Question about Asko 24 in. D3530FI Built-in Dishwasher
I get a water outlet fault message on my asko d3531 dishwasher...water is filling at the bottom of the dishwasher and will not drain.
  • 351 Answers
SOURCE: Dishwasher Asko D 1776
you may need to reset the inlet time on the board do you have the instuction book,turn the power on then press the fifth button five times within 15 sec then press third button normal wash this should fix your problem
Posted on Apr 09, 2008
  • 14 Answers
SOURCE: Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
Posted on Jun 19, 2009
SOURCE: Asko D3100 dishwasher wont drain completely
I think I see the problem based on "futureloginn"'s highly rated solution. You have a dishwasher. You need to stop washing clothes in it.
Posted on Aug 21, 2009
  • 7 Answers
SOURCE: Asko Dishwasher Model D1716B Does not fill
Have an Asko 1325 that experienced similar scenario. Removed the unit from the kitchen to the outside to do a thorough exploration. After all a dead machine is a good one to learn on. With the unit electrically disconnected, I explored within the lower guts of the machine. Found some foreign plastic debris within the turbine. Then wigled and removed each electrical connector and reconnected back. There may be corrosion within the contacts. After this procedure I test ran the machine on the outside and it worked.
BTW a common defect with the Asko is the electrical wiring leading up the main door panel, from below the machine. The wires are typically too short and the metal edges of the unit are razor sharp. You guessed it, wires become cut and cause an electrical short at best, or a fire at worst. See the photo for proof by practice. This is why an Asko can be a fiasco. b84ee89.jpg8bbfcfc.jpg
Posted on Sep 01, 2009
cukin
SOURCE: Asko D3450, Stops with flashing
water level switch is no operative..i have same problem 5,6 months ago ...
regards Peter
Posted on Feb 15, 2010
Testimonial: "Problem was described clearly."
Getting an F4 fault code after about 1 -2 minutes of operation. There is actually water in the bottom of the unit. Have put a vacuum on the inlet feed tubing and also have blown compressed air through the...
Hello & Welcome to FixYa
F4 error in your Asko Dishwasher is a water fill fault and this indicates and over fill fault. To check and solve this problem please follow these steps:
1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray
Please get back to me if you have any other questions.
Kevin
Jan 01, 2011 | Asko 24 in. D3350 Dishwasher
Overfilling fault
I believe the washer has had a flood type situation.there is normally a flood switch in the very bottom of the dishwasher right at the very floor,if water get into the bottom tray it floats a piece polystyrene foam wich triggers a little micro switch wich will run the pump continually & show Overfilling fault at the same time..The water in the tray needs to be mopped out with a rag or spunge so that the styrene foam can drop back down.The blockage you had may have caused this flood situation some how.The overfill fault was probably due to the washer not pumping out,So that may be ok now that you have cleared the blockage.hope this helped.
May 13, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
Our Asko D3250 dishwasher is brand new, and it fills up and drains and fills again and then the water inlet fault flashes. It doesn't go past this point.
this sounds like a improper install ! ck to see if the drain hose outlet is lower than bottm of tank. it should drain to the disposal . and have a drain loop under sink .. the dw prosser is sensing that the drain is longer in time so it flasher inlet fault . . elevate the drain and try again ..if it drains to a lower use a stand pipe or a siphon brake . in the install .. mm
Dec 03, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Asko 1350 fill problem.
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve if found to be defective.
Now, if the valve is ok, replace the control.
In most cases, this will be a control fault.
Jun 21, 2009 | Asko 1385 Dishwasher
ASKO dishwasher
F2 fault water in the base remove dishwasher from under the bench and tip back water will run out,then it will restart.remove rear lower panel and run the dishwasher you may find a leak,also check that the inlet valve is shutting off and not filling the dishwasher up overnight.hope this helps.
Mar 27, 2008 | Asko D1776 Stainless Steel Built-in...
ASKO 1475 Does not not pump out and drain at end of cycle.
If dishwasher drains ok into bucket then fault is with the house plumbing
Jan 19, 2008 | Asko 24 in. D3250 Built-in Dishwasher
F4 Fault indication
F4 is a water inlet fault. It doesn't make sense if you have this fault indication with water flowing into the unit. Does the dishwasher drain properly? Usual suspects for an F4 indication would be a clogged inlet line, water supply turned off, bad fill valve, or a control board failure. Let me know if this helps, or give me a little more information on what you have done to correct so far.
Jul 09, 2007 | Asko 24 in. D3350 Dishwasher
Asko 24 in. D3530FI Built-in Dishwasher Logo
700 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
