Sanyo Plasma Tv
TV was working fine screen went black no sound power light flashs 3 time green then flashs red
    President:
  • 2,712 Answers
There are several things that can cause it. You are best to have an expert technician come in and take some test on it in order to determine if it is from vertical blanking failure or something else. It is not easy to fix this yourself, if you have no experience, because there are a lot of parts that have to be removed before you can reach the components. It could be as simple as a loose connector ribbon or a bust capacitor, but it could also be more complicated. Hence, in my honest opinion, better get a qualified technician.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
Oct 02, 2007 | Panasonic TH-50PX60U 50 in. Plasma HDTV
When I turn on my 50" Plasma TV the light goes from red to green. The Green LED flashes 14 times then solid. There is a white raster but no picture or sound.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 16, 2015 | Zenith Z50P3 50 in. Plasma TV
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Plasma tv stopped working
hi i have a pioneer plasma tv pdpro4e all it doses is flash green red green red and on the mediar reciver as well tv dont come on help please
Dec 31, 2009 | Televison & Video
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
Power Issue 42" plasma flat HDTV Pixel Plus
you ip board is bad go t0 this site partstore.com typ in the modle of tv and buy it . works like brand new .trust mr it did and saved a lot
Apr 07, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Sanyo Plasma Tv Black screen
I've had the same problem main board went out it's a 100.00 part fixed myself.
May 03, 2008 | Sanyo DP42746 42 in. Plasma Television
Returns to standby
Green flashing 3 times = digital DC - DC converter fault
Red flashing 3 times = scan circuit fault
Oct 31, 2007 | Pioneer PureVision PDP-5040HD 50 in....
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
