We had "Power Off" failure of the controller of our lawn sprinkler system. The controller is a "Rain Bird ESP-6PM. The transformer was confirmed as being O.K. We changed tDhe fuse, albeit the old one tested as OK. We also changed the after which t he "Power Off" signal turned off. The problem no w is the system station valves do not turn on. We have entered the desired program. Any suggestions ? Thank You!! Robert Wood
  • Robert H Wood Aug 25, 2010
    How?
    The problem is in fact the circuit board. The valves tested O.K. By bypassing the timer and connecting 24 VAC, directly too them one at a time. I am replacing the timer. I only have to figure out how to wire in the WRC wireless rain sensor. THat should be fairly easy. Thanks, Robert
  • 12,061 Answers
Www.rainbird.com/pdf/turf/man_ESP.pdf
Your manual is above.
Now that Power failure you had, maybe have an underlying problem, First you need to try and reset the unit, as per the manual, and try resetting up the program parameters again, and seeing if it would then work? Right, now if it still will not work, after doing this, then I am afraid that the Power Supply switching semiconductor devices, that drive the solenoids that open the valves that let the water flow, are damaged, that, or the Power supply, has failed in the section that supplies the extra current to drive the valves. or, It simply may have suffered a power spike? and this also would account for symptoms such as these, too.
If it is proved to be internally faulty, you really have no alternative but to return it to the manufacturer for repair, as you will most likely need to replace the driver board.
Posted on Aug 25, 2010
    Top Expert:
  • Office Equip... Master
  • 75,817 Answers
Reset the system programming.
Rainbird esp modular controller will not operate system -
Make sure that the transformer is supplying the 26 volts ac required by the pump relay and zone solenoids. If the voltage is there and unit still will not operate then the electronics are to blame.
Jul 22, 2016 | Rainbird Rain Bird Esp-4mi Esp Modular...
When on auto mode, the system just keeps repeating the zones.
I don't feel you can repair system by yourself. Excuse me if you can; so do it.
You should take it to an authorized Rain Bird repair service. Look for it on some listing they might have given you when you bought your stuff or contact them from here:
http://www.rainbird.com/corporate/contact.htm
Sep 20, 2015 | Rainbird Rain Bird ESP-4ME Modular Outdoor...
System quit watering. Tried man/adv and won't energize sprinkler valves. I can operate sprinkler valves manually. Tried unplugging power source to reset. Any suggestions?
Most sprinkler valves run on electricity from the timer. If the time doesn't send electricity out, the valves don't open. If an animal has chewed through a wire, that valve won't open.
You can take a meter and check the voltage on the wire at the timer. If nothing, replace timer.
If you get correct voltage at timer, measure at valve. if voltage good there, replace valve.
May 31, 2015 | Rainbird Rain Bird Esp-6tm Sprinkler Timer
Rainbird troubleshooting
Check to see if the wiring is crossed.
Jul 18, 2014 | Rainbird Rain Bird Esp-lx 4-station...
I'm getting the error code ER P. What does this mean?
Without knowing who the manufacturer is it sounds like it is an "error in the power supply" Suggest replacing the transformer or checking voltage in the outlet.
Sep 04, 2013 | Rainbird Rain Bird Simple Set 6-station...
120 people viewed this question
k24674
