Question about Cycling
How to adjust handle bars on a Mongoose Link boys bicycle
  • 128 Answers
There shuld be alen keys on the neck loosen to adjust then tighten
Posted on Aug 25, 2010
Adjust handle bars for mongoose bike
Just loosen the nut on the front of where the handlebars goes through, adjust it the way you want it, and tighten it up.
Jun 14, 2012 | Mongoose Cycling
I am wondering where I can order a back wheel for the mongoose 20 inch outer limit boys bike. Accidently got run over and is very bent. Thank you deb
Any Mongoose dealer or bicycle shop should be able to handle that or just web search for a 20" BMX wheel. It doesn't appear to be unique.
Sep 13, 2011 | Mongoose Outer Limit Boys Bicycle Pad Set...
Handle bars need to be adjusted up in height
You need to loosen the neck of the handle bars with a anlenwrinch.After that you will be able to adjust the hieght of the handle bars by lifting the top of them.
May 30, 2010 | Disney Cars 16-Inch Boys BMX Bike
How do you adjust handlebars on mongoose fsg?
There are two ways to adjust handle bars on a bike. It's either by using a hex key at the top of the neck or loosening the octagon nut at the base of the neck near the body.
May 21, 2010 | Mongoose 20-Inch Gravity Games BMX...
Loose handlebars on a Mongoose XR-75 mountain bike. I tried to tighten them but they still are loose. Help!
Check the splines on the handle bar. Just loosen the "clamp" and slide the bar over to one side enough so you can tell if the are stripped or not. If they are then replace the bar, if not then reassemble and try to put a littlle extra torque on the bolt.
I have noticed with the 2 of these bikes that I have that the bars do not like to stay tight for long, they tend to work thier way loose about every other time we use them. I just keep tightening them untill the splines strip, then pick up a new bar.
Contact Mongoose for parts info at: www.Mongoose.com under "about" click ask mongoose.
Good luck.
Apr 04, 2010 | Mongoose MGX Maxim Dual Suspension...
Mongoose Handlebar adjustment
where the bars slide into forks there should be a allen nut on the top undo this slightly and adjust bar height then tighten up allen nut
Apr 03, 2010 | Mongoose Exile 26 Men's Full-Suspension...
How to attach hand brakes? how do i loosen handle bars to adjust?
The bolt you see right above where the handle turns is the handle bar clamp. And if it's been on a while you'll need to take a piece of strong wood and hold it on the bolt, when it's lossened a bit, and hit it with a hammer to fully loosen the handle bars.
Hand brakes should come with clamps to put on the hadle bars, and if you look at bikes that have hand brake, you'll see how to route the cable. The only problwem is if your bike doesn't have the part taht the brake would screw to at the wheel. Then you'll have to improvise.
Dec 22, 2009 | Mongoose 20 in. Boys Axe Bike
New mongoose 20'' bmx. trying to adjust the brakes???
undew the screew at the back of the breakes and turn them round slightly so the wheel in midlde then tighten back up should stay in midle then just not put on straight thats all mate
Jun 18, 2009 | Mongoose Menace Street Dirt BMX Bicycle
Broken cover of handle bars
call mongoose at there # an the link below. They might beable to get you the part.
http://www.mongoose.com/usa/eng/bmx/ask_mongoose
Dec 27, 2008 | Mongoose 2008 CX200
Cycling Logo
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
