Question about Tomtom One XL GPS Receiver
Tom Tom XL
I`ve tried putting in a 2 gb SD card but no matter what I do, the Tom Tom ignores it and I can only fire up my device if I replace the original SD card that came with the device. I`m a trucker and want the mem increase to hold all the places that I visit. I am using a standard SD card and not an SDHC card.
  • 3 more comments
  • Kiwipete May 29, 2008
    Have added a 1GB card into TomTom and down loaded USA map into my PC and then copied it to Tom Tom, when connected to the computer it says both the NZ & USA maps are on the device but when I turn TomTom on I can only find NZ map
  • kv015 Jun 07, 2008
    What if the SD card, 2GB, has only 150 MG free? Is this enough room to copy the startup files so it will work?
  • genmanager Dec 28, 2008
    But not result pl halp me
    I have problem for loading of map from sd pls help me
  • georgettelam Jan 08, 2009
    why wont the memory card read in the tom tom one xl pictures and music
  • 515 Answers
The One XL can only read from internal OR sd card...
So, if you want the device to boot from the sd card, it need system files installed on the sd card...
So, try this:
- BACKUP !!
- Copy ALL content from internal memory to sd card.
- Insert sd card, and boot the device.
It should know boot from sd card, not internal memory...
Posted on May 08, 2008
My sd card came out of my tom tom, when I put it back in it is not reading the card.
its cause everything erases when you take out the memory card so put in the memory card in the tom tom and restore your tom tom orr update it and it will work again
Mar 18, 2011 | Tomtom ONE XL GPS
Device comes on but shows flashing X and nothing else.
The flashing X is usually asscosiated with a corrupt memory card or a pirate copy of a map.
if it is the later then restore the device from a backup to go back to your original map.
If it is a corrupt card then carry on reading below
This means it is not reading the SD card and that it needs to be re-formatted.
This is best done in a card reader and not the tomtom itself.
Right click on it and select format select FAT32 as the files system
Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now need to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
Then just copy ALL the files from the tom tom to your SD card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the SD card
It should now work
Bob
Aug 05, 2010 | Tomtom ONE XL GPS
Display reads problem with map
You now ned to select your tom tom which will also show as a drive.
Then just copy ALL the files from the tom tom to your sd card
Once all the files are on switch off the tom tom and insert the sd card
It should now work
Dec 20, 2009 | Tomtom ONE XL 330 GPS Receiver
GPS unit is stuck on the main screen, and wont turn off
It should now work
Dec 20, 2009 | Tomtom ONE XL GPS
Tom tom wont work after connecting to the computer
Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.
then just copy ALL the files from the tom tom to your sd card
Once all the files are on switch off the tom tom and insert the sd card and re-boot
It should now work
Sep 17, 2009 | Tomtom One XL GPS Receiver
Tomtom 1 v3 wont read new sd card help
Take special not of part 6
1. Remove the SD card
2. formatting is better done in a card reader.
3. Right click on it and select format select FAT32 as the files system
4. Now connect the tomtom but don't let tomtom home run. exit TTH if need be.
5. You now ned to select your tom tom which will also show as a drive.
6. In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
7. Then just copy ALL the files from the tom tom to your sd card
8. DO NOT USE CUT AND PASTE !
9. Once all the files are on switch off the tom tom and insert the sd card
It should now work
Sep 15, 2009 | Tomtom ONE XL GPS
I tried to put an SD card in my tomtom ONE XL and now it won't do anything...it is flashing what looks like a hard drive and there is a red X over the picture of a hand.
Remove the SD card
It should now work
Aug 26, 2009 | Tomtom One XL GPS Receiver
When I turn on there is only a cross over the SD card.
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
Jun 14, 2009 | Tomtom One XL GPS Receiver
When I switch on my TomTom, SD card has a red cross?
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card, Connect the device to your computer. Open the TomTom Home application. Click on 'Update My Device'. This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you update.
Jun 13, 2009 | Tomtom One XL GPS Receiver
Tom tom one xl wont accept SD card with map on
If you have TomTom that have the slot for SD card, then it should accepted the SD card. The instruction for how to use the SD card is simple, but it is hidden in the TomTom Home, that's why it's difficult to find it. Below are the instruction how to use the SD card.
1. Format the SD card (FAT32) and do not stick the SD in the slot yet
2. Run Backup (connect TomTom device to computer)
3. Disconnect TomTom from computer and turn off
4. Slide the SD into the slot and connect TomTom back to computer (choose "yes")
5. In the TomTom Home menu, Choosen Backup & Restore >>> and choosen Restore
TomTom Home will add all applications to the SD card. So the internal memory still have the applications and the SD card also had the same applications. Everytime you slide the card in, TomTom will automatic detect and use it as its primary storage, if it not detect, you can go to the device menu and pick the device to connect to.
Whenver you take the SD card out, then TomTom will use its internal memory.
Hope this helpful
Apr 24, 2008 | Tomtom One Europe v2 GPS Receiver
Tomtom One XL GPS Receiver Logo
406 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
