Question about Sony Ericsson K800i Cellular Phone
Battery charge is finished very soon without even using it( in about 5 hours)
    Novelist:
  • 173 Answers
The proper way of charging the battery on your phone is by waiting for your phone to indicate that it's running out of powe but not completelyr, if you frequently charge your phone even if it's not yet necessary(battery life indicator show half-way) the ability of the battery to store power will deminished hence the battery life is shorter. Last resort would be trying another battery unit to test if it's your battery of your phone that's causing the unsual battery drain.
Or you can try the following steps on conserving your phones battery life;
  • Turn off your Infrared and BlueTooth when not in use. Even when they are not in use, they do keep drawing power looking for signals.
  • Switch off the vibration alerts. Vibration causes a lot of power usage thereby making battery drain fast.
  • Re-adjust your screen brightness to around 50%. Screen power is another silent killer.
  • Usually, presetted Backlight durations are of pretty high order, this can be readjusted to get more from your battery. Try reducing the Backlight duration.
  • Often we don’t understand that playing games requires Light, Sounds and Shakes. This in turn leads to tripling of battery drainage.
  • Lower Ringing and other message sounds. This too helps saving a lot of battery.
  • Finally, do charge your battery before it gets drained fully. This enhances battery life.
Posted on May 05, 2008
Forcd Factory Reset
best learn the principles of your tablet first
first when a battery is less than 10% it takes up to 5 hours to recharge not 5 minutes
next many tablets do not recharge when in operation so you have to shut down to allow the recharge to work
because the battery was dead flat , of course it will reset as that is the same as removing or installing a new battery
Nov 11, 2017 | Polaroid 7-in. Internet Tablet - Other
When I plug in the adapter to the charge the consol the orange light lit. The light does not turn off even after 13 hours of charge. After 13 hours when I want to use it, the red light comes on not the...
Hello there. You may need to replace your battery pack, as leaving it charged for over 4 hours can lead to "overcharging" a condition which can dramatically shorten your battery packs lifespan and charge retention.
Also, be sure to charge your console while the device is turned off. Although you may charge it while it is powered on, it will take longer.
As stated, be sure not to leave the system on charge for more than 5-6 hours, as this can damage the battery and is liable to cause battery leakage, burning, or overheating.
Battery life is largely dependent on the game being played - some games can give you up to 10 hours of battery life, though the real-world estimate is really more like 5-7 hours of constant use before you'll need to recharge.
I hope this helps you. -
Frankie.
May 11, 2011 | Nintendo DS Lite Console
Battery runs down in about 5 hours without using
Hello, I have just published an article on how to save your battery life as I had your problem too. There are around 10 tips in my article to save battery life. Here is the link.
http://www.fixya.com/support/r4079271-tips_hints_maximise_iphone_3gs_battery
All the best
Jim
Jan 21, 2010 | Apple iPhone Smartphone
Battery is discharged very early even without use
Hello Sunil,
Knowing your phone's behavior, Its not usual that the battery if fully charged, will drain within the day, especially that you said even if it is not being used. I would highly advice that you avail the warranty of this phone since you have just purchased that unit. Do not rely on Nokia's customer service online. Go to the store where you made the purchase and avail the warranty. They should change the battery pack.
Nov 03, 2009 | Nokia N72 Cellular Phone
Battery meter is low, even though computer is always plugged in
Hi, I recommend you to try refreshing your battery by doing this step for 3 -5 times 1.Make a fully charge it take around 10 Hours. 2.Unplug your adapter and use the battery until it fully finish.Off by itself. 3.Repeat step1-2 for 3-5 times and see it again
Oct 07, 2009 | Acer Aspire 6920 Notebook PC
They charge gets over very soon,even replaced the batteries
Please provide the correct camera model. If it is the Sony model mentioned then it uses an Infolithium battery pack which is charged in a very different manner then the one detailed above.
If the model is wrong and you have regular NIMh batteries then charge them for atleast 10 hours if using 2100 mah or above
Aug 21, 2009 | Kodak EasyShare Z710 Digital Camera
HP PAVILLION DV6000 REPORTS BATTERY NOT CHARGING
Your battery is dead when it no longer will hold a charge. Replace your battery.
Jun 02, 2009 | HP Pavilion dv6000z Notebook
Battery Problem
Sorry this isn't a solution, but I wish my 8700 would last even as long as yours does. 2 hours, period. on or off, taking pictures or not, two hours & it's a stone dead battery. Just on the off chance it will help I'm about to upgrade the firmware to 1.3 (I don't really think it will help). After that I've decided to take the camera apart & try to find the problem or possibly just a hack that will let me turn it OFF without removing the battery. I'd as soon have a bunch of bits for the project bin as have to put up with this 2 hour battery life problem. Good luck with your problem, and if I find anything worth while I'll post back.
Sep 28, 2007 | Nikon Coolpix 8700 Digital Camera
SPS1 charging system
Borrow a multimeter and check the voltage (and current if you can) going to the battery while the unit is turned off. It should still be charging the battery if it's still plugged into the wall socket. If it is not getting about 13 volts, it's not going to charge the battery. If that's the case, then there's something wrong with the transformer, or another part of the charging circuit. The downside is you can't use the unit without the battery being connected. If the unit still works and sounds good even though it's not charging the battery, then just put the battery on a separate charger every week or so.(I use the SPS1 for my computer and love it!) Good luck with it. H.
Jul 30, 2007 | Scott SPS1 System
Sony Ericsson K800i Cellular Phone Logo
165 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
