Question about Mitsubishi Televison & Video
The picture looks like it is in 3-D. what is wrong with it.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
This depends on model number.
See attached photos.
SD TECH
Posted on Aug 25, 2010
Picture in blue hues
Not sure what is wrong but sounds like 1 or more of the colors are out. Many TVS are 3 colrs like red, blue and green that make up the picture. TVs like this have 3 color generators and they can go out individually so it is likely that is what happened. Probably not an easy fix as it might be the electronics or light (usually the light). Check your manual (or download it) and see if there are user replaceable color lights or take it to (or talk to) Best Buys repair to see if they can replace the light.
Oct 25, 2015 | Televison & Video
My toshiba 40e210u lcd tv won't show full image on screen
The Aspect ratio of the TV could be on the wrong setting for the image you are trying to view. Widescreen's standard ratio is 16:9 ensure the TV is not set to zoom, 4:3, or pan & scan in the picture menu of your TV.
If the picture looks normal except it's just missing the edges or looks squashed or looks like it is zoomed in from the normal image then aspect ratio is probably the cause.
Aug 03, 2012 | Toshiba 40E210U 40 in. LCD TV
Picture is stretched on wide screen a circle looks egg shape
Hello
This is an issue because most television programming is produced in a 4:3 aspect ratio. The minority of programming is high definition, which is produced in a 16:9 aspect ratio. Because televisions are made in either a standard (4:3) or widescreen (16:9) format, there is always a conflict with an image being stretched vertically or horizontally. In the case of widescreen televisions, the stretching is horizontal.
Picture Modes
Luckily, most if not all widescreen televisions have a picture mode that allows the user to toggle between a wide (16:9) and standard (4:3) mode. This means that a person can watch non-HD programming in the 4:3 picture mode, and then go to widescreen when watching HD programming. Some TVs have a picture mode that will automatically adjust to the correct aspect ratio. Other people will watch all programming in the wide picture mode, and learn to adjust to watching a stretched picture.
A stretched picture is when a 4:3 image is pulled on the sides to fill the entire screen. People and images end up looking fatter/wider and shorter.
So, what's the big deal?
Some people don't like a 4:3 picture stretched or distorted because it does reduce the overall visual and picture quality. Some people don't like the bars on the side of the screen when a widescreen is in a standard (4:3) picture mode because it looks different.
Solution
There is no fix-all solution for this issue, unless you own a TV that will automatically adjust to the intended aspect ratio. The stretching of the picture is a side-effect, the price we are paying for the better resolution that is digital and high definition. This is definitely something to consider when buying a television, but keep in mind that there is no right or wrong within this issue. It is just the way it is, and there is no way around it unless you buy a 4:3 aspect ratio television.
Hope these lines will clear the issue, if so do rate the solution
Jan 04, 2011 | Televison & Video
My tv looks like it is in 3d and ideas what is wrong with it and can it be fixed thanks matt
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 27, 2010 | Toshiba 53HX71 53" Rear Projection...
When viewing a dvd on our Bravia we can't set the picture to the full screen. We get black areas above and below the picture.
This is called widescreen, nothing is wrong with the tv or dvd, Look on your box of the dvd it will say Widescreen. This is the exact picture as it is in the movie I got this question all the time when I sold Tv's at sears for 3 years. Again nothing is wrong.
Nov 27, 2009 | Sony BRAVIA KDL52XBR2 Television
I have a samsung rear projection tv and has ghosting on picture? what could be wrong and is it easy to repair?
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 17, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Panasonic 53'' convergence
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Nov 24, 2008 | Toshiba 50H82 50" Rear Projection...
Playstation 3
HI,
Please take a look at the set-up menu from the Playstation-3.
Maybe there's chosen a wrong kind of output (digital/analog)
kind regards,
Gerard
Oct 01, 2008 | LG 42PC3DV 42 in. Plasma EDTV
Re-Sized Photos are Grainy
This camera takes pictures with a Ppi of 72. That is why the pictures look huge on the screen. To get good quality prints you need to have at least 200 ppi, or even better, 300 ppi.
Or, the contrast of the pictures may be to low. I have an FZ7 too, and I always tweak the contrast and color saturation before outputting.
1. images straight from the FZ7 are generally low in contrast.
2. Pictures that are low in contrast might not look too bad on screen, but when they are printed they will look slightly greyish.
3. Low ppi pictures look fuzzy in print.
Maybe you can post a sample original picture??
Jul 06, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Green tint to hd picture
Sister PCB==PIP or video bad,also==PVAT! Look for any Crt leak damage.Solder all bad connects.
Sep 16, 2007 | Samsung HCM4215W 42" Rear Projection...
Televison & Video Logo
11 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
