Question about Texas Instruments TI-89 Calculator
Hi, I recently purchased a ti 89 calculator from a friend and I am having the following problem: The calculator will not evaluate trig functions. For example, if I type Sin(Pie/4) and hit enter, the calculator says Sin(pie/4) as the answer.
  • Texas Instru... Master
  • 7,993 Answers
The calculator is set up to produce exact results. If you want the expression to be evaluated put a decimal mark at the end of the 4.
to making 4 a floating point number instead of integer.
Alternatively, press the [MODE] key. Scroll down through the pages of options until you reach the line labeled Exact/Approx. When cursor is on that line, use the right arrow key to open the menu. Select [3:Approximate]. Press [ENTER] to save.
Posted on Aug 25, 2010
  • k24674 Aug 25, 2010
    OOPS "to making 4 a floating point number instead of integer." should read "to make 4 a floating point number instead of integer."
How to solve trig functions using ti-83 plus
Your best bet would be trying a math package on ti-calc.org - you can usually find something that does what you want there. You'll need a cable and the software to download these programs to your calculator. Here's a link to the trig section:
TI 83 84 Plus BASIC Math Programs Trigonometry ticalc org
Jun 01, 2014 | Texas Instruments TI-83 Plus Calculator
How do i put arc on the calculator
For the inverse trig functions, press 2ND then the trig function key. For example, to calculate the arcsine of 0.5, press 2ND SIN . 5 ENTER
Oct 18, 2013 | Texas Instruments TI-83 Plus Calculator
TI-36X won't let me take the CSC(1.5). I keep getting
No calculator can have EVERY mathematical function. Very few calculators have the secondary trig functions like cosecant because they're so simple to calculate in other ways. By definition csc(x) is equal to 1/sin(x) and you can calculate it that way. Similarly, calculate sec(x) as 1/cos(x) and cot(x) as 1/tan(x).
Jun 04, 2012 | Texas Instruments TI-36X Scientific...
@n sign on ti 89
That's because there's an infinite number of solutions to your equation. Replacing the @n with any integer gives you a new, different solution.
Mar 14, 2012 | Texas Instruments TI89 Titanium Scientific...
How do I get -tan,-sin,-cos for inverse ratios
If you want the inverse trig functions (arctan, arcsin, and arccos), press the yellow 2nd key before pressing the appropriate trig function key. If you want a negative value, press the +/- key between the decimal point and = keys.
Mar 09, 2011 | Texas Instruments TI-30XA Calculator
Does this calculator have an inverse function? If so, which button is it?
The x^-1 key is in the leftmost column of the keyboard, below the MATH key.
If you want the inverse trig functions, press 2ND then the trig function key.
Jan 13, 2011 | Texas Instruments TI-84 Plus Calculator
I am having trouble figuring out why my ti 89 has trouble figuring out integrals. for example i know that the integral of x^2 is x^3/3+c but my ti 89 gives me the answer in a decimal of fraction form. i do...
The calculator does not give a result of an integration with a constant. The form of the result will depend ob the EXACT/APPROXIMATE mode you have selected.
In the following screen capture, your integral has been evaluated with mode set to EXACT,AUTO, and APPROXIMATE. Pay attention to the syntax.
To set the computational mode to EXACT, press the MODE button use the Function keys F1,F2 or F3 to move from page to page, point to EXACT/APPROX and use the right arrow key to unfold the submenu, then the Up or Down arrow to select AUTO, EXACT or APPROXIMATE and press ENTER to SAVE Configuration.
If the integral cannot be found in EXACT mode, the calculator will echo the command without calculating the integral.
Apr 26, 2010 | Texas Instruments TI-89 Calculator
Trig functions of the TI-30XA
if the sides of a triangle are 15cm ,16cm, and 17 cm ,then the area of the triangle is what ?
May 09, 2008 | Texas Instruments TI-30XA Calculator
Graphing trig functions
Put the calculator in radian mode and it will graph trig functions just fine. If you don't know how to change it to radians, then go to mode and cursor over to select radians. I am assuming you know where the sine, cosine, tangent, etc. keys are.
Dec 31, 2007 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-89 Calculator Logo
78 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
