Question about ASUS F3SC-B1 Notebook
Laptop plugged in and not charging - ASUS F3SC-B1 Notebook
  • ASUS Master
  • 12,061 Answers
Ok, you MUST establish weather it is the battery OR charger,or maybe Both?
Now to see if the AC adapter is OK, remove the battery from the unit. Now plug in the AC adapter and see if the Unit will power ON, it should. if it does NOT, then you have a faulty AC adapter you will need to replace.
If it DOES works OK, then, turn OFF, and re-introduce the battery again, and plug the AC adapter in again, now, turn ON, & check to see if the unit is charging, go to power settings and check, it should be evident it is. If it is NOT, then you have a faulty battery, replace.
If you have nothing either way, then BOTH are at fault, replace them both. (Very rare)
Posted on Aug 25, 2010
How change cmos battery L5100
my laptop is no charge . the plugged in .when the plugged in laptop the laptop is running.when the laptop is plugged out the laptop is off .my laptop charging is 13%,
Jul 03, 2014 | Acer Aspire 5100 Notebook
Plugged in,not charging
I think your battery is faulty. Not charging anymore has reached his lifetime. Replace the battery.
Mar 14, 2014 | Acer Aspire Computers & Internet
When i plug charger samsung rv511 laptop its showing plugged in not charging .how to fix to fully charge
maybe the battery is full charged. run without plugging in that is best. pluging in and battery at full charge is not a good thing.
Mar 14, 2014 | Samsung Rv511
Laptop plugged in but not charging
Does the battery get hot when it is on the charger. Possibly a bad battery.
Sep 10, 2013 | Lenovo Computers & Internet
The proper way of charging nec computer laptop
insert the battery onto the laptop. Then plug the power cable to the wall and then plug it straight to the laptop. Its best to charge the laptop if it is shut down so that the laptop would charge faster..
Apr 29, 2011 | NEC Computers & Internet
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
My laptop won't charge when plugged in...I changed the charger but still won't charge
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
Or:
2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
Or:
2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
Feb 06, 2010 | Acer Aspire 5500 5570-2609 Laptop
Battery is not charging in my acer aspire 5052anwxmi
check connections and also try to get another battery and test for the same
May 30, 2009 | Dell Inspiron 1525 Laptop
I don't know how to charge my battery
Its ok. Um just leave the battery plugged into your laptop and the power cord plugged into the laptop as well and the laptop will charge it for you. If it won't, the battery is no good and get a new one but you don't need a external battery charger to charge your laptop battery.
Nov 21, 2008 | Dell Latitude D600 Notebook
ASUS F3SC-B1 Notebook Logo
77 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
