Question about Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
Carburetor troubleshooting vacuum lines.49cc scooter fires but wont stay running
2 Suggested Answers
smithm164
SOURCE: my 49cc wont fire over
My 49cc 2 stroke pull start scooter wont turn over
Posted on Dec 19, 2012
Why wont my 50cc gator moped start has fuel and spark
Hi, Ruth and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to the carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and CDI box.
Spark plug cables in bad condition and shorting check for leakage in the dark, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty MAP, CKP, O2, TPS, sensors.
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box.
17. A stuck bent or burnt valve.
18. Tip over sensor needs a reset.
19. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Scooter Troubleshooting Scooter won start All about Scooters
Fix Chinese 49cc Scooter that won start
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Service Support China Jonway Group
http://www.dirtcheapmotorsports.com/jonway-gator-50-moped.html
Feb 20, 2017 | Jonway Motorcycles
How do i fix my motorcycle honda wave dash fuel gas not continous flowing if i fixed the gas cover
Hi, Danilo always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
2. Fuel cap or fuel tank not venting properly.
3. Fuel filter clogged with rust or dirt.
4. Vacuum line to fuel valve clogged, cracked, pinched, bent, broken, or missing*
5. Faulty vacuum line switch/relay
6. Petcock clogged or diaphragm cracked, cut or torn*
6. Fuel line from the fuel valve/petcock to the carburetor clogged, cracked, pinched, bent, broken, or missing.
7. Vacuum lines to the mechanical fuel pump clogged, cracked, pinched, bent, broken or missing*
8. Faulty electric fuel pump and or wiring*
9. Fuel line from the fuel pump to the carburetor clogged, cracked, pinched, bent, broken, or missing*
10. Carburetor inlet fitting clogged.
11. Carburetor float and or needle and seat stuck.
12. Carburetor overflow line clogged, pinched, or bent.
13. Vacuum line from carburetor deacceleration valve not zipped tied*
* If equipped or applicable.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Scooter Troubleshooting Scooter won run All about Scooters
http://www.scootertherapy.com/startinghints.html
My chinese scooter wont idle or start Check the fuel petcock
http://part-centre.boonsiewhonda.com.my/pdf/catalog/wave%20dash_new.PDF
Honda Wave 110i User Manual
Aug 31, 2016 | Honda Motorcycles
Scooter not getting gas to carb.
Silly question, but are you sure you are getting gas through the line? Could the line from the tank be plugged? How about the tank port?
Is there a fuel shutoff?
May 10, 2016 | Motorcycles
Yamaha scooter
Hi, Anonymous and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Starts then stalls 49ccScoot com Scooter Forums
Yamaha XC50V Service Manual
OEM parts for Yamaha
https://www.manualslib.com/manual/558548/Yamaha-Xc50w.html#product-VINO XC50V
Feb 16, 2014 | Yamaha G5 Motorcycles
Scooter not starting
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your issue. For more information about your issue please visit the website below. Good luck and have a nice day.50CC Scooter Wont start
Startup Troubleshooting Starting Your Scooter 1 7
Gy6 motor scooter problems
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial
Feb 09, 2014 | Bajaj Motorcycles
110cc suzki wont stay idling
Hi, Mark and the usual suspects are:
13. Multi carburetors not in sync.
DRZ 110 wont stay running
How to fix dirt bike that wont idle
Kawasaki KLX110 Service Manual
OEM parts for Suzuki
http://mybikemanuals.com/suzuki
Jun 12, 2017 | Suzuki Motorcycles
The engine starts on my benelli motorella 1965 model and then cuts out
Hi, Anonymous the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or a damaged battery, 9 volts or lower.
2. Faulty alternator/generator and or voltage regulator.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, O2, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Water or dirt in the fuel system, carburetor or filter.
9. . Restricted, blocked or kinked fuel line.
10. Fuel tank empty.
11. The gas cap is not venting properly or fuel tank venting system blocked.
12. A faulty Fuel Pump, pressure regulator and or fuel injectors.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
For more information about your issue, please visit the websites below.com. Good luck and have nice a day.
Chinese scooter won continue to run
HELP scooter wont stay running clean carb
How to tune carburetor in GY6 chinese scooter 150 or 50 cc
Scooter Carburetor Idle Adjust
Classic Motorcycles
Nov 17, 2012 | Benelli Motorcycles
My 49cc wont fire over
Aug 19, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
49cc Pocket Bike Carburetor Won't Draw Fuel
first off, are you getting fuel to bulb? if not are you sure the lines aren't on carb backwards. if you are getting fuel to bulb and won't run then here's what i'de check. how's the compression, may not be making enough vacuum to draw fuel, have you removed the mixture screws and blown out passages, there is a little sreen under diaghram in some of those little carbs that gets clogged, carb base gasket?
May 08, 2010 | RC Xrc Gas Rc Car Scooter
Scooter needs fuel flush
i have a honda 49cc scooter but doesnt seem to be getting fuel?can anyone help plse?
Oct 01, 2009 | 2006 TN'G RS 125
Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
180 people viewed this question
Top Quad Cycling Experts
shaun taylor
Eric Hidle
Level 1 Expert
Are you a Quad Cycling Expert? Answer questions, earn points and help others
