Question about Mitsubishi WS-65712 65" Rear Projection Television
TV will not power up; with all devices disconnected, held down MENU and DEVICE for 5 seconds, got 1 - 2 greenlight blink code. What is wrong; how do I fix it? David
  • 1 more comment
  • hcaproductio Aug 25, 2010
    Thanks for the tip. It was as you said. So - I plugged it in, waited for the blinking to stop; pressed the Power button - the green light came on with a click, 2 seconds, then off. I THEN pressed MENU and DEVICE and got the 2.2 code. Sooooooooo - it is the 2.2 code. How do we fix this problem? My son, who knows some TV repair electronics, took off the back and said the 6 fuses all look OK; he said on of the several capacitors makes a clicking sound when I press Power. He says all 3 guns look aligned and clear. Sooooo - suggestion? Thanks! David
    My email is hcaproductions@yahoo.com Thanks! I have sent this about 5 times in the last 5 minutes. The system seems to block email addresses. David
    My SD-Tech was SUPER!!!!! He has sent full instructions for fix it ourselves!!! He told us what parts, sent pics, and we can buy the parts cheap online!!! I am super satisfied!!!! Thank You FixYa!!! David
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Unplug set for a few minutes. Try to turn it on and if power light comes on and goes off, repeat self check.
If you unplugged set before doing this, error code will always be 1,2 which is no error detected--unplugging clears error code and you have to try again.
If you have questions comment here and I will assist you.
SD TECH
Posted on Aug 25, 2010
  • 16 more comments
  • SD Tech
    SD Tech Aug 25, 2010
    Did you get new error code or not?
    SD TECH---I AM HERE RIGHT NOW TO HELP.
  • SD Tech
    IF error code turns out to be 2, 2, I know how to fix==do it yourself etc.
    SD TECH
    Sorry, I was downstairs with my son holding the 1M Candle flashlight. I will stay here and await your reply. David
    Yes, it is the 2.2 code. David
  • SD Tech
    2,2 MEANS one of the fuses that protect the convergence circuit is blown--model indicated uses a single chip STK-393-110.
    I WILL attach photo of the chip and the fuses which are on the middle board==fuses are green and ones circled are 5 amp--test like any fuse.
    I have start to finish step by step instructions for this repair.
    I can post them here or if I had a email send them to you.
    SD TECH
    This is chip this set uses and on Ebay under 14 dollars.
    Let me know if you want the instructions and a way to send to you.
    SD TECH
    Please post here - THANKS!!!!!! David
  • SD Tech
    I will post in a few parts as it does not allow here to post all at one time. I hope you then rate this very helpful so I get paid for helping you.
    SD TECH
    If it is easier for you to send it to my email - send to hcaproductions@yahoo.com
    I will absolutely give you highest possible rating! You're Superman! David
    If it is easier to send to email, send to hcaproductions@yahoo.com I will give you highest rating! You're the Best!! David
  • SD Tech
    SOME problem here, do you have a email address, it will be easy that way.
    SD TECH
  • SD Tech
    DO YOU HAVE EMAIL ADDRESS? IT WILL BE EASIER THAT WAY.
    my email is hcaproductions@yahoo.com Thanks!!!
  • SD Tech
    YOUR EMAIL?
  • SD Tech
    what is your email?
    my email is hca productions at yahoo dot com - run the hca and productions together as one word. This system seems to block email addresses. David
  • SD Tech
    INCOMING RIGHT NOW
  • Brian Preece Jan 01, 2011
    I have been reading your string, tried to fix it without instrucitons, silly me. I replaced the convergence chip and the oversized caps for the blinking light of death about a year ago. I just replaced all the 3.9 ohm resistos (none tested bad) and the two 5 amp pico fuses. The one on the left of your picture immediatley blew. I replaced it again, same result. Is the convergence chip doing this? or someting else? Preeut
MY TV IS NOT COMEING ON IT IS MITSUBISHI
This is NOT a solution but a suggestion:
So you may know what is wrong, if power light (green) comes on and then goes off:
PRESS AND HOLD"device" and "menu" buttons on front of tv for at least 5 seconds and thenrelease both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
Jun 26, 2011 | Mitsubishi WS-65615 65" TV
My polaroid tv has a v-chip i need to how fix it. i need a code
Hello
If your device does not respond to the remote after trying all codes listed for your brand, or if your brand is not listed, try
searching for your code:
1. Press a device key once.
2. Press and hold SET until the red LED blinks twice; then release.
3. Enter 9-9-1, then the device group number (0= Cable, 1= TV, 2= VCR, 3= Audio). The LED blinks twice.
4. Aim the remote at the device and press Power. The remote sends IR codes from its library to the selected device,
starting with the most popular code first. If the device responds, go to step 7.
5. If the device does not respond, press CH+. The remote will try the next code. Continue until the device responds.
Note: Press CH- to try the previous code.
6. To search for other device codes, repeat steps 1 to 5.
7. Press SET to save and exit.
If you have set up the remote using the procedure in "Searching for Your Code", you may need to find out which four-digit
code is operating your equipment.
For example, to find out which code is assigned to your TV:
1. Press TV once.
3. Enter 9-9-0. The LED blinks twice.
4. To view the code for the first digit, press 1. Count the LED blinks (for example, three blinks = 3), and write down
the number in the appropriate code listing in step 8 under "Programming a Device".
NOTE: If a code digit is 0, the LED does not blink.
5. Repeat step 4 for the four remaining digits, using 2 for the second digit, 3 for the third digit, 4 for the fourth digit,
and 5 for the fifth digit.
6. To check for other device codes, repeat steps 1-5, substituting the device key for TV
Mar 18, 2011 | Polaroid FLM-3232 Television
Hi need code for ancient centrex tv for universal remote help aaaaaaaaaah
Hello
Centrex is not listed with URC04110 universal remote coldes. But you can search and find the code for your device with this remote control. I'm not sure will it work with your old Centrex TV. Anyway try. Wish you the best.
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all
codes listed for your brand, or if your brand is not listed at all, try
searching for your code. For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED blinks twice, then release
SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns
off.
NOTE: In the search mode, the remote control will send IR codes
from its library to the selected device, starting with the most popular
code first.
5. To lock in the code, press and hold SET until the LED blinks
twice, then release SET.
6. To search for the codes of your other devices, repeat steps 1 through
5, but substitute the appropriate device key for the device you are
searching for.
CHECKING THE CODES
If you have set up the remote control using the Searching For Your Code
procedure, youmay need to find out which four-digit code is operating
your equipment:
For example, to find out which code is operating your TV:
SET.
3. Enter 9 - 9 - 0.The LED will blink twice.
4. To view the code for the first digit, press 1 once.Wait 3 seconds,
count the LED blinks (e.g., 3 blinks = 3) and write down the number.
NOTE: If a code digit is "0", the LED will not blink.
5. Repeat step 4 threemore times for remaining digits.Use 2 for the
second digit, 3 for the third digit, and 4 for the fourth digit.
6. To check for codes of other devices, repeat steps 1 through 5, but
substitute the appropriate device key for each device you are checking.
OK.
Mar 08, 2011 | One For All URC4110 Remote Control
BLINKING GREEN LIGHT AND WILL NOT POWER UP
You can check the Error code by doing the following.
On the Front panel hold down the Device and Menu Button for 5 seconds. The LED light will then start flashing the first set of flashing lights is for the "1"5 part of the code it will then pause for about a half second and start the ones place 1"5". The code will repeat 5 times before going off.
The Error Codes: 12 - Normal Operation; 21 - X-Ray Protect; 22 - Short Protect; 23 - Loss of Horizontal Deflection; 24 - Loss of Vertical Deflection.
The problem may also be in the power supply when you first plug the device in check how many times the Led blinks if it blinks for just over a minute the power supply is working fine. If the Led blinks repeatedly and does not stop the DM is not running.
This is a link to the service manual for you TV,
http://www.service-manual.eu/model.php?id=2710
Mar 02, 2011 | Mitsubishi WS-65909 65" Rear Projection...
I had a problem getting the code,to work with tvsignature2000,can you e-mail me the code for this,
Actually there is no code specified in URC-3021 manual to work with Signature.
But still we can try
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH up, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
1 through 5, but substitute the appropriate device key for
the device you are searching for.
If you have set up the remote control using the Searching For Your Code procedure
as above, you may need to find out which four-digit code is operating
your equipment. For example, to find out which code is operating your
TV:
then release SET.
seconds, count the LED blinks (e.g., three blinks = 3) and
write down the number in the leftmost box in the TV
code boxes on page 8.
5. Repeat step 4 (on the previous page) three more times for
remaining digits.Use 2 for the second digit, 3 for the third
digit, and 4 for the fourth digit.Write down the code digits
in the remaining TV code boxes on page 8.
through 5
Feb 17, 2011 | One For All URC-3021 Remote Control
Hi my tv is the ws-55315 and i turn the tv on the light comes on for a second(the power light) and the tv shuts off is that the bulb i dont know?and how do i fix it
WHEN the power light goes off on front of set, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Power light will blink an error code: most common is 2 blinks, 2 blinks, a pause and it will repeat code several times.
This is self check and will narrow down what is wrong with your set.
Let me know what code you find and I will tell you what it means.
SD TECH
Nov 06, 2010 | Mitsubishi WS-55315 55" Rear Projection...
I have a Mitsubishi big screen tv model #WS-65857 and the picture went out as though the tv was turned off and when you turn it back the green light comes one for about 5 seconds the goes of there is no...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
if your set does not have a device button press Menu and Input together for 5 seconds and release. there will be a pause between blinks---2 blinks, a pause and two more blinks etc.
If you need help: etower.766@netzero.net
I do this here for free so if this has helped you give me a vote here.
Aug 18, 2009 | Televison & Video
URC-3605B1 need code for insignia tv
not listed at all, try searching for your
for your TV:
2. Press and hold SETUP until the LED
blinks twice, then release SETUP.
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
the TV turns off.
control will send IR codes from its library
SETUP until the LED blinks twice,
then release SETUP.
for the device you are searching for
procedure, you may need to find out
which four-digit code is operating your
equipment:
operating your TV:
blink twice.
press 1 once.Wait 3 seconds, count
NOTE: If a code digit is “0”, the LED will
not blink.
5. Repeat step 4 three more times for
repeat steps 1 through 5, but substitute
As before,write down each fourdigit
code.
http://www.rockabilly.net/files/manuals/URC-3605.pdf is my source for the info
http://www.rockabilly.net/files/manuals/URC-3605-codes.pdf these are the codes, I didn't see insinia in the TV section, so you may have to use the search feature
May 11, 2009 | One For All URC-3605 Remote Control
Need set up instructions and codes for one for all remote urc-3220
your code.
then release SET.
CH+, or PLAY).
first.
blink twice.
CHECKING THE CODES
TV:
then release SET.
NOTE: If a code digit is “0”, the LED will not blink.
through 5 (starting on the previous page), but substitute
Write down the device’s code digits in the appropriate
I could not find the codes but you can follow these instruction to program without codes
Jun 19, 2008 | Televison & Video
Please help with tv! green blinking light wont stop and tv wont turn on
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
please post your error code
Dec 19, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WS-65712 65" Rear Projection Television Logo
193 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
