Question about IMSI TurboCAD Full Version for Mac
In Turbocad Mac V5 I can't get part dimensions to appear when using the Layout -model to sheet- command.
  • bravo2000 Aug 27, 2010
    Solution discribed well how to set dimension attributes, but the Turbocad staff says that there is no way to carry dimensions made in model space mode over to the sheet mode's various views
  • 857 Answers
FOLLOW THESE STEPS:
1. Establish the scale you wish to use and the size of paper you wish to use and in menu File > Page Layout select your scale - for architectural we commonly use 1/20th so select User Defined and type in 1/20 and the field automatically calculates the decimal - this is now the drawing scale. All future line-work will be scaled from the full size, so you draw full size, it's that easy. As your drawing take shape and you know the extents of it you can change the Rows and Columns to suit, if you check the box that says 'show drawing in preview', it becomes quite easy to see where you are going. This puts you in the picture, so to speak - now for the dimensioning. This is where it gets long winded.
2. First establish your arrow head ( or dim'n line terminator ) style and size in menu DimPen select Arrow Head > Style and check your terminator, then select Arrow Head size. This opens a dialogue box that has pre-set values - Multiply all these values by the denominator of your scale - in this case - 20, all except for the angle - for obvious reasons. Click the OK button.
3. Text sizes for both dimension and notes. Select the Text icon on the Main Tool Palette then Text in the menu, then Size > User Defined, I commonly use 3.5mm, so again multiply this by your scale denominator ( 3.5 x 20 = 70 ) and check the Model radio button, then Ok.
4. Dimension text is much the same way. Just select the Dimension Icon on the Main Tool Palette and DimText in the menu, if you use different size text for notes and dimensions this would affect your values.
5. Now we put it together in the manager.
From the menu select Dimension > Standards Layout > Standards Manager. This opens a dialogue box with a whole set of values with a heading file relating to a current Standard i.e. ( DIN; JIS; ISO ); Scroll through and Select the one you are using.
For more info Go through the user manuel from the link below:
http://my.qoop.com/store/IMSIDesign-1281024257792330/TurboCAD-Mac-v5-Reference-Manual-by-IMSI-DESIGN-78613227594300/
or contact them ;
TurboCAD Phone Support
1.800.833.8082
Hours of Operation: Monday - Friday
9:00 am - 5:00 pm (Pacific Standard Time)
Posted on Aug 27, 2010
My laptop will not come on
try holding down the ctrl and f2 button at the same time as pressing the start button it might get you to the bios so you can reset to default settings .Mine as done it a few times .
Oct 12, 2016 | 3CLeader for Acer Aspire V5-531 V5-531G...
I have TurboCAD Designer 2D for Mac V.5 December. Last night I opened my old project, made some changes and saved it. Now when I try to open that revised file I saved last night, I get error message:...
Hello!
If autosaved is enabled in your CAD, then most likely you can recover a n sv$ file of it saved in a temp folders. You can rename this file and change the extension from .sv$ to .dwg.
This link may help you find the folder where autosaved CAD file is stored
This link might help you also.
Good Luck!
May 03, 2011 | IMSI TurboCAD Mac Designer 2D 5
Turbocad starts to register regenmethods from tcimage.dll
Re: 11.2 Program will not start
I found this on the TurboCAD forums,
"Doesn't appear in "Applications" but appears in "Processes" in Task
Manager (XP)."
I posted the following there also.
I am having the same problem sort of. I installed it on my computer
and the TCStart Module stops responding.
If I click the TC icon, the TCStart Module will open, but if I click
on "NEW" it just closes and stops responding.
I tried opening a file that I had brought home on a disc, clicked on
it, and it will not open.
If I try to open the file from the Start Module by navigating to the
file location, the whole thing stops repsonding.
[EDIT]
One more thing, at the bottom of the Start Module it says, "TurboCAD
starts to register RegenMethods from TCimages.dll...", and it stops
there. I don't ever remember seeing that before.
[/EDIT]
Mar 02, 2011 | IMSI TurboCAD Deluxe 14 (Win) Full Version...
Hard disk crashed on macbook
You can tell if your hard drive for your Macbook Pro has really crashed, if you attempt to run these 3 diagnose and repair procedures and there is no response from the hard drive:
1st Procedure:
font.f1 {font: 12.0px Helvetica} font.f2 {font: 14.0px Myriad Pro} - USING FSCK COMMAND TO VERIFY AND REPAIR DISK-
Start up your computer in Single-User Mode to reach the command line by doing this:
•Make sure your Mac is shutdown.
• Reboot your Mac
• When Mac starts up, press the Apple Command key+ S Key
- A black screen, with white text appears
• At the command-line prompt, type /sbin/fsck -fy
• Press Return.
--fsck will run through a series of tests and will return information about your disk's use and fragmentation. When completed, it will display this message if no issue is found:
The volume (name_of_your_Mac_volume) appears to be OK
If fsck found issues and has altered, repaired, or fixed anything, it will display this message: --FILE SYSTEM WAS MODIFIED--
Important: If this message appears, repeat the fsck command you typed at the beginning, until fsck tells you that your volume appears to be OK (first-pass repairs may uncover additional issues, so this is a normal thing to do).
• When fsck reports that your volume is OK, type reboot at the prompt and then press Return.
• This last command after completing the fsck process, is going to attempt to boot your Mac to the main desktop.
If unable to reach your Desktop with the fsck procedure, go to the next step.
Procedure # 2
font.f1 {font: 13.0px Myriad Pro}
-RUN DISK UTILITY WITH STARTUP DISK-
Insert your Mac OS X Startup disk
•Reboot your Mac
•At the Apple Chime, press the C key and hold it until you see a White screen, gray Apple and eventually a Spinning gear.
• Release the C key only after you see the Spinning gear.
•Mac will boot from the startup disk to the Installer environment
• From the Installer Menu bar, click Utilities > Disk Utility and open up Disk Utility application.
• Click on on the hard drive at the top of the window in the left sidebar and
• Select "Repair Disk"
**Let Disk Utilities run this repair the disk until completion
• At the end of this process, reboot your Mac
* If you have still not gotten a successful boot to your main desktop, try this final step.
Procedure # 3
My recommendation for this issue, is that you use the Archive and Install procedure to resolve this issue.
What this process consists of (using your Mac OS X install disc),is removing the damaged or corrupted Mac OS X directory and replacing it with a brand new directory.
This procedure also allows you to save your applications, files and folders without the old directory interferring with you then accessing those files.
-ARCHIVE AND INSTALL-
• Start up from your Mac OS X Install Disc 1 or Install DVD. Please remember to use the install disc that matches the current operating system your system haves.
Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key.
• Hold the C key until you see a White screen, with a Gray Apple icon and eventually a Spinning gear.
-Your mac will now boot from the disc and load into the Installer environment.
• Select your language. The Welcome to the Mac OS X Installer window appears.
• Click Continue. The Important Information window appears.
• Follow the prompts until you get to the licensing agreement screen
• An agreement sheet appears. If you agree with
the license agreement, click Agree. Then Select a
Destination window appears.
• Click the volume that you wish to install to (your primary hard drive).
• Click Options. The installation options sheet appears.
• Select Archive and Install.
• Select the volume which already has Mac OS X installed.
• You should also select Preserve Users and Network Settings, to preserve network and Home directory settings.
• Click OK.
• Click Continue to begin the installation.
• Once the Archive and Install is completed, when you reach your desktop be sure to run all Software updates to bring your new Mac OS X directory back
up to current.
Also, if you look inside your Macintosh HD icon on your Desktop, look for a folder entitled "Previous System Folder" which will have all of your previous Home folder files prior to the Archive and Install.
Here is the link (below) from Apple for more information about how to locate the Previous System Folder
How to locate Previous System Folder (after Archive and Install)
If there is still no responsiveness of the hard drive after this last procedure, your best option would be to take your Macbook Pro in for repair or replacement of the hard drive, to your local Apple retail store Genius bar or local Apple authorized service center.
Best Regards,
-Mactechtrainer
Jan 29, 2010 | Apple MacBook Pro PC Notebook
Turbocad 14 deluxe freezes when doing moves, copy, and inserting dimensions. Depends on how much detail is in the drawing. Can do very simple things such as drawing, trimming and etc. Have re-installed...
Have you suffient ram. Turbo uses a lot of ram, as well as a high CPU clock speed rate. I have turdo too, had to increase ram chip, runs smooth.
Go to www.offtek.co.uk Free scan of your mem. Readout, advise if you need more ram.
Purchase on line befor 12, with you next day post.
If Ram is ok, come back.
Nov 14, 2009 | Computers & Internet
Can not seem to fit the plot to the paper size.
I have solved the problem and are creating good plots
the problem was not with the plotter but the drawing had bugs
Thank You Jamie
Oct 23, 2009 | IMSI TurboCAD 2D Full Version Academic...
Evaluation expired - not true!
Check the Preferences folder in the System folder to see if there is a TurboCad related file there that might contain an old date.  Delete it and see if TurboCad will start.  If it does it will probably create another file in the Preferences folder that has a new start date for the evaluation period.
May 20, 2009 | IMSI Turbocad Mac Pro 2D/3D V 2.0...
Keyboard types wrong letter
  1. Click Start, and then click Control Panel.
  2. Under Pick a category, click Date, Time, Language, and Regional Options.
  3. Under or pick a Control Panel icon, click Regional and Language Options.
    The Regional and Language Options dialog box appears.
  4. On the Languages tab, click Details.
    The Text Services and Input Languages dialog box appears.
  5. Under Installed services, click Add.
    The Add Input language dialog box appears.
  6. In the Input language list, click the language that you want. For example, English (United States).
    NOTE: When you use the United States-International keyboard layout, you should also use an English language setting.
  7. In the Keyboard layout/IME list, click United States-International, and then click OK.
  8. In the Select one of the installed input languages to use when you start your computer list, click Language name - United States-International (where Language name is the language that you selected in step 6), and then click OK.
  9. In the Regional and Language Options dialog box, click OK.
    Notice that the Language bar appears on the taskbar. When you position the mouse pointer over it, a ToolTip appears that describes the active keyboard layout. For example, United States-International.
  10. Click the Language bar, and then click United States-International on the shortcut menu that appears.
Thanks,
Armymason
Mar 02, 2009 | Dell Dimension 4600 PC Desktop
Vista with turbocad
Hello Robinmia, When it comes tp a production environment, the owners are right. Productity is the most important. Check the website support for Turbocad v9 for the patch. If none Windows Xp should be loaded.
Apr 15, 2008 | Microsoft Windows Vista Ultimate Edition
Turbocad V10.2 will not work with Windows Vista basic
well, turbocad deluxe 10 is NOT compatible with vista. Here is the compatibility list : Windows 98/Me/NT4/2000/XP Pentium-class PC 64 MB RAM (128 MB recommended) 55-212+ MB hard-disk space 64 MB of swap space Super VGA (1024 x 768) display High Color (16 bit) graphics card 4x CD-ROM drive with 32 bit drivers
Jul 16, 2007 | IMSI TurboCAD Deluxe 10 for PC
IMSI TurboCAD Full Version for Mac  Logo
288 people viewed this question
Top IMSI Computers & Internet Experts
Lesley Cameron
Lesley Cameron
Dan Shibata
Dan Shibata
Are you an IMSI Computer and Internet Expert? Answer questions, earn points and help others
