Washing machine will not release any water - Washing Machines
    Genius:
  • 1,073 Answers
What is the model number
Posted on May 05, 2008
Lavamac front loading 28kg commercial washing machine(coin operated). When I press "cold" wash, why is the warm water coming out?
Your washing machine has to release some warm water even when liquid detergent is used. The purpose of the brief release of warm water is to dissolve powdered detergent and/or flush liquid detergent residue.
Jul 19, 2017 | Washing Machines
I have a bosch washing machine Maxx WF1200.The machines fills with water than stops. Nothing happens. Also does not spin to release the water. What is the problem?
If the machine heats the water and finishes the cycle without the drum turning it is most likely your motor or what controls it.
Sep 30, 2014 | Bosch Washing Machines
My moms pipes froze to her washing machine. They thawed and the machine filled with water but they won't wash. She can hear a buzzing sound like the machine is trying to wash the clothes but nothi
Yes , I think the valves also must have jammed in the process and when the hot water filled up in due course it must have released.
It is best to switch off water supply to the machine in such times.
Jan 23, 2013 | Washing Machines
I have a hotpoint aqualtis washing machine and the door is locked how can i release it
Most washing machines wont let you open the door if there is still water in it. Try putting the drain hose on the ground to drain the water out and try the door again. If its a front loader, there may be a drain hose or outlet next to the filter cup. Usually down on the front of the machine.
Sep 17, 2017 | Washing Machines
My washing machine wfs1273bw keeps saying clean pump, how do i do this. I have released the plug on the bottom right corner which lets water out but then it happens again....
Releasing the plug to drain the water won't solve your problem. Your washing machine has a pump that controls the flow of water. There might be an object like coins, or metal from your laundry that may have been included during the washing and is now blocking the pump. Try to unscrew the paddle that rotates during washing. By removing it, you can manually remove any possible obstacle that keeps blocking your pump that causes your washing machine to alert you to clean the pump.
Jul 23, 2011 | Washing Machines
I HAVE F -05 DOES NOT RELEASE WATER CAN YOU HELP
FO5 means pressure switch (9 water level switch) jammed on full.
Check pump filter and pump for possible blockage.
Pump and filter to be found at rear bottom right of washer, remove panel to gain access.
Please rate my solution.
Thanks.
Aug 09, 2009 | Washing Machines
Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine is not spinnig out the water
Does your washing machine spinning? if the washing machine is spinning and the water won't out, the release valve didn't open.
If the washing machine is not spinning, the fin belt broken.
Jun 27, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
