Question about Sharp AR-5316 Advanced Digital Imager Copier
What is a flashing CH icon mean...machine won't work
  • 61 Answers
If CH is on not flashing the side door is open, if it is flashing CH dev cartridge is not installed
Posted on Aug 25, 2010
Testimonial: "fast, efficient & accurate. Thanks Guys"
What does "work Puff Stitch, Ch 1" mean?
Usually it is best to perform each step as stated in the pattern. Close the Puff stitch (follow the instructions for closing the Puff stitch), then Chain 1.
Perhaps this will help:
How to Crochet Puff Stitch dummies
Crochet Puff Stitch Slow Motion Crochet
Puff Stitch crochet
Dec 05, 2016 | Sewing Machines
What does this mean? My machine is very new & won't drain it won't go through a full cycle & won't spin properly now it's bleeping with this flashing up on it!
Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
Apr 06, 2013 | Washing Machines
Samsung ch@t 335 alarm not working.
Make sure you have correctly set your time and date of your phone. By "correctly", I mean double check that "AM/PM" thing.
Jun 11, 2017 | Samsung Cell Phones
Use of Canon 60D's wireless function to control power on Canon 430EXII, being operated manually.
Your flash will fire optically. This is wireless but not radio.On the flashgun window move through the options until you see all of these in the window :- Flashing M, MZoom (24mm)
(the power output eg) 1/4
Flashgun icon CH1 Slave (blank)
The front panel should show a flashing red light. This means it is ready to receive the light signal from your onboard flash. From the camera menu select the in built flash control.
Set it to - Built-in flash - CustWireless
Flash mode - Manual flash
Wireless func - (single flashgun icon)
Channel- 1 ch
firing group - (flashgun icon)All
(flashgun icon) flashoutput - 1/64
selecting 1/64 should be sufficient to trigger the flash gun but not light the scene.
Manually pop up the onboard flash
In the view finder you'll see a number of green bars when half pressing the shutter and wait for them to go down to one which mean the camera and flashgun are communicating, fully press to take the shot and the flash (off camera) should fire.
Jun 26, 2017 | Canon EOS 60D Digital Camera
What does message ch mean?
If your copier front or right cove is not attached properly then CH on standby, or CH is blinking/flashing may be your copier TD unite is not adjust or close.
Dec 28, 2009 | Sharp AL 1631 Copier
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
What does flashing CH mean?
Flashing CH means that the developer unit is not installed inside the copier or its not well installed. Check and install properly.
Aug 24, 2009 | Sharp AL 1631 Copier
AR-150N series copy machine. Making loud clicking sound and has CH on display. Need manual for this machine also.
CH means door is open, flashing CH means problem with toner cartridge You may need to replace the toner cartridge, the op manual can be downloaded at: http://www.sharpusa.com/files/cop_man_AR-151.pdf
The 151 is the same to the 150
Hope this helps you...
Jun 06, 2008 | Sharp Office Equipment & Supplies
Sharp al-1644 photocopier
Usually CH indicates that one of the doors on the copier is not closed properly, if it is a flashing CH then there is no toner cartridge in the copier or the cartridge is of the wrong type for this machine. A lot of toners for this machine look alike but are not the same for the machine.
May 26, 2008 | Office Equipment & Supplies
Sharp AR-5316 Advanced Digital Imager Copier Logo
53 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
