system, TV will show correct picture and color automatically.
Feb 08, 2009 | Bose Lifestyle 35 System
My hitachi 42edt41 42in picture flickers
First. Try using a surge protector.
Could also try purchase a HDMI cable that is compatible with 100Hz,
Possible problems:
backlight inverter wearing out
Very Common In The Newer Tv Sets
Tv's have a chemical/molocules called phosphors that can be deentergized when a tv is left on for a long period of time. Not a serious problem but still annoying
Jan 16, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Jumpy picture
ck for dry solder joints if you take rear cover off and just lightly tap on convergence ic heat sink if the tv jumps then you have to remove the board and resolder the joints. also if you have a magnifying glass ck all solder joints on board when it is out
Oct 05, 2008 | Hitachi 50UX58B 50" Rear Projection...
Hitachi Plasma screen flickers
Got sound but the picture intermittendly flickers on and off. checked all cables and connections had the tv about 3 years now.
Thx
Sep 06, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Picture goes out when floor jars the TV.
Check for bad solder connections around where the tuner attaches to the chassis. Look for cracks with a magnifying glass solder should appear shiny with no circular cracks.
Feb 09, 2008 | Toshiba TP50G60 50" Rear Projection...
PS3 - Screen Flicker
You need to try a new HDMI cable.. Cheap HDMI cables do that? I had the same thing happen to me... I switched the HDMI cable and it fixed mine.
AV
Jan 14, 2008 | Sony Playstation 3 (PS3) Console
Picture Flickers and Jumps on start but is fine after warmed up...
Hawk, broken solder joints, boards will have to be partially removed from the set and re-solder all broken connections and you`ll be like new again, questions ? e-mail me back, BMW Rider
Dec 30, 2007 | Hitachi 50UX57B 50" Rear Projection...
Rear Projection... Hitachi tv
humm.. could be a crt or a high voltage problem..flyback transformer or high voltage splitter... have a tech check it out for you.
Nov 02, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV Flickers up and down and screen is shifted to the right w/ red color dominating the screen.
the last hitachi that had this problem i fixed it bad finding bad solder conenctions throughout the board that the convergance ic's are on, also i foind some on the two main board in my repair. hopefully resoldering the convergance foard will fix the jitter or jumping around problem. if the picture is too red you can also try turning down the screen control slightly. good luck
Jan 02, 2007 | Hitachi 51F500 51" Rear Projection...
Hitachi 55HDS69 55 in. Plasma Television Logo
211 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
