Question about Mastercool 67680 Evaporative Cooler Air Conditioner
Pulleys not working
When I turn on the power switch for the air conditioner, the motor hums like it is trying to start but it won start turning the belt, until I help the bottom wheel move slightly ... then it runs like a champ.
Is my belt to tight? do I need to adjust something?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
More than likely the pulley set screw is lose. Look on the inner hub of the pulley's both on the motor and the fan for a threaded hole with an allen head type of screw in it. Before you 'help' it to turn, look to see if one shaft of the other is spinning inside the pulley without the pulley itself turning. Buy a set of allen wrenches and tighten the screw. You may have to remove the belt to see the setscrew hole. It can be done by stretching it over the edge of the larger pulley and rotating it by hand. Put it back the same way. BTW make sure the power is OFF! fingers are still at a premium.
Posted on May 07, 2009
    Genius:
  • 1,665 Answers
Motor winding seems to be shortcircuited
Posted on May 05, 2008
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos May 05, 2008
    The unit tries to start for a few seconds and then quits
    Every air conditioner has a motor called a compressor. The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.) If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician. This problem is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner.
    give model no and mfg name to search if a service manual is available on web.
The AC makes a humming sound when starting the fan. If I spin it by hand it runs. Model 620315.321 serial 90716722.
The humming sound is the motor trying to start, if you turn it by hand, usually they will run. it sounds like the motor for fan needs cleaning and oiling. God-Bless ya all!
May 20, 2016 | Dometic Rooftop RV Air Conditioner
Husky air compressor motor hums won't start
In a safe manor, when the motor is humming, give one of the pulleys a push to help get the motor started. If the motor runs OK with the help push, the start capacitor is bad. If not the next thing to check is the tank check valve.
Nov 23, 2012 | Air Tools & Compressors
Hello... I have a Goodman CKL49 a/c unit on the exterior of my house. I have checked everything I can think of and isolated the issue to the fan motor not turning on. The unit will recieve the signal from...
Hello, try using a small object to push the fan with power applied to it, if this gets the fan going tnen the capacitor must be replaced. If the fan does not start up then the motor is shot and must be replaced.
Sep 02, 2011 | Goodman CKL49AR49 Air Conditioner
New serpentine belt smoking on 02 zx2
Check to make sure all the idler and other belt pulleys turn freely. It's possible that one of the pulley bearings is locked up which will cause the belt to smoke and fail as it slides over the siezed pulley.
Mar 07, 2011 | 2002 Ford ZX2
Fan not blowing
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
May 06, 2008 | Weather King 10AJA2501AH Air Conditioner
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
447 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
