Question about KLH (AT2100) System
How do you connect a KLH home subwoofer to a home stero receiver
SOURCE: Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Posted on Jan 09, 2008
  • 9 Answers
SOURCE: My klh subwoofer has R&L
Yes, you use a subwoofer cable and hook it into the mono rca jack in the back of the sub. or you can use a Y splitter 1 female to 2 males. or if your amp has 2 sub outputs (L&R) then use both. I do believe it's said that if you use the high level input, it's better. I forgot why...
Oh yeah. the difference between the 2 is a high level input allows the currant from the amp to pass through the sub, thus allowing the continuation of wattage to your other speakers.
Low level input is only taking a audio signal from the amp. No power is being sen through the connection.
Posted on Mar 21, 2009
  • 547 Answers
SOURCE: i have a klh asw120 subwoofer annd a pioneer
On the subwoofer's L&R input, you'll see a tiny "mono" next to the Left input. Hook up your receiver's single sub output to this jack and you're all set.
Posted on Jun 15, 2009
SOURCE: KLH ASW10-120 Subwoofer My KLH ASW10-120
Did you ever find a solution for this problem? I have the exact same thing happening with my KLH subwoofer and I'd love to know how to fix it!
Posted on Jan 26, 2010
  • 3 Answers
SOURCE: I have a KLH ASW10-125C Subwoofer and a Harman
Home Theater
volume - personal taste - usually just high enough that you notice the bass - try turning down until you don't notice it then turn up one notch in the switch
phase - depends on distance from other speakers - try initially setting to 0 degrees
cross-over frequency - depends on your other speakers - try setting at 60-100Hz
Posted on Nov 16, 2010
How to install KLH asw10-20 to a 7.2 receiver
Yes, the 10-120 can use a L & R low level subwoofer input. You can get a short 6" RCA splitter adapter from Radio Shack for a under $10. (1 female input, 2 male outputs) Alternately, just plug the subwoofer output on your receiver to just the low level R channel on the KLH sub.
Jan 20, 2015 | KLH Audio Players & Recorders
Trying to hook up a KLH sub woofer, S100ETH, PSW8-100 to a VCR reciever. Reciever has sub woofer connection but does not works on the KLH sub woofer. What is the problem ?
I suggest you go over your receiver set-up instructions. See if you need to set the receiver to acknolwedge the addition of the subwoofer. It should be in your receiver set-up steps. Just as a check, hook up one of your other speakers to the subwoofer lead to see if gets audio signal. I'm guessing the issue is your receiver settings.
Jan 06, 2015 | KLH Audio Players & Recorders
Need a product manual for a klh 9906 home theater system with 4 satellite speakers a center speaker and a bassbite II
Try the KLH site. I have downloaded (for free) info on KLH products. Not much on technical stuff, but set up info and connections.
Jun 12, 2010 | KLH BB-II Subwoofer
What wires go to the subwoofer to connect to a sony receiver
hi you should only need 1 rca going from the sub pre out to your subwoofer inout.
some subs require a stero signal coming in and you may need to pickup a Y adapter at radio shack.
Jan 02, 2010 | KLH ASW8120 Subwoofer
I have a KLH 700watt home theater reciever that wont stay on!!
Sounds like it is overheating. Try one or all of the following:
Remove anything that may be stored on top of it. Unblock the vents.
Connect speakers with a higher sensitivity rating.
Move it to an area where it has more airflow around it, ie; not in a closet or cabinet.
Disable any bass-boost and equalization, or tone controls.
Set any crossover settings for any subwoofer you may have connected, to a higher frequency.
Decrease your listening volume.
Dec 30, 2009 | KLH R7000 Receiver
I have a klh asw120 subwoofer annd a pioneer receiver. the hookups behind the receiver has one output and the subwfr has a l & r input. does this need a y splitter or is there a certain way to connect...
Jun 09, 2009 | KLH ASW10-120 Subwoofer
KLH SUBWOOFER - RECEIVER-SURROUND SOUND -5 SPEAKER HOOK UP INSTRUCTIONS
Is sub out turned on on the reciever? Some have a setting that doesnt use the sub out, like 2 channel.
Jul 30, 2008 | Audio Players & Recorders
Connect R5100 to DVR/Monitor
use component audio to the HDTV and optical audio to your KLH reciever. The component and optical are always active at the same time. I work for TWC if you have more questions.
Apr 15, 2008 | KLH R5100 Receiver
Lost instructions
Jan 07, 2008 | KLH HT-9900 System
KLH (AT2100) System Logo
241 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Edwards
Michael Edwards
Level 1 Expert
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
