Question about LG Televison & Video
TV will not read incoming cable signal - LG Televison & Video
  • 4 more comments
  • jrosetto Aug 25, 2010
    LG plasma Model # 42PG20. Not a combo model
    HDMI hook up from cable box ia connected. I tried sitching boxes, cables, auto tuning, etc.
    HDMI hook up direct from cable box. Switched out cable, cable box, Tested HDMI plugins with DVD.
    Cable shows no signal across screen
    WHere does one change "TV on channel 3 or 12 or broadcast air or cable"?
    TV will not read the incoming cable signal. HDMI direct hook up from cable box. Changed cables, calbe box, switched HDMI inputs with DVD. HDMI inputs work with DVD but will not read cable signal.
  • jrosetto Aug 29, 2010
    I found out from LG, the plasma TV requires a resolution siganl of 720p or higher. Comcast had lowered the signal out put of the cable box to 480i without notifiying me
  • LG Master
  • 11,800 Answers
Simple test - plug something else in the HDMI entry of the tv. If you get an image then the cable box is defective - take it to the cable company and ask for a replacement.
If you don't get an image then the fault is inside the tv, on the mainboard - you will have to replace it.
Posted on Aug 25, 2010
  • Azrael SRL Aug 25, 2010
    If the TV works just fine when a dvd is plugged instead of a the cable box then tha cable box is faulty, not the TV. Replace the cable box.
  • Azrael SRL Aug 29, 2010
    In that case either raise the signal resolution yourself or use an analogue connection -  RCA cable. The quality of the image will be lower but you will be able to see it.
    President:
  • 1,285 Answers
Is cable live? make sure coaxial cable wire is sticking out at least a 1/4 inch from each cap and is not bent. connect to in on box from wall? cable out from box to TV. is TV on channel 3 or 12 or broadcast air or cable?
  • Dvdcdlaser
    Dvdcdlaser Aug 28, 2010
    okay, you are using hd then your tv should either be on source (component or hdmi) not ch 3 .....the 3 colored wires from the cable box out to tv in
The picture looks like it's moving in slow motion...
Ur tv incomming broadcasting tv channels signals are pick up and using are Free over the AIR broadcasting tv channels pick up are by a Antena signal wright?Not signals by a pay cables or satalites tvs incomming broadcasting input signals?Yes?This tv causes are low and weak ranges of a tv Antena incomming recieving broadcasting tv channels signal.Buy a better design Antena like a Digital Antena and used it will solved this problems.Plug it in ur Digital Antena and rescan ur Free over the AIR broadcasting tv channels again.
Aug 15, 2011 | TruTech PVS31170S1W 17 in. LCD Television
There is a message on the screen that says "Weak or no signal".
Tv it is not getting the tv stations broadcasting incomming signals.Make sure the ur pay CABLE or free AIR incomming broadcasting tv stations signal sources are good and than go in ur tv menu go into SETUP pick AIR or CABLE and rescan channels again.U should have no more weak or no signal message anymore.
Jul 31, 2011 | Samsung HL-67A510 67" DLP HDTV
Our toshiba rezga 47lz196 colour is off. There doesn't seem to be any red. All the skin tones are green. Blue shows up but all the other primary's are green. We have green, blue, yellowish, black and...
There are only two possibilities for this problems for this tv.One: the tv incomming broadcasting signal cable wire that is plugging into ur tv Tuner signal board could be bad.U can test this out the incomming broadcasting signal cable wire is good or bad pretty easily by just plug it into another tv to find out the incomming signal cable wire is bad or good.Two: If the tv incomming broadcasting signal cable wire is good by plug it into a another tv.Than ur tv the tv Tuner signal board is the causes and the problems.The tv Tuner signal board CPU chip is bad.U can do some mechanical work like take things aparts and putting it back together again?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 27, 2011 | Toshiba 47LZ196 47 in. HDTV LCD Television
Why is the screen orange on my plasma tv
Ur tv is missing a blue color.U tv might have a bad incomming broadcasting signal cable.Try watch a DVD movie,to make sure,if u have all three colors guns like R,G,B on the tv.If DVD movie have the same problems,than ur tv have a dying tv Tuner signal board,that take in the incomming broadcasting signal cable.
Mar 03, 2011 | Panasonic Viera TH-42PX80U Plasma TV
The color on my tv is blue,green,yellow and orange. How do i get the original color back to my television?
Ur tv have no Red colors,might have bad incomming broadcasting signal cable plug to tv,tries tv with another incomming broadcasting signal cable.See,if the signal is good have no Red too,than ur tv Tuner signal board is probally dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Feb 10, 2011 | Sharp Aquos LC-26SH20U 26 in. LCD...
I have a model no. 32HLC56 TV. Everything seems to work fine, except the color of football fields. They come in gray instead of green. However, other things, such as uniforms that are supposed to be...
Take this tv set test it with other tv incomming tv signal cable in ur house or take another tv test this incomming broadcasting signal cable.If it is the tv,not the incomming broadcasting signal cable.The tv Tuner signal board is the causes and it is dying.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacemennt.
Dec 09, 2010 | Toshiba 32HLC56 32 in. HD-Ready LCD...
The LED vizio comes on the front of the tv...........screen is blue with floating signal saying No Signal!.
Tries unplug the tv and the cable or satalite boxes too.Replug it all back like an hour later.The tv know will reset itself back to the factory setting.The cables or satalites boxes it upgrading it softwares.The tv should have incomming broadcasting signal and work now.Not,call the cables or satalites compannies to replaced those inputs boxes first,have the same problems with those new input cables or satalites boxes.Than the tv,the Tuner signal board have problems and the cause.That the board,where the incomming broadcasting signal cable plug into it.That the tv Tuner signal board.Tries websites Shopjimmy.com,Ebay.com to buy a whloe refurbish Tuner signal board for the replacement.
Nov 07, 2010 | Vizio VX32LHDTV10A 32 in. LCD HDTV
Unable to view TV programming on TV, able to utilize set for viewing DVD/VCR movies. Cable company says their Cable Card is 'OK' and the TV needs updates (assume software) in order to work correctly with...
U get a channel numder and menu screen do show up?Not the tv,it the incomming broadcasting signal cable plug in or the cable box itself have problems.Tries unplug,replug the tv and the cable box back in like about an hour later.The tv will reset itself to the factory setting and the cable box should upgraded it softwares.Should work now.If have the same problems,tell the cable company change the cable box or check the incomming broadcasting cable wire with another tv,see the incomming broadcasting signal cable wire,with a new cable box,see if it work.
Oct 21, 2010 | Toshiba 46HM95 46" HDTV
MY ORION TV KEEPS FLASHING PINK AND I HAVE FUNNY LINES ON THE SCREEN CAN ANY ONE HELP THANX ANT
Ur Tuner signal board might be dead,need replacing or the incomming coalax signal cable is damage.Take ur tv to another location plug in another incoming coalax signal cable,if u have the same problems after the tv is on about 20 mins or less.Than ur Tuner board is the cause,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.If the incommnig coalax signal cable is the problems,call ur cable companny.
Apr 28, 2010 | Sanyo 42 in. LCD TV
Televison & Video Logo
Computer Repairing
Computer Repairing
