Question about Sony UVW1800 VCR
Error 02-403 Sony Betacam - Sony UVW1800 VCR
Sony bvw300 humidity error
Use an hair dryer and warm within the set. If it clears wipe off any dew that has set in . Wipe also the head clear with a good swab. if the fault is recurring then clean the dew switch sensor or replace.
This is found inside the loading compartment , a small square block. about 1.5mm. Helpful. Good day
Jun 10, 2010 | Sony Betacam SP Small Videocassette 30...
Error02-694 Sony Betacam Deck UVW-1800
UVW-1800 error 02-694 indicates a problem with one or both reel motors. check the cables going to both motors; have seen failures related to these cables.
Jul 21, 2009 | Sony Betacam SP Small Videocassette 30...
Sony Beta sp deck 1800 wont take larger tape down
Most likely problem when a Beta SP deck won't take the large tapes is a bad cable in the cassette housing. Replacement isn't too difficult, and the cable only costs about $20.00.
Jul 14, 2009 | Sony Betacam SP Small Videocassette 30...
Beatcam SP error message
BVW-75 error 09 is "threading motor time out". Look for something obstructing the travel of the threading ring inside the deck (the ring which pulls the tape around the video head).
May 02, 2009 | Sony Betacam SP Small Videocassette 30...
The machine is a SONY VIDEO CASSETTE RECORDER UVR 1400 AR
uvw-1400 error 02-803 is "tape tension error when threading". possible bad threading motor or threading mechanism.
Feb 11, 2009 | Sony Betacam SP Small Videocassette 30...
Mensaje error 02-395 on a Sony BETACAM UVW 1800
error code 02-395 points to a problem with one or both reel motors. a good technician should be able to fix this easily.
Jan 21, 2009 | Fuji M321SP Betacam Tape
Tape End Sensor Error - UVW1800
these error codes point to possible problems with one or both reel motors.
Dec 11, 2008 | Sony Betacam SP Small Videocassette 30...
Betacam Sp Error Code
It seems mechanical problem and you need to apart unit.
I would advice you to get Maintenance Manual of BVW-75 before to open unit and get help from mechanical exploded section.
Below is picture of Maintenance Manual and part of mechanical exploded view...
It is high end broadcast model and needs care in maintenance.
Good Luck.
Nov 26, 2008 | Sony Betacam SP Small Videocassette 30...
I have a Sony UVW 1800 Beta SP deck. This morning, after completing a dub, I rewound the tape. The machine made a sound, the tape stopped and became stuck in the machine. I received an error code 02-803. I...
check your tape deck unit throughly check for any physical damage of REWIND/FORWARD Gears.and FLY Wheel.
and dis locateion of some lever positions.
defnitly you get solved
Nov 13, 2008 | Sony Betacam SP Small Videocassette 30...
Televison & Video Logo
567 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
