Question about AO Smith 1 1/2 HP 115/230V 56C Replacement Motor
I look at the A.O. Smith Motor Master University manual and my question concerns the diagram on page 50, Single Phase Motor. In need to operate my motor with 115V and my understanding of the diagram is that I need to move the Black Tracker wire, from the capacitor, from Term B to Term A and the Black wire from Term A to Term L1. All otther wires stay the same: the Purple wire on Terminal A, the White wire on Term L1 and the Blue wire on Term1. Is this correct? To have both white and black wires on Term L1 and both Black Tracker and Purple on Term A. Nothing on Term B!!!. Any HELP?
    President:
  • AO Smith Master
  • 1,378 Answers
That is correct...if you have done that and still have problems post a comment that includes a description of what is happening and the motor model and serial number for further assistance.
John
Posted on Aug 25, 2010
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
How to change a 3 phase to single phase motor
You cannot change a 3 phase motor into a single phase motor because the windings are different in these motors. You need to buy a single phase motor to replace the 3 phase motor.
Sep 16, 2012 | AO Smith Pool Pump Motor Hayward Swimming...
I need a three phase wiring diagram for 8145-20 model timer.
8145-20 240Volt Paragon timer is not 3-phase.
Clock motor is 240V.
You need a transformer to convert 3-phase to single phase 240V to operate timer.
Then timer outputs can control 3-phase power using 3-phase contactors
Contactor below is 3 phase with 240V coil
http://www.grainger.com/Grainger/DAYTON-Contactor-2UTP7?Pid=search
Defrost timer wiring diagrams show below:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Dec 21, 2010 | Paragon 8145-20 Defrost Timer
I purchased a 60 gallon compressor from Lowes which has a 230 volt single phase motor,3450 rpm,15 amp. The model # of the motor is 7-194160. There is no wiring diagrm in the manual. I was wondering where I...
There may be a wiring diagram either on the body of the motor or inside the wiring terminal cover.
A.O. Smith can be contacted at 800-262-6484. If you do call, have pertinent motor info ready.
Nov 30, 2010 | AO Smith Air Tools & Compressors
I want to reverse rotation on my A.O. Smith 120/230 volt single phase 1.5 HP motor. Catalog number B762
I believe all you have to do is swap your two hot wires,that works for 3-phase but not sure on single phase
Oct 07, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
I need a wiring diagram for the Hobart H600 which has a multi tap motor on and i would like to change the voltage on the motor to 200volt single phase 120/208 or even 120208 3phase. The wiring diagram is...
You cannot wire a three phase motor for single phase and you cannot wire a single phase motor for three phase. If you have a three phase dual voltage motor your options are 220 or 440 volts. If you have a single phase dual voltage motor your options are 120 or 240 volts. A 208 volt Hobart motor will only function correctly on 208 volts and is not dual voltage.
Aug 05, 2010 | Hobart H600 Stand Mixer
Need to replace back half of a.o smith pool motoer
Do you mean A.O. Smith motor? This is the back half of
the Pool Pump. A.O. Smith motors are the most common motor drive for household pumps, so I believe
that you can easily find the replacement. Just specify
the horsepower (HP) rating, voltage: 220/110, single
phase or three phase. Just send your e-mail comment
for more info. God bless you.
Oct 21, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Jun 17, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
AO Smith 1 1/2 HP 115/230V 56C Replacement Motor Logo
228 people viewed this question
Top AO Smith Plumbing Experts
Lawrence Oravetz
Boyet Soriano
Boyet Soriano
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
