Question about Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
The motor runs (Milwaukee 1670 1 Drill) but the chuck does not rotate. This is true with both low and high gear. I suspect the gears are stripped but never had one apart before. I removed the top cover main screws but fail to be able to pull this cap off. How is this done. I do not have the parts or "How to Disassemble" book. Wesley Andrud.
  • 3 Answers
Hi, chances are the spindle driving the check is snapped. This is quite common. At the same time you might (probably) have some broken teeth on one of the intermediate gears and the narrow gear closest to the motor. I have just dissasembled three Hole hwags for a plumber friend of mine and they all have the same damage issues. The cover should come off fairly easily. Give it a couple of taps with a hammer to loosen it. The cost of replacement parts if the issues are the same is at least $100. Some of the spindles are more (the threaded ones) and will bring the cost closer to $170. remove all the grease as broken teeth will be hidden in there. The only thing I have not been able to find is proper grease to put back into the tool. Hope this helps.
Posted on Feb 24, 2011
Milwaukee drill makes noise but don't turn on outside
What model is the drill? Can you see into the drill through the cooling vents - if so, you should be able to verify that the motor is truly spinning (Armature, cool fins) or it's just making noise.
If it is spinning you most likely lost a gear from the Motor to the Chuck or the bushing that connects the Motor to the chuck (Every manufacturer is different) - Time to take the halves apart and inspect.
Sep 14, 2017 | Milwaukee Drills
Looking for a Milwaukee 48-66-1381 chuck kit with a 38-50-5075 spindle.
sure the age of the tool may have parts discontinued or superseded
this is a Milwaukee chuck kit you can buy
and a spindle on sale
try this Milwaukee parts supplier for a part or dimensions of the spindle/chuck you need
Milwaukee 1670 1 SER 472D Single Speed Hole Hawg Drill Parts 26309591-1jfwbypa2loxnuc0fythdbff-4-0.jpg
Oct 13, 2016 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
Milwaukee 1670-1 s/n: 472-18049. Purchased a Replacement 1/2 Drill Chuck Assembly Kit for 48-66-1481. It said it was for this drill.
According to a couple websites you needed to be looking at parts and diagrams for 1670-1 Starting S/N 472-17152.
The chuck you need is 48-66-1381 which replaces 48-66-1380.
The next serial number diagram that I could find was with starting S/N 472-19512, that too uses the same 1381 chuck.
I believe that the newer ones with serial 472B, 472C etc use the chuck you bought.
Oct 10, 2016 | Milwaukee Drills
My Milwaukee hd 18 pd drill runs but chuck doesn't,t turn it it possible to repair drill myself
Sounds like the gears are stripped. Go to eReplacementparts.com. Enter the make and model number.
Oct 08, 2014 | Drills
Chuck will only turn side to side after repair of gears box after
I need more information to answer your problem.
The chuck normally has movement turning because of the clutch gear.
It is possible if you had a gear strip or spindle break that there are pieces of metal in the grease that have jammed your new gears. I would recommend tearing down completely, remove all the grease, thoroughly clean gearcase, regrease & reassemble.
Nov 13, 2013 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
Chuck broke on my hole hog how i fix it
The back needs to come off, you need to remove the spindle, press it off the gear, replace it by pressing the gear back on and reassembling. You will need to have your serial number then go to toolpartsdirect.com and look up the parts diagram. It looks like the part number is 38-50-5076 which also comes with a new chuck. I just looked at the kit as I actually have one in stock.
Aug 16, 2012 | Milwaukee 1670 1 Drill 1/2 900 Hole Hawg
Drill works perfectly in gear 2, but its like gear 1 doesnt engage properly, it just rattles and doesnt rotate when it comes under even slight pressure
This sounds like stripped gears, happens if you switch the gears while unit is running. you have to disassemble and replace what is damaged. Not always very easy for a home repair, consider a tool shop for this task.
Oct 11, 2010 | Milwaukee Tool Milwaukee 2601 22 18V Li...
Milwaukee cordless drill 14.4 gears
usually you would remove the chuck first under my name in the profile section is the tip for chuck removal, it is a standard thread probably 1/2-13. As far as the gears go try the site Milwaukeetool.com and type in your model number for a parts explosion. Let me know if I can help further
Oct 29, 2009 | Milwaukee Tool Drills
My chuck would not rotate,(Porter cable 14.4V Hamm drill) but the motor would turn as normal as I pressed the switch. There was a grinding noise as the motor turned which I first heard when I attempted to...
It sounds like you were between gears. When you are in neither low or high, you are sort of in neutral. Normally it isn't a big deal. It happens to me occasionally, and I do what you did. You should be OK.
Jul 18, 2009 | Porter Cable 14.4V Hamm Drill Kit
Milwaukee 1670 1 Drill 1/2 900 Hole Hawg Logo
310 people viewed this question
Top Milwaukee Drills Experts
Jim Thurston
Mike
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
