Question about Dishwashers
Caster wheel broken - Dishwashers
  • ltews2001 Jan 16, 2009
    where can i buy one
  • 1,073 Answers
Whats the model number
Posted on May 05, 2008
Caster broken
Some caster wheels are a press fit on an axle. That's why they frequently fall off.
Feb 19, 2014 | Goldstar DH304 Dehumidifier
Where can i get a set of wheels for my five gallon brute vaccuum?
emailthispage.gif printthispage.gif 1" Dual Wheel Caster (Set of 4 6774200 casters with retainers) Catalog No. 420-63-96
Four (4) casters. Set of 4 Replacement Caster Wheels with retainers. This item is the replacement for the plastic, non-hooded casters shown. These casters you will receive are an upgraded dual hooded caster that are a perfect replacement but offer superior performance.
Four (4) casters. Discontinued. Order this item and we will send you an upgraded, superior dual hooded set of casters. A = 1-12/16" B = 1/4" C = 1-9/16" D = 3-7/16"
You can also look at your local Lowe's who sometimes carry a generic wheel.
Mar 07, 2011 | Shop Vac Brute 5 Gallon Bagged Canister...
I need to replace the tires and casters on my probasics wheelchair. I am not sure what I should order and whether the tires come on the wheels ot what.
As a general rule, it is best to replace the caster as a complete assembly consisting of tire and wheel hub. Usually this is the only way to replace casters when the tire is molded on to the wheel hub. It is the best way to replace the caster since you get a tire, wheel hub and 2 new bearings.
With regard to the drive wheels on a manual wheelchair you can get just a new tire. With a plastic mag wheel and hand-rim you can sometimes get just a replacement snap-on tire to replace the existing.(Snaps on like a rubber band using tire irons). If the hand-rim, wheel, spokes, and bearings are worn or broken, you are usually better off replacing the wheel assembly. With power chairs, it is more cost effective to only replace the drive tires and use the existing wheel rims. Hope this helps.
Dec 23, 2010 | Probasics Health & Beauty
How do you raise the metro to make it sit higher off the floor? Is it adjustable
This mnaual wheelchair has dual position rear axles and caster forks to allow seat to floor height changes with no additional components. What this means is that the wheelchair is adjustable in height based upon the position of the front caster wheel axles and rear wheel axles. Raising the axles lowers the chair. Lowering the axle postion raises the chair. If the rear axles of the rear wheels are in the top position you can lower the wheels and raise the chair. Likewise, if the caster axles of the front wheels are in the top hole of the fork then put the wheels and axles in the lower hole to raise the chair. It is easy to accomplish this with basic tools.
If the front and rear wheels are already in the lower holes (the chair is in its highest position) you have another option. This option is a more expensive way to raise the chair by buying 4 new wheels. Lets say for example you have 24" diameter rear wheels. If you purchase new 26" diameter wheels you will raise the chair 1". If you have 6" casters and put on 8" casters this raises the chair 1" in the front. Hope this helps.
Nov 23, 2010 | Everest & Jennings 18" Metro Ic3...
Need replacement caster wheel unit.
I found them here:
Feb 20, 2010 | Pelonis WM-HO202C Oil Filled Radiator...
Broken wheel roller on a PAC-121 portable air conditioner
Yes, you can. The caster part number is 2040-0142 and can be found at some online retailers.
Feb 18, 2009 | Comfort-Aire PAC-121 Air Conditioner
Changing the dual axle on an Invacare recliner to lower seat
You will need to remove the rear tires and front casters. If you look at the front caster fork there should be some extra holes where you can re-position the caster wheel. Likewise on the hole where the rear tires mounts there should be a hole above it where you can re-mount the tire. So just move the caster and wheel up to the next hole. If there are no holes to move up to then you cant lower the chair. The only other options would be to install a drop seat which you`ll have to purchase from a dealer or install smaller wheels and casters. So, for instance,say you have 8" casters and 24" wheels you would then install 6" casters and 22" wheels. Good Luck and let me know how it turns out.
Jan 16, 2009 | Invacare Lightweight Tracer SX5 Wheelchair...
Broken casters (wheels)
This is definitely something that you can do yourself. Remove the back of the dishwasher and the front kickplate. This will give you access to the wheels. The wheels are held in place with a U shaped clip. Remove the clip and the wheel will come out. replace with the new wheel.
This happened with my Danby DDW1805 and I fixed it myself. I used two step stools at the side of the dishwasher to raise it off of the floor.
Aug 28, 2006 | Danby DDW1805W Designer Series...
Dishwashers Logo
123 people viewed this question
Top Dishwashers Experts
