Question about Car Audio & Video
Cobra 7928 car alarm
Hi i just replaced the batteries in my alarm key fob and now it wont work at all i know the batteries work as the lights flashing. maybe i need to reset it but dont know how. please help !!!!!!
  • Anonymous Dec 04, 2008
    exactly the same! I will try first solution and tell you if it works! thanks anyway!
  • 4 Answers
Hold both buttons down until led goes out. let go. led will stay on.
press large button twice.
actually
Posted on Oct 24, 2008
  • 47 Answers
REMOVE THE BATTERIES HOLD THE LOCK BUTTON FOR 10 SECONDS AND RE INS THE BATTERIES
Posted on May 13, 2008
Cobra inverter
should probably connect it straight to your battery or you are trying to use something that requires too much power.
Sep 04, 2014 | Cobra 12 Volt 2500 Watt Power Inverter...
My amp wont shut off when i turn off the car and take the keys out. just want to know how to turn off the amp. im out of town and cant go to the place i had everything installed at, for another week. just...
Hi, can you disconnect the wire from the "rem" terminal of the amp? The wire connected here is supposed to come from the head unit and is hot only when the head unit is turned on. It should be a blue wire.
Sep 12, 2011 | Alpine MRD-M1000 Car Audio Amplifier
I just bought two ten inch JL Audios and i hooked them up and they work great.... i installed them two days ago, and since then my battery has died on me twice.... i dont know what the problem is... i...
Hi there, check when you have switched off the power in the car to see if the amp power lights are still on, if so there could be a problem with your remote wire. Check the cables to he rear of your stereo and with a test meter, determine which one loses power when the ignition key is removed. When you have found this cable, splice your remote lead to this one, and your amp should switch off when you switch the car off, thus saving your battery. You could wire it to a permanent live feed and install a switch to allow you to run the amp without the key in the ignition but dont forget your battery will run down fast because Amps use a LOT of power.
May 06, 2011 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Hi. I have a Kicker amp KX1200.1 that doesn't seem to be working. I think it blew a fuse. Do you know how I can get that fixed?
You should have an inline fuse (external) at the amp and one at the battery. There are not fuses on the amp.
Jun 25, 2009 | Kicker KX1200.1 Car Audio Amplifier
Need fuse size for cobra cpi-850
80a fuse should work fine thats the size i have it installed with i used 4 ga. wire
Jan 08, 2009 | Cobra CPI-850 Car Audio Amplifier
Car alarm in-line fuse
What type of alarm system is it? The size of the fuse varies slightly depending how extravagant the alarm is. You could try to low ball it and if it pops the fuse then get a slightly bigger one. You might start out at 15 amps. BUT, if you can tell me the make and model of the alarm then I might find out the correct size. I hope I can help.
-Andrew Hawkins
Mar 31, 2008 | Car Audio & Video
Car alarm programing
Assuming the following -
1. Your key, when turned to lock or unlock in the driver's door key cylinder and held there, will roll the windows/sunroof up or down respectively,
2. The transmitter on your car locks and unlocks the doors just fine.
3. You know where the valet switch for your alarm is located.
Program as follows:
Open the door and leave it open until you've finished programming. Turn the ignition on and off. Push the Valet switch and release it 10 times, and push it an 11th time making sure to hold it in. You should see 10 flashes on the status LED, 10 siren chirps, or both. This tells you that you are in option 10, which is the comfort closure feature.
At this point push the unlock button on the transmitter. That will change the comfort closure setting to "on". Once the unlock button is pushed the LED should stop flashing. At this point it is programmed and you can turn the ignition on again.
Feb 21, 2008 | Car Audio & Video
Cobra 6422 alam
chek the remote turn on cable it should be connected to cd player or possitive
Jan 23, 2008 | Car Audio & Video
Audiobahn A2300HCt wont work
you might not have enough power pushing the amp.... I have two batteries and two caps running
Apr 02, 2007 | AudioBahn A2300HCT Car Audio Amplifier
Car Audio & Video Logo
522 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
