Question about Samsung Digimax S730 Digital Camera
My samsung S730 digital camera is always blurry what should the F setting be in manual mode cause any mode i am in the closest view without zooming is very blurry
  • 17 Answers
SOURCE: won't focus
If the camera was dropped, it is possible that something was knocked out of place. That sounds very likely in your case. You should also make sure that the batteries are good. I have a Kodak camera that uses rechargeable AA cells, and they do not last long at all! Mine is a C-743, which has an actual viewfinder, though I suspect yours only has the LCD screen. Those idiots at Kodak think that cameras don't need those anymore, now that they have image stability programs. THEY ARE WRONG!
You may need a repair so expensive that you should consider trading it in for a newer model. These days it is hard to justify the cost of repairing a camera.
Back in the days of the Retina IIIC, Kodak sold some great cameras, and frankly I own two Kodaks now myself, a C-743 which is a pile of junk, and a Z-712 which I love. I believe that Kodak has some of the best image quality available on a digital camera, because they were one of the first camera companies to learn how to tame the contrasty CCD that actually takes the picture in these digital cameras....
Posted on Feb 10, 2009
  • 8 Answers
SOURCE: My Samsung S730 digital camera
Try to change the setting from manual config to automatic.....
Posted on Feb 16, 2009
SOURCE: Samsung digital camera S730.
Hopefully you have already solved this problem, but if not...You need the driver for the camera. It came on the CD that came with your camera. Insert the CD to install the program. Then you should be able to insert the SD card in a card reader plugged in via USB, or plug the camera in with the USB cord, or plug the SD card directly in your computer if it has the slot for it. Any of those actions should trigger Windows to ask you what you want to do. You can copy to your computer or whatever. If you lost the CD (like I did) look on the internet for Samsung S730 drivers. You can download them for free from several sources (even the Samsung site).
Posted on Mar 12, 2009
  • 5 Answers
SOURCE: When I am in photo mode and zoom, camera does not
Could be you are zooming in to much.
Posted on Jan 12, 2010
  • 11967 Answers
SOURCE: samsung s1050: camera lens blurry
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 03, 2010
I like to get up close pics of objects especially plants and scenery. The problem is when I zoom in the picture is always blurry and cannot focus on objects that are not far away. Is there anyway setting...
most cameras come with an option called macro,this setting is for close up shots.on your camera it needs to set at wide angle.when choosing the shooting mode move left or right and choose the icon of a flower.if you adjust the zoom, a zoom bar will appear at the top of the lcd.if you try to use a zoom not intended for macro shots the flower icon will gray out and the bar will appear yellow,if you take a picture with the yellow bar it will be blurry.if you zoom out a little until it stops you should be ok. if you use a flash in macro mode the images edges usually will darken.hope this helps.
Jan 08, 2011 | Canon PowerShot SX100 IS Digital Camera
How do I set the self timer on the Samsung S730 camera?
Press the self-timer button (right-arrow on the circular multiselector) until the desired mode shows on the monitor. Your choices are 2 seconds, 10 seconds, and double. Press the shutter release button to start the timer.
Full details are in the "Self-timer/Right button" section in the manual, page 27 in the edition on Samsung's web site at
http://downloadcenter.samsung.com/content/UM/200803/20080324103057703_English.pdf
Aug 03, 2010 | Samsung Digimax S730 Digital Camera
Samsung L50: I get a very blurry - near white image when taking pics outside. Inside the pics look ok, a little blurry though. Movie recording works fine. Help please. Tried changing batteries, reseting...
Check if you are using Auto settings. It seems you are using Manual (M) and the exposure time is too long for outside conditions (inside there is less light).
Switch the camera to Auto and it should work fine. Please let us know how it went.
Apr 11, 2010 | Samsung Genuine Digital Camera Digimax...
I have lost the manual for samsung s73 digital camera
Try this link:
http://www.dphotojournal.com/samsung-s730/
The download of the manual is found about half way down the page
Jan 06, 2009 | Samsung Digimax S730 Digital Camera
My Samsung S730 digital camera takes blurry pictures
Dec 12, 2008 | Samsung Digimax S730 Digital Camera
It became blurry
Are you using the auto function on the disc on top? If you are not it may be that your lens is open for too long.
I often get the same problem when using any other option as I'm not a pro, and when I zoom in very close on something far away.
Dec 06, 2007 | Samsung Digimax S730 Digital Camera
Card error samsung s730
I own a Samsung S730, i downloaded all the drivers on Vista Home, I tried formatting the SD Card but it says CARD LOCKED, and it isnt. Any solutions
Oct 25, 2007 | Samsung Digimax S730 Digital Camera
Help! My flash isn't working!
1 The flash- with the camera shut down take the batteries out. leave an hour. put them back in. Now - switch on and go to flash mode. Hold the camera to your ear.Can you hear a slight hgih pitched whine? This is the capacitor charging up. If you did not hear it then the flash unit is dead. But to be sure- read the manual and make sure you have set it up and operating it correctly. Blurry picture are something else[possibly] Check that you have not inadvertantly got the camera set to MACRO mode[this may also affect the flash inability. A good reread of the manual will do little harm and check out all those controls again.
May 19, 2007 | Olympus Camedia C-50 Zoom Digital Camera
Blurry pictures
You're both right. The pictures are blurry because the shutter speed is too slow, but it's too slow because there isn't enough light for it to be faster. Try this: Set the ISO to 800 Set the camera at shutter priority mode, and enter 1/160 for wide angle to mid-zoom, and 1/400 for full zoom. If the pictures come out too dark ( and you're too far to use the flash ), you can always brighten them on the computer. But if they're blurry, you can't really fix that.
Sep 11, 2005 | Olympus Camedia C-700 Ultra Zoom Digital...
Samsung Digimax S730 Digital Camera Logo
23 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
