Question about Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharpaquos 32' TV model LC-32D44U WILL NOT STAY ON MORE THAN 30-45 SECONDS TV COMES ON , THEN SCREEN GOES BLANK FOR ABOUT 5 SECONDS THEN SHUTS OFF AND THE POWER INDICATOR LIGHT FLASHES GREEN I TRIED TO RESET THE TV TO FACTORY SETTINGS BUT THIS DID NOT WORK
  • Sharp Master
  • 12,061 Answers
This is a classic switchmode power supply, shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center, Sharp in your case, Now, this last point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
static.compusa.com/.../Sharp-LC-32D44U-LCD-HDTV-Manual.pdf - United States
Above is your user manual, and below is your service and repair manual should you wish to DIY, not really recommended, however I have included it for your convenience.
http://elektrotanya.com/sharp_lc32d44u.pdf/download.html
Posted on Aug 25, 2010
How to make picture on full screen
You have to go the menu of the tv and have to change aspect ration setting to 16:9. Here i have added the link the the manual of the tv which will help you to know how you access the settings.
www.electro-medical.blogspot.com
Sharp Aquos LC 32D44U Operation Manual
Sep 11, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My tv won't turn on, it will if i hold in the power button and will only stay on a few seconds, then flashes green
Bad capacitors on power supply board they will be vented or swollen on Top. 1000uf 2200uf 10v 3300uf 10v
May 31, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I want buy a power supply board
Unfortunately you might need to buy the same model of your power supply that comes in the LC-32D44U model. If this SMPS has failed try and check with some help with the link below before you contact Sharp service.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Mar 02, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
When I turn on my TV sharp model LC-32D44U turn on a 2 second on analog canal 2 than turn off and start a green led flashing ..
common problem for this particular model, one or more CCFL (backlight lams) falure. Lamps are not avalable as the replacement parts, only way to get them is to take appart bad/broken screen tv.
Oct 12, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp AQUOS LC-32D44U 32 in. LCD TV turns off after a few seconds
Its the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this help in solving the problem, take care
Sep 14, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Power blinking green light
Power supply section may be the problem, that will be the first place to look, look for caps with leaking/bulging tops, see examples of failed TV and monitors due to bad caps here;
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 13, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Mt sharp aquos 32D44U doesnt recognize any remote please help
Unplug the TV from the outlet, press and hold power button on TV for 10 seconds, release, plug the TV in. Enjoy.
Aug 18, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp AQUOS LC-32D44U 32 in. LCD TV Logo
295 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
