Hi. i have a vermont castings radiance stove, RDV40. the pilot light went out and won't reignite. yes, the gas is on. i've followed the manual -- turning the control knob to pilot and pressing the ignition button -- but nothing is happening. there is no one in my area who repairs these stoves!
    Problem Solver:
  • 28 Answers
Check to make sure your pilot orfice is not clogged it will be located at the end of the small tube coming from your gas control valve if its not then while you are trying to light the pilot tap the side of the gas valve (sometims somewhat hard) if it then lights you know you have a bad gas valve
Posted on Aug 26, 2010
  • 3 Answers
I had a similar problem, here's how I fixed it.
1. Shut off gas.
2. Use 7/16 wrench and unscrew pilot gas line from BOTTOM (beneath the unit). Pull it down so you can see top.
3. Turn gas back on and push in pilot button.. does gas come out? If so, then you're pilot is plugged with dust or spider eggs or something. Continue steps below.. if not, then probably valve problem, get a new valve.
4. Shut off gas.
5. Remove logs. and the rear left support plate to access pilot unit screws
6. Take out pilot unit screws so you can access the pilot stack with your 7/16 wrench. (lift pilot unit slightly for this)
7. Remove the pilot stack.
8. Clean all passage ways. Blow out pilot stack, use a toothpick or paperclip to make sure it is all cleaned out... Make sure the thru hole down below is cleared, and clean and blow out the little cylindrical flow adapter piece.
9. Put it all back together.. Put adapter into place, screw down pilot stack, screw back in pilot unit, screw back in rear support, put logs back into place, push gas line back up into pilot, tighten pilot gas line back into bottom, put glass back on.
10. Light pilot as usual and it might work now.
Posted on Jan 08, 2015
Rnv40 pilot goes out
Sounds like you need a new thermocouple. here is the link to the part
http://www.ibuyfireplaceparts.com/model/radiance-rnv40-vermont-castings-gas-b-vent-stove
Apr 09, 2013 | Grilling
I'm looking for natural gas conversion kit for a Vermont Castings Radiance Model 2240 currently LP gas fired freestanding stove
Try going to www.ibuyfireplaceparts.com 1-888-634-4289..They deal directly with the manufacturer and would be able to tell you if a conversion kit is available and how to go about ordering it
Jan 25, 2013 | Kitchen Ranges
Looking to purchase new or used log set for radiance vermont castings stove model 2600 log set # 500-2933
I have a log set that came out of a Radiance Vent Free Stove. Not
sure of the part numbers. If you are interested, email me at
alis4@yahoo.com.
Marty
Oct 17, 2011 | Grilling
I have a vermont castings natural gas stove Model # RFSDV34RFN. I need the owner's manual.
You can download the Owners Manual for your VC Radiance Direct Vent gas Log Stove from Vermont Castings website starting on it's Home page. www.vermontcastings.com . Then click on Brochures, Manuals & Spec Sheets.
Feb 15, 2011 | Heating & Cooling
Need a replacement pilot assembly for Vermont Casting radiance 2600
When Majestic Fireplace Co, who owned Vermont Castings bankrupted, Monessen Hearth Sysems purchased VC. Parts are now available from Monessen Hearth System @
.www.monessenhearth.com
Jan 28, 2011 | Stoves Heating & Cooling
Pilot lights, main burner will not. Replaced gas valve, no change
I had a problem with the same stove,same model no. etc. Needed new valve. Will replace tomorrow, I will let you know how I make out.
Apr 06, 2009 | Vermont Casting VCS4017 (NG)
Vermont Casting Radiance Gas Stove (RUVSOD) NG to Propane (LP)
Unfortunaletly, due to the delicate nature of vent-free appliances, you'll find that most are not field convertable. If the vent free appliance were to lose its efficiency, you would be subjected to high levels of CO, carbon monoxide, and could likely die. Therefore, field conversion is not recommended and in this case, not possible. Vermont Castings does not provide parts to convert and if they did you would be essentially replacing the entire unit short of the outer cast shell. I wish you luck.
Dec 22, 2008 | Heating & Cooling
Heating & Cooling Logo
739 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
