Question about Samsung CLP 300 Laser Printer
It won't feed paper, soon as it begins to feed, stops and red light comes on
  • 3 Answers
I have a CLP-300, the paper jams alot also - I have found that cleaning the area around the imaging unit seems to help.
but usually the best fix is to replace the Waste Toner Bottle. that seems to let it work for awhile. If it starts acting up again, I'll empty the bottle, vacuum the imaging unit area and seems to help. I think 3 times is the most I have been able to do this before needing to use a new toner bottle.
Hopefully this helps...
Posted on Aug 28, 2010
HSM AMA 125HS-6 Starts to shreed and abuptly stops. Red light comes on next to a circl symbol.
Thickness of papers is too much. Feed only 1-2 pages at a time.
To clear, pull paper back out. Run reverse, then forward, then feed 1 page at a time using a clean edge.
Sep 13, 2009 | Office Equipment & Supplies
PAPER WON"T LOAD
The problem is software rather than mechanical operation. Uninstall the printer driver from the Add/Remove section of the Control Panel. Pull out the USB port and replace it back. This will prompt you pc to install the driver of the newly found hardware. Reinstall the printer driver. Should your printer be observed to have the usual problem, replace both cartridges with a one. "Loading paper" problem feedback is the same prompt as what you get when cartridges are old or refilled with unauthentic ink.
Feb 03, 2009 | Canon PIXMA iP1600 Printer
Paper won't load. and Stops printing before it can start.
Try turning the paper around. Some times the corners of the paper get slightly bent and the paper wont load.If turning the paper around does not work, switch your paper. Hope this helps.
Epson R220 paper feed.
TRY holding all 3 bottons at the same time for 20 sec this will reset the printer
Nov 18, 2008 | Epson Stylus Photo R220 InkJet Printer
The paper only feeds part way and then stops. Red light comes on
Following a suggestion on another post, I tilted my printer so it is at a slight angle backwards, higher at the front. So far this has worked.....
Nov 12, 2008 | Samsung ML 2010 Laser Printer
RED LIGHT BROTHER 2040
light explain link check first!.... paper jam light indicates a few things ie paper mismatch.
possible dirty feed roller, confirm by using bypass slot.
slightly damp rag on rubber feed roller to clean if the issue
Dec 22, 2007 | Brother HL-2040 Laser Printer
Feeding paper too early
try doing a reset. When you plug in the machine as soon as the lights flash. Hold the power and copy buttons down and allow the printer to do a memore reset.
That may help.
Nov 17, 2007 | HP PSC 1315 All-In-One InkJet Printer
Samsung CLP 300 Laser Printer Logo
119 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
